Connection interrupted, HTTP request timed out
I am getting a "Connection interrupted, attempting to reconnect...
HTTP request timed out" on some files I try to print. current file that is giving me issue is 704.6 kb
Ran file from same software 14.3 mb file loads and prints great still does but try to load new file and times out.
I have power cycled and re boot everything .
regenerated and loaded file. What else can I try?Files are generated by Simplify3D vers. 4.1.2 also tried 5.1.1
I am running ;
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
Duet WiFi Server Version: 1.26,
Duet Web Control 3.3.0 -
Please try copying the contents of your SD card to a new fresh card and see if that solves the problem.
@Phaedrux I don't have a spare SD card. Do you recommend a particular brand, size and / or quality SD card to buy?
A Samsung or SanDisk brand up to 64GB.
Something like this: https://www.amazon.ca/Samsung-microSD-Class-Memory-Adapter/dp/B09FFFSH25/ref=sr_1_16?crid=12DKJH5ZLJYCS&keywords=samsung+sd+card&qid=1690476037&sprefix=samsung+sd+car%2Caps%2C122&sr=8-16
@Phaedrux I installed new reformatted SD card. still loses connection. on some files it does it immediately on other 15 -20 minutes into print.
8/8/2023, 4:15:25 PM m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S4-6JKFA-3SD6L-KV1AL
Used output buffers: 3 of 24 (20 max)
Static ram: 23876
Dynamic ram: 75704 of which 20 recycled
Never used RAM 14816, free system stack 176 words
Tasks: NETWORK(ready,13.9%,244) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,364) MAIN(running,85.9%,433) IDLE(ready,0.1%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:18:09 ago, cause: power up
Last software reset at 2023-08-01 15:28, reason: TerminateCalled, GCodes spinning, available RAM 14640, slot 1
Software reset code 0x4183 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20002078 Task MAIN Freestk 591 ok
Stack: 0000002b 0045c607 00000000 20018540 20002430 0045ca37 00000000 0045c389 200020c8 0043d923 20002118 00000000 20018540 00000000 20002314 00000001 00000000 00461e7f 20002118 00000000 20018540 00461e7f 0047ae94 20018540 0043d921 20002314 ffffffff
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 40.9, current 41.3, max 45.2
Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2023-08-08 16:15:23
Slowest loop: 8.48ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.43ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 24:a1:60:2e:ac:cf
WiFi Vcc 3.44, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26984
WiFi IP address 192.168.1.116
WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
8/8/2023, 3:57:22 PM Connection established
8/8/2023, 3:57:21 PM Connection interrupted, attempting to reconnect...
- WiFi -
Can you please try updating our firmware by uploading this zip file to your system tab in DWC?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
@Phaedrux
I downloaded files into DWC. It asks to install. I click yes, it starts to install then loses connection. My Wi-Fi antenna is only about 8' away if that matters.
Is there a way to connect Ethernet cable to Duet2 Wi-fi board to eliminate that Wi-Fi signal as issue? Can I use laptop and USB cable to update firmware? -
@airflair said in Connection interrupted, HTTP request timed out:
No.
Yes, there are a few ways.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
First, though, can you connect to the wifi after a power cycle now?
If not, can you connect via USB and use YAT to send some commands to get the status of the board? Send M122 and copy and paste the results here. That will let us know if the firmware installed or not.
The next thing to try would be to test the wifi module in access point mode where it creates a network and you connect your computer to that network, bypassing your own wifi router. It the connection works well that way we know the issue is with the wifi router or the module itself.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
