    PID does not work
    395
    • Haggan90undefined
      Haggan90
      Iv'e done multiple PID tunes but I still get this error every time, what am I doing wrong?!
      Heater 1 fault: temperature rising too slowly: expected 0.64°C/sec measured 0.37°C/sec
      This is my M307
      M307 H1 R1.863 K0.492:0.000 D11.56 E1.35 S1.00 B0 V24.3```
      dc42undefined A Former User? 3 Replies Last reply Reply Quote 0
        dc42 administrators @Haggan90
        @Haggan90 do you get that error every time you heat the tool, or only if it is heating with the print cooling fan running?
        From the M307 parameters it appears that either you have no print cooling fan, or you tuned the heater not the tool, so it didn't measure the effect of the pront cooling fan.
        Haggan90undefined 1 Reply Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @dc42
          @dc42 I did the tuning with the print cooling fan on, but it said something like "it appears the print cooling fan is not cooling down the hotend"
            jay_s_uk @Haggan90
            @Haggan90 best tune as a tool i.e. M303 T0 S240
            • Haggan90undefined
              Haggan90 @jay_s_uk
              @jay_s_uk I did so
              dc42undefined Haggan90undefined 2 Replies Last reply Reply Quote 0
                @Haggan90 which firmware version are you using?
                • Haggan90undefined
                  Haggan90 @Haggan90
                  @Haggan90 3.4.2
                    What kind of heater is it? Photos?
                    • Haggan90undefined
                      Haggan90 @Phaedrux
                      @Phaedrux It's just a Volcano heater, I never had this problem before RR3.
                      • A Former User?
                        A Former User @Haggan90
                        This post is deleted!
                          @Haggan90 two suggestions:
                          1. Upgrade to firmware 3.4.6
                          2. If that doesn't help, reduce the R parameter in the M307 command. Try a 25% reduction first. If you reduce it too much then the temperature will overshoot the set value.
                          • Haggan90undefined
                            Haggan90 @dc42
                            @dc42 Ok thank you, I will try that!
