    BLTouch giving error
    345
    • terhartundefined
      terhart
      the (original Antclaps)BLTouch sensor on my printer is giving problems.
      When I use the G28 command or home the Z direction, I get the error: G28 Z Error: Bad command: probe
      I tried to find the reason for the error, tried different versions of the firmware, nothing works really. The error stays.
      When I use the command M280 P0 S10 / M280 P0 S90 no error occurs.
      Using M401 P0 and M402 P0 give an error.
      Does anybody have an idea of what I'm doing wrong here?
      Thanks a lot for your help.
      This is what the system looks like:
      Board: Duet 2 WiFi
      Current firmware version: 3.4.1
      WiFi Server: 1.26
      Web Control: 3.4.1
      I tried other (newer) versions but that makes no difference, error stays)
      This is what the system files look like:
      Config.g:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 19:16:17 GMT+0200 (Midden-Europese zomertijd)
      M550 P"Ter Hart 3D-Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards X-Motor
      M569 P1 S1 ; physical drive 1 goes forward Y-Motor
      M569 P2 S0 ; physical drive 2 goes backwards Z-Motor Twee motoren in parallel
      M569 P3 S1 ; physical drive 3 goes forward E0-Motor
      M92 X100.00 Y100.00 Z1600.00 E563.77 ; set steps per mm
      M566 X350.00 Y350.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z120.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z150.00 E1000.00 ; set max acceleration HtH 23052022
      M906 X1500 Y1500 Z1500 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X270 Y270 Z300 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin !^xstop
      M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin !^ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z1.65 ; set Z probe trigger value, offset and trigger height Hogere waarde = dichter naar het glas
      ; Grid
      M557 X0:250 Y0:180 S180 ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
      ; Control Cooling Fan
      M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Cooling Fan" ; set fan 0 value. Thermostatic control is turned off
      ; Control Nozzle Fan
      M106 P1 S1 H1 T45 C"Nozzle Fan" ; set fan 1 value. Thermostatic control is turned on
      ; Control MCU temperature
      M308 S4 Y"mcu-temp" A"MCU Temp"
      M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.15 X1 B0.3 T25:35 C"MCU Fan" ; set fan 2 value, turn on at 50% if the CPU temperature reaches 45C, and increase to full speed gradually as the temperature rises to 50C
      ; Filament sensor
      M591 P1 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop
      M501 ; set the active parameters to those stored in sys/config-override.g on the SD card
      M912 P0 S-12 ; correctie MCU temperatuur T nozzle - T MCU
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; calle� to retract a physical Zprobe
      ; generated �y RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 19:16:17 GMT+0200 (Midden-Europese zomertijd)
      M280 P0 S90 ; retract BLTouch
      The macros use M401 and M402
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @terhart
        @terhart post your homez file
        M401 and M402 should just be M401 and M402 with no P0 at the end
          droftarts administrators @terhart
          @terhart @jay_s_uk M401 and M402 should be able to take a P parameter; see https://docs.duet3d.com/User_manual/Reference/Gcodes#m401-deploy-z-probe
          However, this sounds like a bug, and that it is looking for deployprobe0.g, and when it does not find it, it is not switching to deployprobe.g. I've marked this as a bug for @dc42 to check.
          • terhartundefined
            terhart
            Here is the homez file:
            ; homez.g
            ; called to home the Z axis
            G91 ; relative positioning
            G90 ; absolute positioning
            G1 X15 Y15 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
              Did you modify your deploy and retract macros to remove the P0 from the M280 commands?
              terhartundefined 2 Replies Last reply Reply Quote 0
              • terhartundefined
                terhart @Phaedrux
                @Phaedrux Yes, I did. But unfortunately it didnt solve anything. Error stays.
                Thanks for your help.
                • terhartundefined
                  terhart @Phaedrux
                  @Phaedrux Next to my previous remark: This is exact error text that is generated:
                  M98 P"0:/macros/BLTouch Retract"
                  There is no error on the deploy macro.
                  Also, if I initiate the command "M280!P0 S90" or "M280!P0 S10" the BLTouch deploys and retract without an error.
                  The error only comes on M402.
                  Thanks.
                    deployprobe.g and retractprobe.g must be in the sys folder for M401 and M402 to work. They must be named that way too.
                      dc42 administrators @terhart
                      @terhart said in BLTouch giving error:
                      We'll need to see the contents of macro file "BLTouch Retract" to diagnose that.
                      terhartundefined 1 Reply Last reply Reply Quote 0
                      • terhartundefined
                        terhart @dc42
                        Hi, thanks for helping me.
                        This is all that is in the BL Touch Retract file:
                        M402
                        If I just enter M402 on the command line, a "probe" error is raised.
                        Best regards,
                        Hans ter Hart
                          retractprobe.g deployprobe.g
                          Try placing these files in your sys folder.
                          • terhartundefined
                            terhart @Phaedrux
                            @Phaedrux
                            THANKS!!!! That did it....!! Problem solved! No error anymore.
                            Best regards,
                            Hans
