    Duet 2 Ethernet disconnect when printing and paneldue connected
    PanelDue
    2.2k
    • Shokiundefined
      Shoki @Phaedrux
      @Phaedrux
      No. A single computer is connected to the duet.
      However, this computer is connected to multiple duet.
        Can you open a windows command prompt and send a command to have it ping the duet continuously while you do a print?
        ping -t 93.184.216.34
        Where you insert the IP address of the Duet.
        If you don't want to watch it while it prints you could pipe it to a file to look at later
        ping -t 93.184.216.34 > %username%\desktop\pings.txt
        When the DWC disconnects do the pings fail as well?
        Shokiundefined 1 Reply Last reply Reply Quote 0
        • Shokiundefined
          Shoki @Phaedrux
          The ping does not seem to fail. I have watched it for a full 15 minutes print and the higher it got was 10ms. And there was quite a few disconnection.
          This image was taken 4-5 seconds after the last disconnection.
          @Phaedrux It does not seem to fail much :
          Also, the frequency seems to depend on the gcode I print. Yesterday I was printing a retraction calibration test with firmware retraction to tune it live. The disconnections were so frequent I barely had the time to send the command to change the retraction value.
          • Shokiundefined
            Shoki @Shoki
            I just tried to replace the Duet with a brand new one that I had and the problem is still there.
            I also tried to replace the SD card with a formated one.
            Do you think the problem might come from the Duex5 ? I also have one of these that I can swap.
            This is my config.g for reference :
            ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
            ;  General preferences
            M111 S0 				; Debugging off
            G21 					; Work in millimetres
            G90 					; Send absolute coordinates...
            M83 					; ...but relative extruder moves
            M555 P2 				; Set firmware compatibility to look like Marlin
            M669 K1 				; Select CoreXY mode
            ;        Network
            M550 P"ToolChanger" 	; Set machine name
            M553 P*****     ; Ethernet Settings - Mask
            M554 P*****     ; Ethernet Settings - Passerelle
            M552 P*****      ; Ethernet Settings - Adresse
            M552 S1					; Enable Networking
            M586 P0 S1 				; Enable HTTP
            M586 P1 S0 				; Disable FTP
            M586 P2 S0 				; Disable Telnet
            ;         Drive
            ;Drive directions
            M569 P0 S0 											; Drive 0 (X)
            M569 P1 S0 											; Drive 1 (Y)
            M569 P2 S1 											; Drive 2 (Z)
            M569 P3 S0 											; Drive 3 (C)
            M569 P4 S0 											; Drive 4 (E0)
            M569 P5 S0 											; Drive 5 (E3)
            M569 P6 S0											; Drive 6 (E2)
            M569 P7 S0 											; Drive 7 (E1)
            M569 P8 S1 											; Drive 8 (W)
            M569 P9 S0 											; Drive 9 UNUSED Future 5 axes
            ;Drive mapping and control
            M584 X0 Y1 Z2 C3 W8 E4:7:6:5 						; Stepper motor connection points, see C:\Users\YN14386\Documents\Documentation\Toolchanger for wiring diagram
            M208 X-25:338.5 Y-49:243 Z-0.2:300 C-45:360 W-3:65 	; Set axis maxima & minima
            M92  X100 Y100 Z800 C91.022 W360 E392:392:392:392	; Set steps per mm assuming x16 microstepping
            M350 X16 Y16 Z16 I1									; Configure microstepping with interpolation for the extruders
            M350 E16:16:16:16 I1 								; Configure microstepping with interpolation for the XYZ movements
            M350 C16 I1  										; Configure microstepping with interpolation for the coupler
            M350 W16 I1											; Configure microstepping with interpolation for the pebble wiper
            ;Drive speeds and acceleration
            M203 X35000 Y35000 Z1200 C5000 W2400 E5000:5000:5000:5000	; Set maximum speeds (mm/min)
            M201 X2000 Y2000 Z400 C500 W800 E2500:2500:2500:2500		; Set maximum accelerations (mm/s^2) was X6000 Y6000
            M566 X300 Y300 Z20 C2 W100 E400:400:400:400					; Set the jerk : maximum instantaneous speed changes  (mm/min)
            ; reset this to 400 400
            ; Motor current
            M906 X1800 Y1800 Z1330 I30   						; Idle motion motors to 30%
            M906 E1000:1000:1000:1000 C500 I10     				; Idle extruder and cooupler motors to 10%
            M906 W600 I20										; Idle pebble wiper to 20%
            ;        Endstops
            ;X and Y axis
            M574 X1 Y1 S3 					; Set X / Y endstop stall detection
            M915 X Y S3 F0 H400 R1   		; Stall Detection for the X and Y Axes ;
            ; Coupler Axis
            M574 C0 Z0  				    ; No C Z endstop, it just crashes
            ;P axis
            M574 W1 S3 						; Set W endstop stall detection
            ;Z axis
            M558 P8 C"zstop" H3 F360 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
            G31 P200 X0 Y0 Z0	 				; Set Z probe trigger value, offset and trigger height
            M557 X10:290 Y20:180 S40 			; Define mesh grid
            ;M557 X10:290 Y20:180 S280:160		; Define mesh grid to test quickly
            ;M376 H15							; bed compensation taper
            ;         Heaters
            ;see C:\Users\YN14386\Documents\Documentation\Toolchanger\*** for connection points names
            ;Tool 0
            M308 S1 P"e1temp"      Y"thermistor" A"Heater 0" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
            M950 H1 C"e1heat" T1													; Set heater number (H) and connection point (C)
            M143 H1 S285															; Set temperature limit for heater to 285C
            ;Tool 1
            M308 S2 P"duex.e2temp" Y"thermistor" A"Heater 1" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
            M950 H2 C"duex.e2heat" T2												; Set heater number (H) and connection point (C)
            M143 H2 S290															; Set temperature limit for heater to 285C
            ;Tool 2
            M308 S3 P"duex.e3temp" Y"thermistor" A"Heater 2" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
            M950 H3 C"duex.e3heat" T3												; Set heater number (H) and connection point (C)
            M143 H3 S285 															; Set temperature limit for heater to 285C
            ;Tool 3
            M308 S4 P"duex.e4temp" Y"thermistor" A"Heater 3" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
            M950 H4 C"duex.e4heat" T4												; Set heater number (H) and connection point (C)
            M143 H4 S285 															; Set temperature limit for heater to 285C
            ;Heated bed
            M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 				; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
            M950 H0 C"bedheat" T0													; Set heater number (H) and connection point (C)
            M143 H0 S115 															; Set temperature limit for bed heater to 110C
            M140 H0																	; Bed heater is heater 4
            ;        Fans
            ;Tool 0
            M950 F4 C"fan1"					; Set hotend fan number (F) and connection point (C)
            M106 P4 S255 H1 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
            M950 F0 C"fan2"					; Part cooling fan connection point
            M106 P0 S0 C"Tool 0"			; Turn off the part cooling fan.
            ;Tool 1
            M950 F5 C"duex.fan3"			; Set hotend fan number (F) and connection point (C)
            M106 P5 S255 H2 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
            M950 F1 C"duex.fan4"			; Part cooling fan connection point
            M106 P1 S0 C"Tool 1"			; Turn off the part cooling fan.
            ;Tool 2
            M950 F6 C"duex.fan5"			; Set hotend fan number (F) and connection point (C)
            M106 P6 S255 H3 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
            M950 F2 C"duex.fan6"			; Part cooling fan connection point
            M106 P2 S0 C"Tool 2"			; Turn off the part cooling fan.
            ;Tool 3
            M950 F7 C"duex.fan7"			; Set hotend fan number (F) and connection point (C)
            M106 P7 S255 H4 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
            M950 F3 C"duex.fan8"			; Part cooling fan connection point
            M106 P3 S0 C"Tool 3"			; Turn off the part cooling fan.
            ;         Tools
            ;Tool 0
            M563 P0 S"Tool 0" D0 H1 F0 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
            G10 P0 X0 Y0 Z0 						; Reset tool axis offsets
            G10 P0 R0 S0 							; Reset initial tool active and standby temperatures to 0C
            ;Tool 1
            M563 P1 S"Tool 1" D1 H2 F1 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
            G10 P1 X0 Y0 Z0 						; Reset tool axis offsets
            G10 P1 R0 S0 							; Reset initial tool active and standby temperatures to 0C
            ;Tool 2
            M563 P2 S"Tool 2" D2 H3 F2 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
            G10 P2 X0 Y0 Z0 						; Reset tool axis offsets
            G10 P2 R0 S0 							; Reset initial tool active and standby temperatures to 0C
            ;Tool 3
            M563 P3 S"Tool 3" D3 H4 F3 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
            G10 P3 X0 Y0 Z0 						; Reset tool axis offsets
            G10 P3 R0 S0 							; Reset initial tool active and standby temperatures to 0C
            ;       PID tune
            ; run M303 T0 S230 with the tool you want to autotune (T) and the target temperature (S)
            ; for the bed, run M303 H4 S80 with the target temperature (S)
            ;Tool 0
            M307 H1 R4.405 K0.459:0.607 D1.76 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
            ;Tool 1
            M307 H2 R4.395 K0.424:0.670 D1.72 E1.35 S1.00 B0 V24.3
            ;Tool 2
            M307 H3 R4.902 K0.455:0.686 D1.64 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
            ;Tool 3
            M307 H4 R5.197 K0.520:0.759 D1.42 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
            ;Bed
            M307 H0 R1.286 K0.265:0.000 D3.49 E1.35 S1.00 B0 ; PID parameter for the bed heater (H) for magnetic + PEI
            ;     tool offsets
            ; !ESTIMATED! offsets for:
            ; V6-tool: X-9 Y39 Z-5
            ; Volcano-tool: X-9 Y39 Z-13.5
            ; Hemera-tool: X20 Y43.5 Z-6
            global xmicroscope = 338.4  ;
            global ymicroscope = 98.3   ;
            ; for the XY calibration, major divisions are 0.1 mm and minor are 0.05 mm
            ;G1 X336.8  Y99.5 F6000
            ;G10 P0 X20.00 Y43.50				    ; Tool 0 is the reference
            ;G10 P1 X19.65 Y43.55					; Tool 1 was Y 43.25
            ;G10 P2 X19.70 Y43.60        			; Tool 2 was X 19.55 Y 43.50
            ;G10 P3 X19.75 Y43.45        			; Tool 3 was Y 43.30
            ; X and Y offsets are set in the toolXYoffset files
            M98 P"0:/sys/toolXYoffset0.g"
            M98 P"0:/sys/toolXYoffset1.g"
            M98 P"0:/sys/toolXYoffset2.g"
            M98 P"0:/sys/toolXYoffset3.g"
            ; Z (and W) offsets are set in the toolZoffset files
            M98 P"0:/sys/toolZoffset0.g"
            M98 P"0:/sys/toolZoffset1.g"
            M98 P"0:/sys/toolZoffset2.g"
            M98 P"0:/sys/toolZoffset3.g"
            ;    Pressure advance
            ;Default pressure advance for PLA, different values should be set in the slicer
            M572 D0 S0.025 						; pressure advance T0
            M572 D1 S0.025 						; pressure advance T1
            M572 D2 S0.025 						; pressure advance T2
            M572 D3 S0.025 						; pressure advance T3
            ;         Others
            M593 F42.2						; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
            ; Pebble wiper servo motor
            M950 S0 C"duex.pwm5" Q500
            M575 P1 S1 B57600				; Enable LCD
            G29 S2							; disable mesh
            T-1								; deselect tools
            ;*******Macro parameters*******
            global homingSpeed = 4800
            global movementSpeed = 18000
            global zmovementSpeed = 900
            global centerX = 155
            global centerY = 100
            global backX = 155
            global backY = 210
            global centerProbeX  = {global.centerX - sensors.probes[0].offsets[0]}
            global centerProbeY  = {global.centerY - sensors.probes[0].offsets[1]}
            global toolSafeY     = 150
            global notoolSafeY   = 210
            global toolapproachY = 217
            global tool0X = -3.4
            global tool0Y = 227.0
            global tool1X = 87.2
            global tool1Y = 227.2
            global tool2X = 221.8
            global tool2Y = 227.9
            global tool3X = 312.4
            global tool3Y = 227.9
            I just found this post :
            https://forum.duet3d.com/topic/30481/duet2-wifi-frequently-disconnects-when-paneldue-7i-is-connected/18
            Might be my problem ! Will try to disconnect paneldue to see.
            • Shokiundefined
              Shoki @Shoki
              @Shoki Disconnecting the PanelDue entirely fix the issue ! Not a single disconnection problem during a 1 hour print.
              I tried to swap the PanelDue with one from another machine and the problem still appeared. I also tried to switch the cable with a new shielded one and no difference. The cable does not go near any motor or anything.
              When the PanelDue is in the "Settings" window, the problem does not appear.
              The guy in the post above had the problem with his Jubilee 3D Printer. Maybe this is software related to having multiple tool displayed on the 1LC ?
              Can i do something to fix the issue and still use a PanelDue or do I just have to live without it ?
                Phaedrux Moderator @Shoki
                @Shoki said in Duet 2 Ethernet disconnect when printing:
                That's very interesting. What firmware version is on the PanelDue? Which paneldue hardware version is it?
                • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
                • Shokiundefined
                  Shoki @Phaedrux
                  @Phaedrux
                  This is a Panel Due 7i that I bought directly from you last year. Do you need more than this information ? Cant seem to find a version or serial number on the display.
                  The firmware on the 7i has been updated recently, but I already has the problem before.
                  It is curently version 3.5.0-rc6-7.0i.
                    Thanks for the info. 7i is the hardware version.
                    Can you gather another M122 report after having this issue happen?
                    • Shokiundefined
                      Shoki @Phaedrux
                      @Phaedrux The M122 I show above are sent directly after an error.
                        @Shoki said in Duet 2 Ethernet disconnect when printing and paneldue connected:
                        Are they after a reboot though?
                        Can you get the fault to happen, then switch PD to the setup screen so that DWC can connect, then run M122?
                        • Shokiundefined
                          Shoki @Phaedrux
                          @Phaedrux Not after a reboot of the Duet. Just when I can have access back to the DWC.
                          As I said, while this happen, the printer is printing and continuing like nothing happened.
                          The thing is, I don't need to switch to the setup screen to get the DWC to connect back, it comes back on its own after 3-5 seconds.
                            Can you share the rest of your config files for your machine? Homing files, tool change, etc?
                            • Shokiundefined
                              Shoki @Phaedrux
                              @Phaedrux I will download them and send them when I'm back to work on thurday !
                              Thanks a lot for taking the time to help me figure it out.
                              edspedundefined 1 Reply Last reply Reply Quote 0
                              • edspedundefined
                                edsped @Shoki
                                @Shoki I had the exact same issue... I even went so far as to switch from a Duet2 Wifi to a Duet3, I'm happy I did but it did not solve the issue. I ultimately thought the PanelDue was faulty then I decided to keep trying. I erased the firmware on the paneldue several times then updated it to the latest firmware over USB using Bossa per instructions and now my issue seems to be resolved. On a side note I no longer see results of G32 on the consol of the PanelDue and it shows 0.0.0.0 as the IP but at least I don't have constant wifi disconnects.
                                See my original post here I fought this for almost a year and finally resolved within the past week.
                                edit: one common thread is that we both run tool changers, only I'm running a Jubilee
                                edit edit: I see you found my post... DOH...
                                • edspedundefined
                                  edsped
                                  @Phaedrux @Shoki If there's anything I can do to help let me know... I should update my post that my problem seems to be resolved.
                                  • Shokiundefined
                                    Shoki @edsped
                                    @edsped Thanks for replying with your solution. I will try it tomorrow and post the result here.
                                    • edspedundefined
                                      edsped @Shoki
                                      @Shoki Out of curiousity, before wiping see if the paneldue shows the IP address of the printer. I know mine used to but now it only shows 0.0.0.0 and I'm not sure if it's because I'm running a Duet3 with SBC or if wiping the paneldue had something to do with it. I didn't really pay attention to the IP on the paneldue and only noticed that it no longer showed the correct IP after everything was working properly.
                                      I feel your pain though as it's been incredibly frustrating.
                                        Phaedrux Moderator @edsped
                                        @edsped said in Duet 2 Ethernet disconnect when printing and paneldue connected:
                                        This is the reason because the SBC is handling all networking.
                                        • edspedundefined
                                          edsped @Phaedrux
                                          @Phaedrux I realize I'm hijacking the thread but could the reason the paneldue didn't initially work with the Duet3 w/SBC be that it was still using the IP from the Duet2 or is the IP just passed through from config.g during boot up?
                                            The paneldue only gets information from the duet. When the Duet is in SBC mode, it has no IP address of it's own.
