Error:Failed to activate input monitor on pin 255
Hi all.
I have a genuine duet 3 and 1LC. I have just installed and commissioned the 1LC. When I go to print a gcode file I get this error first Error:Failed to activate input monitor on pin 255. It must be the 1LC toolboard as I've never seen this message before
What is this related too? Accelerometer on the toolboard
@SJI no idea until we see your config
@jay_s_uk
; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Jul 11 2023 13:25:33 GMT+1000 (Australian Eastern Standard Time); General preferences
; Wait a moment for the CAN expansion boards to start
; Toolboard 1LC CAN Address B20
G4 S2 ; Wait for Toolboard 1LC to Start
;--------------------------------------------------------------------------------------------------------------------------------------------------------------G90 ; send absolute coordinates...
M550 P"HevORT - Midnight" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 P192.168.1.20 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S1 ; physical drive 0.0 goes forwards X
M569 P0.1 S0 ; physical drive 0.1 goes backwards Y
M569 P20.0 S0 ; Toolboard 1LC physical drive 0.2 goes backwards E
M569 P0.3 S1 ; physical drive 0.3 goes backwards Z1
M569 P0.4 S0 ; physical drive 0.4 goes forwards Z2
M569 P0.5 S0 ; physical drive 0.5 goes backwards Z3
M584 X0.0 Y0.1 Z0.3:0.4:0.5 E20.0 ; set drive mapping MB6 and Toolboard 1LC B20 Address
M92 X80.00 Y80.00 Z800.00 E412 ; set steps per mm
M566 X1200.00 Y1200.00 Z155.00 E5000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z1200.00 E10000.00 ; set maximum speeds (mm/min)
M201 X10000.00 Y10000.00 Z500.00 E30000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1000:1000:1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout;--------------------------------------------------------------------------------------------------------------------------------------------------------------
; Axis Limits - Define X,Y Origin
;X0.0 Y0.0 = Bed Center
M208 X-142 Y-152 Z0 S1 ; set axis minima
M208 X142 Y152 Z320 S0 ; set axis maxima;--------------------------------------------------------------------------------------------------------------------------------------------------------------
M574 X1 S1 P"20.io2.in" ; Tool board 1LC configure active-low X axis endstop
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z;--------------------------------------------------------------------------------------------------------------------------------------------------------------
M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Bed" ; configure sensor 0 as thermistor on pin temp0
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"20.temp1" Y"thermistor" T500000 B4723 C1.196220e-7 A"LGX Hotend" ; configure sensor 1 as thermistor on pin temp1 - Slice Engineering HTT 13/5/21
M950 H1 C"20.out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
M307 H1 R3.048 K0.408:0.041 D3.32 E1.35 S1.00 B0 ; LGX Tuned for 220 deg 12/07/2023
M143 H1 S400 ; set temperature limit for heater 1 to 400CM308 S2 P"temp2" Y"thermistor" T100000 B4138 A"Chamber" ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2
M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
M141 H2 ; map chamber to heater 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C;--------------------------------------------------------------------------------------------------------------------------------------------------------------
M950 F0 C"0.out9" Q2000 ; create fan 0 on pin out7 and set its frequency
M106 P0 C"CPAP Cooling" S0 H-1 B0.1 L0.15 ; set fan 0 name and value. Thermostatic control is turned offM950 F1 C"20.out2" Q100 ; Toolboard 1LC create fan 2 on pin OUT2 and set its frequency
M106 P1 C"LGX Cooling" H1 T45:150 ; Toolboard 1LC set fan 1 name and value. Thermostatic control is turned on;--------------------------------------------------------------------------------------------------------------------------------------------------------------
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C;--------------------------------------------------------------------------------------------------------------------------------------------------------------
; Pushed to macro's
M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^20.io0.in" H20 F500 T12000 ; set Z probe type to bltouch and the dive height + speeds;--------------------------------------------------------------------------------------------------------------------------------------------------------------
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossM950 P2 C"out3" ; Set out3 to Heatbed Safety Contactor
M42 P2 S0 ; Set Heatbed Safety Contactor OffM912 P0 S-8.3 ; Set Electronics Temperature Monitor Adjustment
T0 ; select first tool;Toolboard 1LC
M955 P20.0 I20 ; Configure accelerometer on toolboard with CAN address 20 and specify orientation
; Accelerometer Orientation - Accelerometer X+ = Axis X+, Accelerometer Y+ = Axis Y+
M593 P"zvddd" F40.5 ; use ZVDDD input shaping to cancel ringing at 40.5Hz
@SJI theres nothing in your config thats wrong so maybe something is being added to your gcode thats sending a command.
maybe post your start gcode so we can take a look -
;Simplify 3d – Scripts – Starting G90 M82 M98 P"0:/macros/Setup/Safety_Contactor_ON" M98 P"0:/macros/Setup/StartScript" ;Select Bed Mesh ;M117 "Bed Mesh Full X260 Y290" ;M98 P"0:/macros/Bed/BedMeshFullX260Y290" ;M117 "Bed Mesh Half X130 Y145" ;M98 P"0:/macros/Bed/BedMeshHalfX130Y145" M117 "Bed Mesh Small X65 Y72.5" M98 P"0:/macros/Bed/BedMeshSmallX65Y72.5" ;M117 "Bed Mesh Ulti X150 Y130" ;M98 P"0:/macros/Bed/BedMeshUltiX150Y130" T0
;P"0:/macros/Setup/Safety_Contactor_ON" ;Safety Contactor ON M42 P2 S1
;P"0:/macros/Setup/StartScript" ;Here is the start of the macros for bed leveling, etc M98 P"0:/macros/Setup/Filament_Loaded_message" M98 P"0:/macros/BLTouch/Probesettings.g" ;BLTouch Parameters M117 "Screw Levelling" M98 P"0:/macros/Bed/ScrewLevelling" ;Levels Bed Screws
;P"0:/macros/Setup/Filament_Loaded_message" M291 P"FILAMENT LOADED?" S3 G4 S1 M117 "LET'S PRINT" G4 S1
;P"0:/macros/BLTouch/Probesettings.g" M574 Z0 P"20.nil" M950 S0 C"20.io0.out" M558 P9 C"^20.io0.in" H20 F500 T12000 G31 P500 X0 Y-30.0 Z1.4 ; set Z probe trigger value, offset and trigger height
;P"0:/macros/Bed/ScrewLevelling" ;3 x LeadScrews Levelling ;BLTouch OffSets ;X axis = 0 no offset ;Y axis = -30 in front of the nozzle M561 ; clear bed transform G29 S2 ; clear height map G28 ; home all axis G90 ; use absolute co-ordinates M671 X-142:0:142 Y-88:152:-88 S50 M558 H20 F480 T12000 ;Set Z probe dive height (H) + speeds (F Probe 1st probe 8mm/s:2nd probe) (T Travel 200mm/s) ; Probe the bed at 3 points adjacent to motors G30 P0 X-142 Y-88 H0 Z-99999 ;X-142 Y88 Driver 3 G30 P1 X0.0 Y122 H0 Z-99999 ;X0 Y304 Driver 4 G30 P2 X142 Y-88 H0 Z-99999 S3 ;X142 Y88 Driver 5 G28 Z ;Home Z Axis Again M558 H5 F120 ;Set Z Axis Dive Height + F = 2mm/s G30 P0 X-142 Y-88 H0 Z-99999 ;X142 Y88 Driver 3 G30 P1 X0.0 Y122 H0 Z-99999 ;X0 Y304 Driver 4 G30 P2 X142 Y-88 H0 Z-99999 S3 ;X142 Y88 Driver 5 G28 ; Home all axes for establishing datums
@SJI again, theres nothing in those either so i'm unsure of where the message is coming from.
Do you have anything instart.g
ordaemon.g
in sys? -
@jay_s_uk i'm not using daemon.g or start.g
It's got me stumped.
Oh I'm on build 3.4.5
Board: Duet 3 MB6HC (MB6HC)
Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.5
Duet Web Control 3.4.5
1LC was updated too 3.4.5 -
@SJI can you post the first section of the gcode file up to the point it starts to prnit?
; thumbnail begin 160x160 7692 ;Removed for posting ; thumbnail end ; G-Code generated by Simplify3D(R) Version 5.1.1 ; Jul 12, 2023 at 4:08:35 PM ; Settings Summary ; processName,Process 1 ; targetModels,ExtrusionArm ; profileName,HevORT ; profileVersion,2023-07-12 16:07:33 ; app,S3D-Software 5.1.1 ; technology,fff ; baseProfile, ; extruder,Extruder 1 ; toolheadNumber,0 ; nozzleDiameter,0.60000 ; extrusionMultiplier,1.00000 ; extrusionWidthMode,automatic ; extrusionWidth,0.30000 ; useRetraction,0 ; retractDistance,1.00000 ; extraRestartDistance,0.00000 ; retractVerticalLift,0.00000 ; retractSpeed,1800.00000 ; useCoasting,0 ; coastingDistance,0.20000 ; useWiping,0 ; wipingDistance,5.00000 ; speedMaxFlowRate,1000.00000 ; toolheadOffsetX,0.00000 ; toolheadOffsetY,0.00000 ; filamentDiameter,1.75000 ; filamentPricePerKilogram,52.00000 ; filamentDensity,1.22000 ; primaryExtruder,Extruder 1 ; layerHeight,0.20000 ; topSolidLayers,5 ; bottomSolidLayers,5 ; outlinePerimeters,1 ; useVaseMode,0 ; useAdaptiveLayerHeights,0 ; minAdaptiveLayerHeight,0.10000 ; maxAdaptiveLayerHeight,0.30000 ; adaptiveSmoothingLevel,5 ; horizontalOuterCompensation,0.00000 ; horizontalInnerCompensation,0.00000 ; firstLayerUnits,percentage ; firstLayerHeightPercentage,100 ; firstLayerWidthPercentage,100 ; firstLayerSpeedPercentage,100 ; firstLayerHeightAbsolute,0.30000 ; firstLayerWidthAbsolute,0.40000 ; firstLayerSpeedAbsolute,900.00000 ; startPointStrategy,closest ; alignStartPointsX,0.00000 ; alignStartPointsY,0.00000 ; restrictStartPoints,0 ; perimeterPrintingOrder,inside_out ; islandPrintingOrder,closest ; printInfillBeforePerimeters,0 ; useSkirt,1 ; skirtExtruder,Extruder 1 ; skirtLayers,1 ; skirtOffset,1.00000 ; skirtOutlines,5 ; useRaft,0 ; raftExtruder,Extruder 1 ; raftBaseLayers,2 ; raftTopLayers,3 ; raftOffset,3.00000 ; raftSeparationDistance,0.14000 ; raftSpeedUnits,percentage ; raftSpeedPercentage,30 ; raftSpeedAbsolute,600.00000 ; usePrimePillar,0 ; primePillarExtruder,Extruder 1 ; primePillarWidth,12.00000 ; primePillarLocation,north_west ; primePillarSpeedPercentage,100 ; primePillarInfillPercentage,100 ; autoStopPrimePillar,1 ; primePillarLayersAfterAutoStop,0 ; useOozeShield,0 ; oozeShieldExtruder,Extruder 1 ; oozeShieldOffset,2.00000 ; oozeShieldOutlines,1 ; oozeShieldSidewallShape,waterfall ; oozeShieldSidewallAngle,30 ; oozeShieldSpeedPercentage,100 ; autoStopOozeShield,1 ; oozeShieldLayersAfterAutoStop,0 ; sparseInfillExtruder,Extruder 1 ; sparseInfillPattern,rectilinear ; sparseInfillRotation,0 ; sparseInfillPercentage,100 ; sparseInfillExtrusionWidthPercentage,100 ; sparseInfillCombinedLayers,1 ; denseInfillLayers,0 ; denseInfillPercentage,100 ; infillOutlineOverlapPercentage,25 ; minInfillLength,0.00000 ; externalInfillPattern,rectilinear ; externalInfillRotation,0 ; solidInfillThresholdArea,0.00000 ; solidInfillExtraExpansion,0.00000 ; useMonotonic,1 ; useDiaphragm,1 ; diaphragmSolidLayers,3 ; diaphragmSpacingLayers,20 ; topLayerExtraExpansion,1.00000 ; topLayerExtrusionModifier,100 ; overrideFanSpeedForTopLayer,0 ; topLayerFanSpeedPercentage,100 ; useIroning,0 ; ironingOutlineOffsetPercentage,50 ; ironingExtrusionWidthPercentage,25 ; ironingExtrusionModifier,15 ; ironingSpeedModifier,30 ; sparseSupportExtruder,Extruder 1 ; sparseSupportInfillPattern,aligned ; sparseSupportInfillRotation,0 ; sparseSupportInfillPercentage,30 ; sparseSupportOutlines,0 ; sparseSupportCombinedLayers,1 ; upperDenseSupportLayers,0 ; lowerDenseSupportLayers,0 ; denseSupportExtruder,Extruder 1 ; denseSupportInfillPercentage,70 ; denseSupportExtraExpansion,0.00000 ; baseSupportLayers,0 ; supportInflationDistance,0.00000 ; supportHorizontalPartOffset,0.30000 ; supportUpperSeparationLayers,1 ; supportLowerSeparationLayers,1 ; defaultPrintSpeed,3600.00000 ; outerPerimeterSpeedPercentage,100 ; innerPerimeterSpeedPercentage,100 ; topLayerSpeedPercentage,100 ; solidInfillSpeedPercentage,100 ; sparseSupportSpeedPercentage,90 ; denseSupportSpeedPercentage,70 ; travelSpeedXY,9000.00000 ; travelSpeedZ,3600.00000 ; reduceSpeedForQuickLayers,1 ; speedMaxQuickLayerTime,10.00000 ; minQuickLayerSpeedPercentage,30 ; reduceSpeedForShortPerimeters,1 ; speedMaxShortPerimeterLength,40.00000 ; minShortPerimeterSpeedPercentage,50 ; reduceSpeedForMaxFlowRate,0 ; accelXY,10000.00000 ; accelZ,500.00000 ; accelE,10000.00000 ; jerkXY,600.00000 ; jerkZ,24.00000 ; jerkE,300.00000 ; exportFileFormat,gcode ; useStickyCommands,1 ; use5D,1 ; relativeExtrusionDistances,0 ; allowExtruderAxisZeroing,1 ; independentExtruderAxes,0 ; includeM10123,1 ; includeThumbnailImages,1 ; thumbnailImageEncoding,standard ; thumbnailImageSizes,160|160,400|400 ; x3gMachineProfile,r2 ; overrideStepsPerMillimeter,0 ; stepsPerMillimeterX,88.57319 ; stepsPerMillimeterY,88.57319 ; stepsPerMillimeterZ,400.00000 ; stepsPerMillimeterA,96.27520 ; stepsPerMillimeterB,96.27520 ; xyzFileFormatVersion,1 ; makerBotMachineProfile,replicator_5 ; makerBotModelExtruder,mk13 ; makerBotSupportExtruder,mk14_s ; makerBotModelMaterial,pla ; makerBotSupportMaterial,pva ; globalOffsetX,0.00000 ; globalOffsetY,0.00000 ; globalOffsetZ,0.00000 ; applyToolheadOffsets,0 ; buildVolumeShape,rectangular ; buildVolumeX,260.00000 ; buildVolumeY,290.00000 ; buildVolumeZ,325.00000 ; buildVolumeDiameter,200.00000 ; originOffsetX,130.00000 ; originOffsetY,145.00000 ; originOffsetZ,0.00000 ; homingDirectionX,max ; homingDirectionY,min ; homingDirectionZ,min ; mirrorVisualX,0 ; mirrorVisualY,1 ; mirrorVisualZ,0 ; machineBackgroundModel, ; startingScript,"G90|M82|M98 P""0:/macros/Setup/Safety_Contactor_ON""|M98 P""0:/macros/Setup/StartScript""||;Select Bed Mesh||;M117 ""Bed Mesh Full X260 Y290""|;M98 P""0:/macros/Bed/BedMeshFullX260Y290""||;M117 ""Bed Mesh Half X130 Y145""|;M98 P""0:/macros/Bed/BedMeshHalfX130Y145""||M117 ""Bed Mesh Small X65 Y72.5""|M98 P""0:/macros/Bed/BedMeshSmallX65Y72.5""||;M117 ""Bed Mesh Ulti X150 Y130""|;M98 P""0:/macros/Bed/BedMeshUltiX150Y130""||T0" ; preLayerChangeScript, ; postLayerChangeScript, ; preRetractionScript, ; postRetractionScript, ; preToolChangeScript, ; postToolChangeScript, ; processChangeScript, ; endingScript,"M98 P""0:/macros/Setup/Safety_Contactor_OFF""|M98 P""0:/macros/Setup/EndScript""|" ; postProcessingScript,"{REPLACE ""M101"" ""G11""},|{REPLACE ""M103"" ""G10""},|{STRIP ""M102""},|{REPLACE ""Material Length"" ""Filament length""}" ; useBridging,1 ; bridgingThresholdArea,50.00000 ; bridgingInfillExtraExpansion,1.00000 ; bridgingExtrusionModifier,100 ; bridgingSpeedModifier,100 ; overrideFanSpeedForBridging,0 ; bridgingFanSpeedPercentage,100 ; useFixedBridgingAngle,0 ; fixedBridgingAngle,0 ; applyBridgingToPerimeters,0 ; bridgingPerimeterExtraOverlap,0.00000 ; minBridgingPerimeterLength,10.00000 ; useToolChangeRetraction,0 ; toolChangeRetractDistance,12.00000 ; toolChangeExtraRestartDistance,-0.50000 ; toolChangeRetractSpeed,600.00000 ; toolChangePrimeOnFirstUse,0 ; toolChangeRetractAtEnd,0 ; externalThinWallType,single_extrusions ; internalThinWallType,gap_fill ; thinWallAllowedOverlapPercentage,10 ; singleExtrusionMinLength,0.20000 ; singleExtrusionMinWidthPercentage,50 ; singleExtrusionMaxWidthPercentage,200 ; singleExtrusionEndpointExtensionDistance,0.20000 ; onlyRetractWhenCrossingOutlines,1 ; retractBetweenLayers,1 ; retractOnTopLayers,1 ; useRetractionMinTravel,0 ; retractionMinTravel,5.00000 ; useRetractionMinExtrusion,0 ; retractionMinExtrusion,3.00000 ; onlyVerticalLiftOnTopLayers,1 ; retractWhileWiping,0 ; wipingMode,outer_perimeter ; avoidCrossingOutlines,1 ; maxMovementDetourFactor,3.00000 ; openLoopSlicingBehavior,thicken ; openLoopThickenWidth,0.10000 ; slicingRegionRepairMode,positive G90 M82 G90 M82 M98 P"0:/macros/Setup/Safety_Contactor_ON" M98 P"0:/macros/Setup/StartScript" ;Select Bed Mesh ;M117 "Bed Mesh Full X260 Y290" ;M98 P"0:/macros/Bed/BedMeshFullX260Y290" ;M117 "Bed Mesh Half X130 Y145" ;M98 P"0:/macros/Bed/BedMeshHalfX130Y145" M117 "Bed Mesh Small X65 Y72.5" M98 P"0:/macros/Bed/BedMeshSmallX65Y72.5" ;M117 "Bed Mesh Ulti X150 Y130" ;M98 P"0:/macros/Bed/BedMeshUltiX150Y130" T0 ; process Process 1 ; layer 1, Z = 0.2000 T0 ; feature skirt ; tool H0.2000 W0.720 G1 X41.756 Y16.740 F9000 G1 Z0.2000 F3600 G11 G92 E0.00000 G1 X-41.756 Y16.740 E4.99975 F3600 G1 X-44.240 Y14.256 E5.21004 G1 X-44.240 Y-14.256 E6.91703 G1 X-41.756 Y-16.740 E7.12732 G1 X41.756 Y-16.740 E12.12707 G1 X44.240 Y-14.256 E12.33736 G1 X44.240 Y14.256 E14.04435 G1 X41.756 Y16.740 E14.25464 G10 G1 X41.458 Y16.020 F9000 G11 G92 E0.00000 G1 X-41.458 Y16.020 E4.96404 F3600 G1 X-43.520 Y13.958 E5.13862 G1 X-43.520 Y-13.958 E6.80990 G1 X-41.458 Y-16.020 E6.98448 G1 X41.458 Y-16.020 E11.94852 G1 X43.520 Y-13.958 E12.12310 G1 X43.520 Y13.958 E13.79439 G1 X41.458 Y16.020 E13.96897 G10 G1 X41.160 Y15.300 F9000 G11 G92 E0.00000
I've also noticed I'm not getting the full information when selecting the file on the 7" PanelDue. Layer Height, Sliced By, etc
heres the end code
G10 ; layer end M98 P"0:/macros/Setup/Safety_Contactor_OFF" M98 P"0:/macros/Setup/EndScript" ; Build Summary ; Build Time: 4 hours 45 minutes ; Filament length: 58879.2 mm (58.88 m) ; Material Volume: 141621.0 mm^3 (141.62 cc) ; Material Weight: 172.78 g (0.38 lb) ; Material Cost: 8.98
@SJI still can't see anything there either. Do you have anything in
tpre0.g
ortpost.g
Might be better starting a new thread about not being able to get the full file information on the paneldue -
@jay_s_uk
Just did a diagnostic on the toolboard whilst it's still runningM122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.4.4 (2022-10-14 11:46:33) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2648, free system stack 45 words Tasks: Move(notifyWait,0.5%,91) HEAT(notifyWait,0.9%,75) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.1%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,6.1%,57) MAIN(running,82.3%,351) IDLE(ready,0.0%,26) AIN(delaying,10.0%,142), total 100.0% Last reset 03:09:29 ago, cause: power up Last software reset data not available Driver 0: pos 12140682, 412.0 steps/mm,ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 32782, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 12686994 done 12686873 Moves scheduled 66473, completed 66472, in progress 1, hiccups 0, step errors 0, maxPrep 656, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0 Peak sync jitter -2/4, peak Rx sync delay 231, resyncs 0/0, next step interrupt due in 218 ticks, enabled VIN voltage: min 23.9, current 24.1, max 24.2 MCU temperature: min 38.6C, current 54.8C, max 56.2C Last sensors broadcast 0x00000002 found 1 109 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 227681, send timeouts 0, received 169009, lost 0, free buffers 37, min 35, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 658, adv 32902/74661 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
I'll look into the panel due issue
My actual chamber temp is 31 degrees and I can't see anything out of the ordinary on the 1LC -
; tpre0.g ; called before tool 0 is selected ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 27 2021 10:10:40 GMT+1100 (Australian Eastern Daylight Time)
; tpost0.g ; called after tool 0 has been selected ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 27 2021 10:10:41 GMT+1100 (Australian Eastern Daylight Time) ; Wait for set temperatures to be reached M116 P0
@SJI nothing there either in which case i'm stumped
@SJI said in Error:Failed to activate input monitor on pin 255:
The message could be coming from trying to activate the X endstop. Does the X endstop work?
@jay_s_uk
Nothing like a good challenge -
Yes end stops working correctly.
They are optical endstops
X endstop is Min
Y endstop is Min -
@SJI In config.g you have:
; Z-Probe ; Pushed to macro's M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^20.io0.in" H20 F500 T12000 ; set Z probe type to bltouch and the dive height + speeds
In /macros/BLTouch/Probesettings.g you have:
The probe is being created in config.g (perhaps it should be commented out here?), then you're cancelling the assignment in the macro ( though this possibly is not working, as I think this should be just
M574 Z0 P"nil"
), then recreating it. I think some part of this isn't working.What happens if you turn on the machine, then run
? Do you get the same message?Ian
@droftarts
You are a champion. I didn't even see that error in the probesettings.g
