Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5
Hi everyone,
today, I decided to update my Duet Wifi v1.04 from v2.05.1 to 3.4.5.
Some dates about the 3D printer:
• 3D printer: Anycubic Chiron
• Motherboard: Duet 2 WiFi
• Firmware name: RepRapFirmware for Duet 2 WiFi/Ethernet
• Firmware_version: 2.05.1
• Eletronics: Duet WiFi 1.02
• Firmware date: 2020-02-09b1These are the web site I visited until now:
• https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware
• https://docs.duet3d.com/User_manual/Referenc
• https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
• https://docs.duet3d.com/User_manual/Troubleshooting/WiFi_troubleshooting
In this article (https://forum.duet3d.com/topic/28000/duet-2-wifi-v1-04-web-interface-incompatible-firmware-version/4 ) I found a person who had the same problem, but I tried without results.As you can see in this other image I substituted some installation files in the www folder.
Next, you can see the error message.
I reset the modem ADSL, I tried to connect to the phone hotspot, to import (following the instructions https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware) due to SD card all the files for the update of the firmware 3.0.0.
I tried a Fallback procedure using USB port and YAT too.
Any Ideas ? I tryed allready for a few hours to solve the problem.
Thanks!Savier
@genioluiz7 I'd guess that the SD card has been corrupted just enough for the Duet not to be able to read it, as it has been working up until now. You even have a picture of the newer version of DWC in your first post, so it got that far. To get to the point where it says "Your Duet rejected the HTTP request", the firmware is starting up, the config.g is read (it has to be, to turn the networking on), it is connecting to your network, and the request from your browser is making it to the Duet. It's just that the Duet can't find the file the browser is requesting, which could be because it is corrupted, or not in the correct place.
While the SD card can be read in your PC, it has the benefit of a sophisticated operating system, with gigabytes of memory. The microcontroller on the Duet runs everything in 0.5MB! So the SD card does need to be in the best condition.
Try:
- Copy any important files (eg contents of sys folder) to your PC.
- reformatting the SD card, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting
- Create the folder structure, copy files back to SD card
- Make sure you use the version of DWC that matches the firmware version on the Duet.
@genioluiz7 can you post a screenshot of the contents of the SD card and of the www folder?
Can you also post an output of M122 -
@genioluiz7 see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-from-older-firmware-versions
In the 'Updating from 1.x or 2.x', there's this:If you are updating a Duet 2 WiFi from RRF 1.18.2 or earlier, you will also need to manually update the WiFi firmware via USB or PanelDue. See 'Updating WiFi firmware' instructions below. And you will need to unzip the Duet Web Control zip file into a folder called 'www' on the SD card. See SD card for the current SD card structure.
I think you have already unpacked the updated DWC files into the www folder on the SD card.
Follow the instructions here: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-wifi-firmware
@jay_s_uk sure
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SN-6J1DG-3SD6J-TUT3L
Used output buffers: 1 of 24 (3 max)
Static ram: 25712
Dynamic ram: 93140 of which 0 recycled
Exception stack ram used: 312
Never used ram: 11908
Tasks: NETWORK(ready,1416) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:02:23 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11732 bytes (slot 1)
Error status: 0
Free file entries: 10
SD card 0 not detected, interface speed: 20.0MBytes/sec
MCU temperature: min 24.1, current 28.9, max 29.1
Supply voltage: min 0.2, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 382506108
Slowest loop: 5.08ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 2 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 12.44ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.27
WiFi MAC address 84:0d:8e:b3:04:69
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25800
WiFi IP address 192.168.1.53
WiFi signal strength -56dBm, reconnections 0, sleep mode unknown
ok
- WiFi -
@genioluiz7 said in Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5:
do you have the SD card in the board when you ran this?
Can you also confirm what filesystem the SD card has been formatted in? (it should be FAT32 to work) -
@jay_s_uk no the SD card was in my pc when I run M122. Do I retry the command with the SD card inside?
The SD card is formatted correctly
@genioluiz7 yes, would just help to make sure its being read correctly
@jay_s_uk === Diagnostics ===
Used output buffers: 1 of 24 (11 max)
Static ram: 25712
Exception stack ram used: 320
Never used ram: 11900
Owned mutexes:
Last reset 00:14:53 ago, cause: power up
Error status: 0
MCU temperature: min 28.8, current 32.6, max 32.9
Supply voltage: min 1.5, current 1.7, max 24.4, under voltage events: 1, over voltage events: 0, power good: no
Cache data hit count 2698876049
Slowest loop: 1.71ms; fastest: 0.05ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 200.45ms; fastest: 0.06ms
Failed messages: pending 0, notready 0, noresp 1
ok
- WiFi -
@genioluiz7 so thats fine. does it still show as
Duet ejected your HTTP request
when you navigate to 192.168.1.53? -
@genioluiz7 ok, i see the issue.
replace the contents of the www folder with the contents of this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/2.05/DuetWebControl-SD-2.04.zip -
@jay_s_uk
Just to specify... Have I to unzip this file and put all the files inside in the www folder? -
@genioluiz7 yep
@jay_s_uk ok now? retry M122?
@genioluiz7 now try the ip address again (obviously with the SD card inserted and the board power cycled)
@jay_s_uk
again
@genioluiz7 my only other thought is that you're running the latest wifi firmware with 2.05.1.
put this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
and this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedIAP.bin
in the "sys" folder thats on the SD card.
Then with the sd card inserted sendM997
using YAT
that should install 3.0. you can then confirm using M115
then try browsing to the IP address again -
@droftarts I've already tried this
@jay_s_uk
So, have I just to put them in the sys folder? -
@genioluiz7 yep, then run M997 etc
