    Printer freezes after pruge-line, then restarts
    • Velviaundefined
      Velvia
      M122
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 08DJM-9P63L-DJ3S0-7JKF0-3S86T-TAJR8
      Used output buffers: 3 of 40 (22 max)
      Static ram: 152760
      Dynamic ram: 65564 of which 156 recycled
      Never used RAM 131712, free system stack 142 words
      Tasks: SBC(ready,0.6%,468) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,256) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,333) TMC(notifyWait,8.1%,57) MAIN(running,91.0%,1197) IDLE(ready,0.3%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:03:45 ago, cause: software
      Last software reset at 2023-07-14 20:23, reason: User, Platform spinning, available RAM 132192, slot 2
      Software reset code 0x0000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 133
      MCU temperature: min 33.3, current 33.4, max 44.8
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 78, reads 10531, writes 21 timeouts 0
      Driver 1: standstill, SG min 0, mspos 102, reads 10531, writes 21 timeouts 0
      Driver 2: standstill, SG min 0, mspos 290, reads 10531, writes 21 timeouts 0
      Driver 3: standstill, SG min 0, mspos 24, reads 10538, writes 15 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 10542, writes 11 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 10542, writes 11 timeouts 0
      Date/time: 2023-07-14 20:27:42
      Slowest loop: 56.78ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 20, maxWait 92585ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 8, completed 8, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 2022, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 1130/0/0
      Tx timeouts 0,0,1129,0,0,891 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 9291/9291
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad48
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.1
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 41.44, max time between full transfers: 56.4ms, max pin wait times: 31.4ms/12.1ms
      Codes per second: 0.37
      Maximum length of RX/TX data transfers: 3080/992
      Identical gcode from one day ago works fine. Only difference now is that I updated Prusa to 2.6.0. Otherwise everything is the same.
      gcode
      ; generated by PrusaSlicer 2.6.0+win64 on 2023-07-14 at 17:00:12 UTC
      ; external perimeters extrusion width = 0.80mm
      ; perimeters extrusion width = 0.80mm
      ; infill extrusion width = 1.00mm
      ; solid infill extrusion width = 0.80mm
      ; top infill extrusion width = 0.80mm
      ; support material extrusion width = 0.80mm
      ; first layer extrusion width = 0.80mm
      M201 X10000 Y10000 Z1500 E9000 ; sets maximum accelerations, mm/sec^2
      M203 X12000 Y12000 Z4800 E7200 ; sets maximum feedrates, mm / min
      M204 P8000 T12000 ; sets acceleration (P, T), mm/sec^2
      M566 X600.00 Y600.00 Z60.00 E420.00 ; sets the jerk limits, mm/min
      ;TYPE:Custom
      T0 ; Select tool 0
      G28 ; home all axes
      G92 E0.0
      M104 S200                           ; preheat extruder to no ooze temp                           ; wait for extruder temp
      M140 S75 ; set bed temp
      M109 S200                           ; wait for extruder temp
      M400
      M564 H1 S0                          ; allow movement outside print area (S0) of all homed axes (H1)
      M400
      G1 X189.5 Y-83.0 Z20.00 F4000       ; wipe nozzle over brass brush
      G1 X189.5 Y-83.0 Z14.00
      G1 X177.0 Y-90.0 Z14.00 F3000
      G1 X179.5 Y-80.0 Z13.00
      G1 X189.5 Y-83.0 Z13.00
      G1 X191.5 Y-69.0 Z14.00
      G1 X191.5 Y-69.0 Z13.00
      M190 S75 ; wait for bed temp
      M400
      G1 X177.0 Y-90.0 Z13.00
      M400                           ; wait for previous action to finish
      G1 X0 Y0 Z13 F4000             ; move to middle of bed to probe
      M400
      M564 S1                        ; restrict movement outside print area
      M400
      G1 Z9 F8000                    ; move to 9mm above bed to probe
      M400                           ; wait
      G30 F2000                          ; probe middle of bed to establish Z0 to avoid babystepping every time
      M400                               ; wait
      G1 X164 Y38 Z5 F8000               ; set nozzle above bed
      M400                               ; wait
      G1 G30 S-1 F1200                   ; set nozzle into bed to prevent oozing
      M104 S250    ; set extruder temp
      M109 S250    ; wait for extruder temp
      M400
      G1 z0.4                            ; set nozzle 0.3mm aboe bed to purge
      G1 X122.6 Y118.6 E30 F800          ; purge intro line
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M82 ; use absolute distances for extrusion
      G92 E0
      M572 D0 S0.20               ; pressure advance
      M579 X0.9978 Y0.0.9902 Z1       ; X, Y and Z scaling
      G29 S1 P"heightmap70.csv"     ; S1 = load specific heightmap
      M107
      ;LAYER_CHANGE
      ;Z:0.3
      ;HEIGHT:0.3
      G1 E-3 F3600
      G92 E0
      G1 Z.5 F12000
      G1 X.003 Y-73.992
      G1 Z.3
      G1 E3 F3600
      M204 P3000
      ;TYPE:Skirt/Brim
      ;WIDTH:0.8
      G1 F2400
      G1 X75.528 Y-73.988 E9.92946
      Homegrown, grass fed and organically built 350mm delta
      • deckingmanundefined
        deckingman @Velvia
        @Velvia said in Printer freezes after pruge-line, then restarts:
        Just after your purge line you have this.........
        I'm wondering if the two decimal points for Y is what is screwing things up. I guess it should be M579 X0.9978 Y0.9902 Z1 so try changing that to see if it helps.
        Velviaundefined 2 Replies Last reply Reply Quote 2
        • Velviaundefined
          Velvia @deckingman
          @deckingman Didn't catch that! Will change. Thanks!
          • Velviaundefined
            Velvia @deckingman
            @deckingman That was the issue. Huge thanks!
