    Duet 2 Ethernet disconnect when printing and paneldue connected
    PanelDue
    2.3k
    • Shokiundefined
      Shoki
      Hi everyone,
      I have a weird issue with my E3D Toolchanger that has a Duet 2 ethernet and a Duex5.
      It disconnects every 30 seconds or so from the web interface, but only when printing. It does not stop the print, it's just very annoying.
      • I tried to connect it to a different computer, same problem.
      • I tried with a different ethernet cable, same problem.
      • I tried to print a large square in vase mode (very few gcode commands and very long so not much communication with the SD cards), same problem.
      • I copied all the commands from this file into a macro : same problem.
      • I wrote a macro that power all 4 tools, the bed, all fans and move the X and Y axis around so that I have a heavy load on the power supply : no problem at all.
      I have installed the latest duet release candidate 3.5.0 rc1.
      I absolutely need this new version for the gcode meta commands it introduced (loops and variables). I have pretty much the same config on a different toolchanger but with a Duet3, and it does not have the problem at all.
      How would I go about figuring out the source of the problem and solving it ?
        Phaedrux Moderator @Shoki
        @Shoki said in Duet 2 Ethernet disconnect when printing:
        Did this only start when you moved to 3.5 RC1?
        Does it not happen on older firmware?
        When you get a disconnect can you gather a M122 report via usb and share it here?
        Shokiundefined 2 Replies Last reply Reply Quote 0
        • Shokiundefined
          Shoki @Phaedrux
          @Phaedrux
          It was working fine when I had the version that was originally installed. I don't remember which one it was, sorry.
          I could try revert back to older version to see if it makes a difference (next week).
          I think it started happening when I switch to the 3.5 beta. But I was very busy at the time and did not have time to diagnose it and verify it wasn't a hardware problem.
          • Shokiundefined
            Shoki @Phaedrux
            @Phaedrux Sorry it took me so long to answer.
            I tried with version 3.3 which use to work fine and I still have the problem.
            I have download the diagnostics both for the 3.5RC1 and for the 3.3.0.
            Please let me know if you see something unusual here.
            I see the error 0x04 Output buffer starvation. What is it ?
            I'm open to any idea that could help me diagnose the problem.
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.1 (2023-08-31 16:16:15) running on Duet Ethernet 1.02 or later + DueX5v0.11
            Board ID: 0JD0M-9X6JA-JUNSW-6JTD0-3S46P-TBL7V
            Used output buffers: 4 of 26 (26 max)
            Static ram: 23076
            Dynamic ram: 75504 of which 0 recycled
            Never used RAM 11108, free system stack 126 words
            Tasks: NETWORK(1,ready,95.5%,180) HEAT(3,nWait,2.2%,287) Move(4,nWait,3.9%,261) DUEX(5,nWait,0.0%,26) MAIN(1,running,129.0%,619) IDLE(0,ready,0.2%,29), total 230.8%
            Owned mutexes:
            Last reset 20:03:42 ago, cause: software
            Last software reset at 2023-10-18 18:09, reason: User, Gcodes spinning, available RAM 11284, slot 0
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU temperature: min 34.8, current 38.7, max 44.5
            Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1344/936, gc cycles 0
            Events: 2 queued, 2 completed
            Driver 0: standstill, SG min 0
            Driver 1: standstill, SG min 0
            Driver 2: standstill, SG min 0
            Driver 3: standstill, SG min 0
            Driver 4: standstill, SG min 0
            Driver 5: standstill, SG min n/a
            Driver 6: standstill, SG min 0
            Driver 7: standstill, SG min n/a
            Driver 8: standstill, SG min 0
            Driver 9: standstill, SG min n/a
            Driver 10:
            Driver 11:
            Date/time: 2023-10-19 14:12:51
            Slowest loop: 231.49ms; fastest: 0.15ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 2.1ms, write time 25.4ms, max retries 0
            DMs created 83, segments created 25, maxWait 49576689ms, bed compensation in use: none, height map offset 0.000, ebfmin -0.52, ebfmax 1.00
            no step interrupt scheduled
            Moves shaped first try 6195, on retry 85, too short 4365, wrong shape 39, maybepossible 14
            === DDARing 0 ===
            Scheduled moves 411, completed 411, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            Heater 0 is on, I-accum = 0.3
            Movement locks held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Q0 segments left 0
            Code queue 0 is empty
            === DueX ===
            Read count 1, 0.00 reads/min
            === Network ===
            Slowest loop: 128.44ms; fastest: 0.02ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            HTTP sessions: 1 of 8
            Interface state active, link 100Mbps full duplex
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later + DueX5
            Used output buffers: 3 of 24 (24 max)
            Static ram: 23876
            Dynamic ram: 74400 of which 0 recycled
            Never used RAM 13284, free system stack 118 words
            Tasks: NETWORK(ready,24.7%,227) HEAT(delaying,0.1%,330) Move(notifyWait,0.2%,313) DUEX(notifyWait,0.0%,24) MAIN(running,75.1%,441) IDLE(ready,0.0%,29), total 100.0%
            Owned mutexes:
            Last reset 00:05:05 ago, cause: software
            Last software reset at 2023-10-18 18:09, reason: User, GCodes spinning, available RAM 11284, slot 0
            Error status: 0x04
            Aux0 errors 0,0,0
            Step timer max interval 0
            MCU temperature: min 39.1, current 39.9, max 40.1
            Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/290/0, gc cycles 0
            Driver 0: position 16290, standstill, SG min/max 0/239
            Driver 1: position 6710, ok, SG min/max 0/242
            Driver 2: position 6664, standstill, SG min/max 0/180
            Driver 3: position 2855, standstill, SG min/max not available
            Driver 4: position 3641, ok, SG min/max 0/191
            Driver 5: position 0, standstill, SG min/max not available
            Driver 6: position 0, standstill, SG min/max not available
            Driver 7: position 0, standstill, SG min/max not available
            Driver 8: position 0, standstill, SG min/max not available
            Driver 9: position 0, standstill, SG min/max not available
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2023-10-19 14:20:33
            Slowest loop: 13.31ms; fastest: 0.15ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 0.5ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            Scheduled moves 329, completed moves 309, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.0
            Heater 1 is on, I-accum = 0.3
            Segments left: 1
            Movement lock held by null
            File is doing "G1 X147.681 Y85.998 E.0195" in state(s) 0
            Code queue is empty.
            === DueX ===
            Read count 0, 0.00 reads/min
            === Network ===
            Slowest loop: 16.21ms; fastest: 0.04ms
              Do you connect to DWC from multiple devices?
              Shokiundefined 1 Reply Last reply Reply Quote 0
              • Shokiundefined
                Shoki @Phaedrux
                @Phaedrux
                No. A single computer is connected to the duet.
                However, this computer is connected to multiple duet.
                  Can you open a windows command prompt and send a command to have it ping the duet continuously while you do a print?
                  ping -t 93.184.216.34
                  Where you insert the IP address of the Duet.
                  If you don't want to watch it while it prints you could pipe it to a file to look at later
                  ping -t 93.184.216.34 > %username%\desktop\pings.txt
                  When the DWC disconnects do the pings fail as well?
                  • Shokiundefined
                    Shoki @Phaedrux
                    The ping does not seem to fail. I have watched it for a full 15 minutes print and the higher it got was 10ms. And there was quite a few disconnection.
                    This image was taken 4-5 seconds after the last disconnection.
                    @Phaedrux It does not seem to fail much :
                    Also, the frequency seems to depend on the gcode I print. Yesterday I was printing a retraction calibration test with firmware retraction to tune it live. The disconnections were so frequent I barely had the time to send the command to change the retraction value.
                    • Shokiundefined
                      Shoki @Shoki
                      I just tried to replace the Duet with a brand new one that I had and the problem is still there.
                      I also tried to replace the SD card with a formated one.
                      Do you think the problem might come from the Duex5 ? I also have one of these that I can swap.
                      This is my config.g for reference :
                      ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
                      ;  General preferences
                      M111 S0 				; Debugging off
                      G21 					; Work in millimetres
                      G90 					; Send absolute coordinates...
                      M83 					; ...but relative extruder moves
                      M555 P2 				; Set firmware compatibility to look like Marlin
                      M669 K1 				; Select CoreXY mode
                      ;        Network
                      M550 P"ToolChanger" 	; Set machine name
                      M553 P*****     ; Ethernet Settings - Mask
                      M554 P*****     ; Ethernet Settings - Passerelle
                      M552 P*****      ; Ethernet Settings - Adresse
                      M552 S1					; Enable Networking
                      M586 P0 S1 				; Enable HTTP
                      M586 P1 S0 				; Disable FTP
                      M586 P2 S0 				; Disable Telnet
                      ;         Drive
                      ;Drive directions
                      M569 P0 S0 											; Drive 0 (X)
                      M569 P1 S0 											; Drive 1 (Y)
                      M569 P2 S1 											; Drive 2 (Z)
                      M569 P3 S0 											; Drive 3 (C)
                      M569 P4 S0 											; Drive 4 (E0)
                      M569 P5 S0 											; Drive 5 (E3)
                      M569 P6 S0											; Drive 6 (E2)
                      M569 P7 S0 											; Drive 7 (E1)
                      M569 P8 S1 											; Drive 8 (W)
                      M569 P9 S0 											; Drive 9 UNUSED Future 5 axes
                      ;Drive mapping and control
                      M584 X0 Y1 Z2 C3 W8 E4:7:6:5 						; Stepper motor connection points, see C:\Users\YN14386\Documents\Documentation\Toolchanger for wiring diagram
                      M208 X-25:338.5 Y-49:243 Z-0.2:300 C-45:360 W-3:65 	; Set axis maxima & minima
                      M92  X100 Y100 Z800 C91.022 W360 E392:392:392:392	; Set steps per mm assuming x16 microstepping
                      M350 X16 Y16 Z16 I1									; Configure microstepping with interpolation for the extruders
                      M350 E16:16:16:16 I1 								; Configure microstepping with interpolation for the XYZ movements
                      M350 C16 I1  										; Configure microstepping with interpolation for the coupler
                      M350 W16 I1											; Configure microstepping with interpolation for the pebble wiper
                      ;Drive speeds and acceleration
                      M203 X35000 Y35000 Z1200 C5000 W2400 E5000:5000:5000:5000	; Set maximum speeds (mm/min)
                      M201 X2000 Y2000 Z400 C500 W800 E2500:2500:2500:2500		; Set maximum accelerations (mm/s^2) was X6000 Y6000
                      M566 X300 Y300 Z20 C2 W100 E400:400:400:400					; Set the jerk : maximum instantaneous speed changes  (mm/min)
                      ; reset this to 400 400
                      ; Motor current
                      M906 X1800 Y1800 Z1330 I30   						; Idle motion motors to 30%
                      M906 E1000:1000:1000:1000 C500 I10     				; Idle extruder and cooupler motors to 10%
                      M906 W600 I20										; Idle pebble wiper to 20%
                      ;        Endstops
                      ;X and Y axis
                      M574 X1 Y1 S3 					; Set X / Y endstop stall detection
                      M915 X Y S3 F0 H400 R1   		; Stall Detection for the X and Y Axes ;
                      ; Coupler Axis
                      M574 C0 Z0  				    ; No C Z endstop, it just crashes
                      ;P axis
                      M574 W1 S3 						; Set W endstop stall detection
                      ;Z axis
                      M558 P8 C"zstop" H3 F360 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                      G31 P200 X0 Y0 Z0	 				; Set Z probe trigger value, offset and trigger height
                      M557 X10:290 Y20:180 S40 			; Define mesh grid
                      ;M557 X10:290 Y20:180 S280:160		; Define mesh grid to test quickly
                      ;M376 H15							; bed compensation taper
                      ;         Heaters
                      ;see C:\Users\YN14386\Documents\Documentation\Toolchanger\*** for connection points names
                      ;Tool 0
                      M308 S1 P"e1temp"      Y"thermistor" A"Heater 0" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                      M950 H1 C"e1heat" T1													; Set heater number (H) and connection point (C)
                      M143 H1 S285															; Set temperature limit for heater to 285C
                      ;Tool 1
                      M308 S2 P"duex.e2temp" Y"thermistor" A"Heater 1" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                      M950 H2 C"duex.e2heat" T2												; Set heater number (H) and connection point (C)
                      M143 H2 S290															; Set temperature limit for heater to 285C
                      ;Tool 2
                      M308 S3 P"duex.e3temp" Y"thermistor" A"Heater 2" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                      M950 H3 C"duex.e3heat" T3												; Set heater number (H) and connection point (C)
                      M143 H3 S285 															; Set temperature limit for heater to 285C
                      ;Tool 3
                      M308 S4 P"duex.e4temp" Y"thermistor" A"Heater 3" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                      M950 H4 C"duex.e4heat" T4												; Set heater number (H) and connection point (C)
                      M143 H4 S285 															; Set temperature limit for heater to 285C
                      ;Heated bed
                      M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 				; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                      M950 H0 C"bedheat" T0													; Set heater number (H) and connection point (C)
                      M143 H0 S115 															; Set temperature limit for bed heater to 110C
                      M140 H0																	; Bed heater is heater 4
                      ;        Fans
                      ;Tool 0
                      M950 F4 C"fan1"					; Set hotend fan number (F) and connection point (C)
                      M106 P4 S255 H1 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
                      M950 F0 C"fan2"					; Part cooling fan connection point
                      M106 P0 S0 C"Tool 0"			; Turn off the part cooling fan.
                      ;Tool 1
                      M950 F5 C"duex.fan3"			; Set hotend fan number (F) and connection point (C)
                      M106 P5 S255 H2 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
                      M950 F1 C"duex.fan4"			; Part cooling fan connection point
                      M106 P1 S0 C"Tool 1"			; Turn off the part cooling fan.
                      ;Tool 2
                      M950 F6 C"duex.fan5"			; Set hotend fan number (F) and connection point (C)
                      M106 P6 S255 H3 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
                      M950 F2 C"duex.fan6"			; Part cooling fan connection point
                      M106 P2 S0 C"Tool 2"			; Turn off the part cooling fan.
                      ;Tool 3
                      M950 F7 C"duex.fan7"			; Set hotend fan number (F) and connection point (C)
                      M106 P7 S255 H4 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
                      M950 F3 C"duex.fan8"			; Part cooling fan connection point
                      M106 P3 S0 C"Tool 3"			; Turn off the part cooling fan.
                      ;         Tools
                      ;Tool 0
                      M563 P0 S"Tool 0" D0 H1 F0 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                      G10 P0 X0 Y0 Z0 						; Reset tool axis offsets
                      G10 P0 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                      ;Tool 1
                      M563 P1 S"Tool 1" D1 H2 F1 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                      G10 P1 X0 Y0 Z0 						; Reset tool axis offsets
                      G10 P1 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                      ;Tool 2
                      M563 P2 S"Tool 2" D2 H3 F2 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                      G10 P2 X0 Y0 Z0 						; Reset tool axis offsets
                      G10 P2 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                      ;Tool 3
                      M563 P3 S"Tool 3" D3 H4 F3 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                      G10 P3 X0 Y0 Z0 						; Reset tool axis offsets
                      G10 P3 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                      ;       PID tune
                      ; run M303 T0 S230 with the tool you want to autotune (T) and the target temperature (S)
                      ; for the bed, run M303 H4 S80 with the target temperature (S)
                      ;Tool 0
                      M307 H1 R4.405 K0.459:0.607 D1.76 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                      ;Tool 1
                      M307 H2 R4.395 K0.424:0.670 D1.72 E1.35 S1.00 B0 V24.3
                      ;Tool 2
                      M307 H3 R4.902 K0.455:0.686 D1.64 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                      ;Tool 3
                      M307 H4 R5.197 K0.520:0.759 D1.42 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                      ;Bed
                      M307 H0 R1.286 K0.265:0.000 D3.49 E1.35 S1.00 B0 ; PID parameter for the bed heater (H) for magnetic + PEI
                      ;     tool offsets
                      ; !ESTIMATED! offsets for:
                      ; V6-tool: X-9 Y39 Z-5
                      ; Volcano-tool: X-9 Y39 Z-13.5
                      ; Hemera-tool: X20 Y43.5 Z-6
                      global xmicroscope = 338.4  ;
                      global ymicroscope = 98.3   ;
                      ; for the XY calibration, major divisions are 0.1 mm and minor are 0.05 mm
                      ;G1 X336.8  Y99.5 F6000
                      ;G10 P0 X20.00 Y43.50				    ; Tool 0 is the reference
                      ;G10 P1 X19.65 Y43.55					; Tool 1 was Y 43.25
                      ;G10 P2 X19.70 Y43.60        			; Tool 2 was X 19.55 Y 43.50
                      ;G10 P3 X19.75 Y43.45        			; Tool 3 was Y 43.30
                      ; X and Y offsets are set in the toolXYoffset files
                      M98 P"0:/sys/toolXYoffset0.g"
                      M98 P"0:/sys/toolXYoffset1.g"
                      M98 P"0:/sys/toolXYoffset2.g"
                      M98 P"0:/sys/toolXYoffset3.g"
                      ; Z (and W) offsets are set in the toolZoffset files
                      M98 P"0:/sys/toolZoffset0.g"
                      M98 P"0:/sys/toolZoffset1.g"
                      M98 P"0:/sys/toolZoffset2.g"
                      M98 P"0:/sys/toolZoffset3.g"
                      ;    Pressure advance
                      ;Default pressure advance for PLA, different values should be set in the slicer
                      M572 D0 S0.025 						; pressure advance T0
                      M572 D1 S0.025 						; pressure advance T1
                      M572 D2 S0.025 						; pressure advance T2
                      M572 D3 S0.025 						; pressure advance T3
                      ;         Others
                      M593 F42.2						; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                      ; Pebble wiper servo motor
                      M950 S0 C"duex.pwm5" Q500
                      M575 P1 S1 B57600				; Enable LCD
                      G29 S2							; disable mesh
                      T-1								; deselect tools
                      ;*******Macro parameters*******
                      global homingSpeed = 4800
                      global movementSpeed = 18000
                      global zmovementSpeed = 900
                      global centerX = 155
                      global centerY = 100
                      global backX = 155
                      global backY = 210
                      global centerProbeX  = {global.centerX - sensors.probes[0].offsets[0]}
                      global centerProbeY  = {global.centerY - sensors.probes[0].offsets[1]}
                      global toolSafeY     = 150
                      global notoolSafeY   = 210
                      global toolapproachY = 217
                      global tool0X = -3.4
                      global tool0Y = 227.0
                      global tool1X = 87.2
                      global tool1Y = 227.2
                      global tool2X = 221.8
                      global tool2Y = 227.9
                      global tool3X = 312.4
                      global tool3Y = 227.9
                      I just found this post :
                      https://forum.duet3d.com/topic/30481/duet2-wifi-frequently-disconnects-when-paneldue-7i-is-connected/18
                      Might be my problem ! Will try to disconnect paneldue to see.
                      • Shokiundefined
                        Shoki @Shoki
                        @Shoki Disconnecting the PanelDue entirely fix the issue ! Not a single disconnection problem during a 1 hour print.
                        I tried to swap the PanelDue with one from another machine and the problem still appeared. I also tried to switch the cable with a new shielded one and no difference. The cable does not go near any motor or anything.
                        When the PanelDue is in the "Settings" window, the problem does not appear.
                        The guy in the post above had the problem with his Jubilee 3D Printer. Maybe this is software related to having multiple tool displayed on the 1LC ?
                        Can i do something to fix the issue and still use a PanelDue or do I just have to live without it ?
                          That's very interesting. What firmware version is on the PanelDue? Which paneldue hardware version is it?
                          • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
                          • Shokiundefined
                            Shoki @Phaedrux
                            @Phaedrux
                            This is a Panel Due 7i that I bought directly from you last year. Do you need more than this information ? Cant seem to find a version or serial number on the display.
                            The firmware on the 7i has been updated recently, but I already has the problem before.
                            It is curently version 3.5.0-rc6-7.0i.
                              Thanks for the info. 7i is the hardware version.
                              Can you gather another M122 report after having this issue happen?
                              • Shokiundefined
                                Shoki @Phaedrux
                                @Phaedrux The M122 I show above are sent directly after an error.
                                  @Shoki said in Duet 2 Ethernet disconnect when printing and paneldue connected:
                                  Are they after a reboot though?
                                  Can you get the fault to happen, then switch PD to the setup screen so that DWC can connect, then run M122?
                                  • Shokiundefined
                                    Shoki @Phaedrux
                                    @Phaedrux Not after a reboot of the Duet. Just when I can have access back to the DWC.
                                    As I said, while this happen, the printer is printing and continuing like nothing happened.
                                    The thing is, I don't need to switch to the setup screen to get the DWC to connect back, it comes back on its own after 3-5 seconds.
                                      Can you share the rest of your config files for your machine? Homing files, tool change, etc?
                                      • Shokiundefined
                                        Shoki @Phaedrux
                                        @Phaedrux I will download them and send them when I'm back to work on thurday !
                                        Thanks a lot for taking the time to help me figure it out.
                                        edspedundefined 1 Reply Last reply Reply Quote 0
                                        • edspedundefined
                                          edsped @Shoki
                                          @Shoki I had the exact same issue... I even went so far as to switch from a Duet2 Wifi to a Duet3, I'm happy I did but it did not solve the issue. I ultimately thought the PanelDue was faulty then I decided to keep trying. I erased the firmware on the paneldue several times then updated it to the latest firmware over USB using Bossa per instructions and now my issue seems to be resolved. On a side note I no longer see results of G32 on the consol of the PanelDue and it shows 0.0.0.0 as the IP but at least I don't have constant wifi disconnects.
                                          See my original post here I fought this for almost a year and finally resolved within the past week.
                                          edit: one common thread is that we both run tool changers, only I'm running a Jubilee
                                          edit edit: I see you found my post... DOH...
                                          • edspedundefined
                                            edsped
                                            @Phaedrux @Shoki If there's anything I can do to help let me know... I should update my post that my problem seems to be resolved.
