    First manual extruder move at full speed.
    • danharcombeundefined
      danharcombe
      When I reboot my machine I have noticed that the first extruder move (manual or through paneldue) is at full speed. I have searched the forum but cant find anyting on it. It might just be this firmware as only recently noticed it.
      Firmware v 3.4.1
      anyone else had this?
        Phaedrux Moderator @danharcombe
        @danharcombe said in First manual extruder move at full speed.:
        is at full speed.
        What exactly do you mean by this? Faster than the selected feed rate?
        Firmware v 3.4.1
        Can you update to 3.4.6 and see if you experience the same thing?
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
          danharcombe
          yes faster than the selected rate for the first manual move through the paneldue or DWC.
          normally i do a manual prime if I need to check things but if it goes flat out it strips the filament.
          I will try a firmware update but I had downgraded as I was trying to diagnose some other issues.
            danharcombe
            was fixed in 3.42
            Under certain conditions an extrusion-only move was executed at maximum speed instead of the requested speed
