3.5B4: Input Shaping Plugin: Bug: Data collection cancelled
Beta Firmware
524
  • undefined
    alexjx
    There is a bug in the latest 3.5B4 input shaping plugin, when we try capturing data, we always get "Data collection cancelled" error message. If it's a multi-move test, only the first move will be recorded due to this error. Others have seen such issue too.[https://forum.duet3d.com/topic/32383/input-shaping-plugin-not-collecting-data-using-3-5-0-beta-3/23]
    I'm using a proper shielded cable (shield grounded), so I think I could rule out the potential cable issue.
    The problem is that the plugin assumes we're always using the CANBUS to connect the accelerameter, and following code will throw if it's a none CANBUS board, as in my case a Duet2 WIFI.
    // src\plugins\InputShaping\RecordMotionProfileDialog.vue:494
    // Get board
    const board = this.boards.find(board => board.canAddress === parseInt(matches[1]));
    if (!board) {
    throw new Error("Failed to get accelerometer board");
    I have zero exprience in Vue, and less in frontend, so I don't know what a proper fix should be. However, can we assume that for a none CAN-connencted board, the canAddress will always be null? And there should only be one such board? Like following?
    // Get board
    const board = this.boards.find(board => board.canAddress === null || board.canAddress === parseInt(matches[1]));
    if (!board) {
    Thanks
    Jia
    undefined 1 Reply Last reply 20 Jun 2023, 09:48 Reply Quote 1
    • undefined
      chrishamm administrators @alexjx
      @alexjx I cannot confirm this, it works OK on my Duet 3 Mini5+ setup with 3.5-b4 which only has an accelerometer connected to the mainboard. The code you are referring to only captures the first number from the accelerometer string (0 -> 0, 1.0 -> 1) to identify the accelerometer to observe in the OM while a move is being performed.
      It may help to check the JS console for potential errors if the data collection fails.
      Duet software engineer
      undefined 1 Reply Last reply 20 Jun 2023, 10:08 Reply Quote 0
      • undefined
        alexjx @chrishamm
        @chrishamm I think the codes lead to a subtle situation where it just happened to work unintentionally. As far as I recall, duet mini 3 has CAN bus capability, by another word, there will be a valid CAN address.
        Please see following picture, the accelerometerId is "0", so long if there is a board with canAddress equals to 0, the find will return a valid board. Therefore as long as we have a board with canAddress matching, we will not have the problem.
        However with duet 2 wifi, we dont have such a board, it will always return undefined in line 495, and exception afterwards.
        undefined 1 Reply Last reply 20 Jun 2023, 11:04 Reply Quote 0
        • undefined
          @alexjx Thanks, that's a valid concern. I just committed a possible bug fix to GitHub, are you able to test it?
          undefined undefined undefined 3 Replies Last reply 20 Jun 2023, 11:21 Reply Quote 1
          • undefined
            tas @chrishamm
            @chrishamm I can test this now on a Duet 2 Wifi in standalone. Can you provide a link to the file please, I can't find it. Must be too early in the morning.
            undefined 1 Reply Last reply 20 Jun 2023, 11:23 Reply Quote 0
            • undefined
              droftarts administrators @tas
              @tas Here is the commit https://github.com/Duet3D/DuetWebControl/commit/5db3108df0e8435e726b0ec5bc2954d09c422872
              0 chrishamm committed 20 Jun 2023, 11:04 to Duet3D/DuetWebControl
              Potential bug fix for IS plugin
              undefined 1 Reply Last reply 20 Jun 2023, 11:29 Reply Quote 1
              • undefined
                tas @droftarts
                @droftarts Many thanks but sorry I have no idea where to put those files. I was expect a zip of DWC. Any instructions appreciated.
                undefined 1 Reply Last reply 20 Jun 2023, 12:03 Reply Quote 0
                • undefined
                  alexjx @tas
                  @tas I think you have to compile it. I will give it a try. I think it should work.
                  undefined 1 Reply Last reply 20 Jun 2023, 12:04 Reply Quote 0
                  • undefined
                    tas @alexjx
                    @alexjx Thanks, sorry I wasn't able to help.
                    • undefined
                      alexjx @chrishamm
                      @chrishamm The patch works.
                      • undefined
                        droftarts administrators @chrishamm
                        @chrishamm Can you post a patched DWC.zip?
                        undefined 1 Reply Last reply 20 Jun 2023, 12:38 Reply Quote 0
                        • undefined
                          jay_s_uk @droftarts
                          @droftarts https://drive.google.com/drive/folders/1qd4OQXAwT2fin9BYjAkfLMPyyukXC77A?usp=drive_link
                          undefined 1 Reply Last reply 20 Jun 2023, 12:44 Reply Quote 0
                          • undefined
                            tas @jay_s_uk
                            @jay_s_uk Excellent! Thank you. This works on my Duet 2 Wifi standalone.
                            • undefined tas referenced this topic 21 Jun 2023, 01:44
                            • undefined tas referenced this topic 28 Jun 2023, 13:22
                            9 out of 13
