    Looking for particular documentation ( I cant find it)
    Documentation
    692
    • A Former User?
      A Former User
      This post is deleted!
        I'm not sure we have docs specific to that type of setup, but I seem to recall a forum post with working example of it being done. I think it's common with vorons.
        If you can share some more specifics we can probably work out how it should function.
        • A Former User?
          A Former User @Phaedrux
          • moth4017undefined
            moth4017
            https://forum.duet3d.com/topic/8579/automatic-z-offset-calculation/2
            • moth4017undefined
              moth4017
              I had a quick go with a macro , its for a core xy , i also have to pick up my probe and got these results
              9/23/2023, 3:27:26 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:23 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:19 PM Stopped at height 4.272 mm
              9/23/2023, 3:27:16 PM Stopped at height 4.272 mm
              9/23/2023, 3:27:13 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:10 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:07 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:04 PM Stopped at height 4.270 mm
              9/23/2023, 3:27:01 PM Stopped at height 4.270 mm
              9/23/2023, 3:26:57 PM Stopped at height 4.269 mm
              Its not a very polished macro but i think you could make it work
              ; Clear compensation map and Z probe trigger height
              G31 Z0                       ; Reset Z probe trigger height
              M564 H0 S0
              ; home all axis
              G28                          ; Home all axis
              G90                          ; Absolute positioning
              T0                           ; Activate first tool
              ; Set lower speeds for Z homing and lower Z motor current
              M566 Z10                     ; Set maximum instantaneous speed changes (mm/min) (Jerk)
              M203 Z300                    ; Set maximum speeds (mm/min)
              M201 Z10                     ; Set maximum accelerations (mm/s^2)
              M913 Z60                     ; Drop motor current to prevent damage in case of head crash
              ; Move nozzle to center of bed at z25
              M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3
              G1 Z15                       ; Drop bed for nozzle clearance
              G1 X155 Y155 Z12 F4000       ; Move to bed center
              ; Reset z to 20 to allow jogging up to touch bed to nozzle
              G92 Z20
              ; Dialog to allow user to jog z to touch nozzle to bed gently and then move Z down 10
              M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
              G92 Z0                       ; Set z = 0
              M104 S0                      ; Set nozzle to 0 and release
              G1 Z15
              M98 P"/macros/ProbePickUp"   ; probe pick up
              ; Move probe to center of bed and get probe trigger heights
              M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" S3
              ;G1 Z1			; Drop bed for nozzle clearance
              G1 X155 Y155 F4000           ; Move to bed center
              M291 P"Heights will be found in gcode console if logging successful gcode is enabled" R"Did you remember to enabled gcode logging?" S3
              ; G30 S-1 10 times
              ; 1
              G1 Z10
              G30 S-1
              ; 2
              G1 Z10
              G30 S-1
              ; 3
              G1 Z10
              G30 S-1
              ; 4
              G1 Z10
              G30 S-1
              ; 5
              G1 Z10
              G30 S-1
              ; 6
              G1 Z10
              G30 S-1
              ; 7
              G1 Z10
              G30 S-1
              ; 8
              G1 Z10
              G30 S-1
              ; 9
              G1 Z10
              G30 S-1
              ; 10
              G1 Z10
              G30 S-1
              M291 P"Probing complete.  Check log for trigger heights and enter into config.g" S2
               M98 P"/macros/ProbeDropOff" ; probe drop off
              ; Tone to get user attention
              M400                         ; Clear movement buffer so tones play reliably
              M300 S666 P500
              G4 P501
              M300 S1111 P300
              G4 P301
              • A Former User?
                A Former User @moth4017
                moth4017undefined 1 Reply Last reply Reply Quote 0
                • moth4017undefined
                  moth4017 @A Former User
                  @Herve_Smith you could use sensorless homing on z and then save the z offset into the config.g but this would depend on how good your Z sensorless homing was . then could you trust it? if there was a bit of filament left on the end of the nozzle it could throw it all out .
                  • A Former User?
                    • oliofundefined
                      oliof
                      The troodon v2 comes with such an arrangement, and team gloomy provides an auto z trigger height macro at
                      https://github.com/TeamGloomy/Troodon-V2/tree/improved/Config/macros
                      maybe that's what you are looking for?
                      • A Former User?
                        A Former User @oliof
                        • moth4017undefined
                          @Herve_Smith there is also this option
                          https://www.youtube.com/watch?v=oQYHFecsTto
                          • A Former User?
                            • moth4017undefined
                              @Herve_Smith not that familiar with a voron but does it have a z endstop stop and a z probe?
                              • A Former User?
                                • System has marked this topic as solved
                                • A Former User?
                                  A Former User
                                  • oliofundefined
                                    oliof @A Former User
                                    @Herve_Smith would you be willing to share your solution?
                                    • A Former User?
                                      oliofundefined 1 Reply Last reply Reply Quote 2
                                      • oliofundefined
                                        @Herve_Smith very nicely explained and done, thanks!
                                        • A Former User?
