Is Input Shaper not working or what's causing ringing?
@oliof Thank you. Maybe you know why I can not complete the measurement? I can perform a movement but nothing happens next
@Arminas first step would be to check whether the file was generated or not.
@oliof already found the issue. It works well with DWC 3.5 version. (mine was 3.4.6).
Although, I think I have another problem, but as I understand it should be solved.. Looks like Input shaper is not applied for Y axis, which is connected to duex expansion board. Is it possible that IS only works with mainboard?
@Arminas theres no limitation regarding duex as its basically part of the mainboard
