    Problem with Panel DUE
    PanelDue
    394
    • Makergal3Dundefined
      Makergal3D
      I'm back with this problem, at first my panel due was working fine. I don't know when but suddendly it start to say connecting.
      I try to update de firmare, install the old cable, the one it came with the Panel Due, I made a new one guiding myself for the one that came with the duet. But its imposible to get connection between the duet and the board.
      In the config.g and in the panel it self I have the baudrate set to 57600
      Just figure out something now, the panel due connect only if I home XYZ other wise will not show info in the screen.
      In the config is on the very top of the file just in case.
      Thanks in advance
        Makergal3D @Makergal3D
        @Makergal3D I think the ribbon cable was not properly attach to the panel due 🤦
        You can close it
        Sorry
          What firmware version on the PanelDue and Duet?
          Which Duet board?
          How do you have it wired? ribbon or 4 wire?
          Does the wiring run near motor or endstop cables?
            Makergal3D
            I just install today the last version avaliable in github.
            I got a duet 6xd
            Ribbon cable
            And about the placement I try to moved away from other cables, but is the same only show things if I make homing, without homing no info in the screen
              So duet firmware 3.4.6 and paneldue 3.5 rc3?
              Have you tried using the 4wire cable option?
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue
              Makergal3Dundefined 1 Reply Last reply Reply Quote 0
                Makergal3D @Phaedrux
                @Phaedrux the RC6 for the panel Due, but yes, both updated to the lasts firmwares.
                I didn't try to connect with the other method, but the weird thing to me, is that shows info only after homing, previous to homing no data in the screen
                  Can you test by disconnecting the endstops entirely and see if it works correctly?
                    @Phaedrux disconecting the enstop didn,t work. If I connect the screen with the 4 cables, I need to add something to the config I suppose, right??
                    If there is nothing to config, with the 4 cables doesn't work either
                      Which Duet board are you using?
                      Did you review the connection guide?
                        @Phaedrux I'm using a Duet 3 6XD and a 1 XD expansion board.
                        Yes of course I did read the user manual. But I can not make the screen to work properly.
                        As I said with the ribbon cable doesn't show info.
                        With the 4 cable connector also not info.
                        With the original cable the panel due came in, nothing either.
                        I don't know what else to do. But the screen is not working, and from time to time it start working.
                        I though it was after homing but further testing shows that is not related with the homing
                          You can close it
                          Sorry
                          • droftartsundefined droftarts marked this topic as a question
                          • droftartsundefined droftarts has marked this topic as solved
