DSF drops wifi and starts to pause/print after a while
Does anyone else have issues like that?
it starts fine and prints well for a while.
After some time it drops HTTPS (timedout) and starts to pause the print for few seconds and the continues again.
It is running on Pi4 with 3.5.0 beta 4 -
@Aurimas you may want to provide more information, such as DSF logs and M122 output as well as the actual error messages you are seeing
@jay_s_uk There are no errors.
Can I save M122 somehoe to the memory? Otherwise any current M122 log will be wiped out when I restart the board since I have no access from the browser
I can send the commends from the screen and it reports fine.
No errors on the screen and M122 is not reporting any errors either.
MCU is below 30C -
@Aurimas you can get the M122 output using a USB connection to your board
@jay_s_uk I don't have access to the USB right now - would have to ull printer apart
@Aurimas if its the pi dropping the connection, thats something thats handled by linux anyway and not RRF (or DSF) so you'll have to investigate that more using general linux information.
If its something along the lines of transfer ready pin issues then that is an RRF issue, but without basic error information its all just guess work -
@jay_s_uk said in DSF drops wifi and starts to pause/print after a while:
I understand that it is difficult to say, but how to get any info out of it? M122 is not reporting any errors
@Aurimas if the print pauses then there will definitely be a reason or something recorded.
you can useM122 "DSF"
to get some extra data
you can also get logs directly from DSF https://forum.duet3d.com/post/314758
