calabrate
hi all so sorry to be hear again but have a problem
when i make a sq, with carveco software my cnc will only draw one line and then go down through the job can you check my config .g att,hear; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Jul 24 2023 12:35:53 GMT+0100 (British Summer Time); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.1 S1
M569 p0.2 s1 ; physical drive 0.1 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1:0.2 Z0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
M574 Z2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io3.in; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid -
@o_lampe thank you that’s seams to have changed things
