Solved Thermistor Semitec 104nt config problem
Hi everybody
I am using a Duet 2 Ethernet to control a custom extruder.
At this stage I do not need any axis or extruding control just Heating and Temperature reading/controlI took heater cartridge and thermistor from a E3D TITAN AERO KIT
according to E3D website the themistor should be a Semitec 104NTAfter configuring firmware accessing webinterface I get a temperature of -273.1 for tool 0
my cfg is set like this:
M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H0 S500 ; set temperature limit for heater 0 to 500C; Tool 0
M563 P0 D0 H0 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CI am pretty sure that everything is wired correctly and I searchd for similar topic on this forum
like this one link text
but even trying to use different parameters combination my temperature reading is alway -273.1 °Ccan anyone help me?
Thanks a lot, best regards -
@Branzo Ok little update, i changed config like this
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8
and I get a temperature value
is it a problem of pin name?
are stil e0temp and e1temp valid pin names?may be a hardware problem on the board? how to check it?
@Branzo all of those pin names are valid. post a photo to show where you've wired it to
@Branzo said in Thermistor Semitec 104nt config problem:
M143 H0 S500 ; set temperature limit for heater 0 to 500Cif you declared S0 and H0 has the heated bed, need to declare S1 and H1 as the heater
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 A"Nozzle E0" R4700 ; E3d configure sensor 0 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 2 M143 H1 S285 A2 ; disable temporarily H1 if temp exceeds 285C M143 H1 S295 A0 ; heater fault H1 if temp exceeds 295C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M570 H1 P10 T30 ; heater fault for 10 seg of 30ºC excursion
@jay_s_uk I go to bury myself deep underground
checking wiring I have found out I was looking the board upsidedown and I wired the heaters to "always on fans" pin
I feel ashamedso sorry guys now everything seems working
