Delta calibration G32 Offset issue
  • undefined
    Serhii
    Hello everyone.
    I would like to ask for some help with the following issue:
    Setup:
    [3D printer]
    I have a Kossel anyCubic 3D printer with a Duet3D board.
    [Sensor]
    A mechanical switch.
    [bed.g]
    G28 ; home all towers
    G30 P0 X0.00 Y90.00 Z-99999 H-14.82
    G30 P1 X57.85 Y68.94 Z-99999 H-14.82
    G30 P2 X88.63 Y15.63 Z-99999 H-14.82
    G30 P3 X77.94 Y-45.00 Z-99999 H-14.82
    G30 P4 X30.78 Y-84.57 Z-99999 H-14.82
    G30 P5 X-30.78 Y-84.57 Z-99999 H-14.82
    G30 P6 X-77.94 Y-45.00 Z-99999 H-14.82
    G30 P7 X-88.63 Y15.63 Z-99999 H-14.82
    G30 P8 X-57.85 Y68.94 Z-99999 H-14.82
    G30 P9 X0.00 Y45.00 Z-99999 H-14.82
    G30 P10 X38.97 Y22.50 Z-99999 H-14.82
    G30 P11 X38.97 Y-22.50 Z-99999 H-14.82
    G30 P12 X0.00 Y-45.00 Z-99999 H-14.82
    G30 P13 X-38.97 Y-22.50 Z-99999 H-14.82
    G30 P14 X-38.97 Y22.50 Z-99999 H-14.82
    G30 P15 X0 Y0 Z-99999 S6
    Thank you in advance.
    undefined 1 Reply Last reply 23 Sept 2023, 10:54 Reply Quote 0
    • undefined
      droftarts administrators @Serhii
      @Serhii I think you’re using the H parameter of G30 incorrectly. From the Gcode dictionary
      The H parameter is an optional height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z parameter of the G31 command in the config.g file. When you probe using G30 and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H parameter. For example, when doing delta calibration, it can account for the change in trigger height caused by effector tilt, if the vertical offset caused by the tilt has been measured.
      So H parameter should be 0 unless there is a variation is Z height with XY position.
      Use G31 Z… to set the probe offset ie 14.82mm. You haven’t posted your config.g or firmware version, so I don’t know how this is currently set.
      undefined 1 Reply Last reply 23 Sept 2023, 10:58 Reply Quote 0
      • undefined
        Serhii @droftarts
        @droftarts Thank you for the quick replay.
        I have attached my config file
        config.g
        Could you suggest which changes should be made?
        undefined 1 Reply Last reply 23 Sept 2023, 11:07 Reply Quote 0
        • undefined
          @Serhii said in Delta calibration G32 Offset issue:
          I thought I just did! Set H to 0 in, or remove it from, the G30 commands in bed.g. Set the Z probe offset in the G31 command in config.g.
          I can’t read your config.g, I’m on my phone. Post it as a text file (.txt ending) or as code in code tags.
          undefined 1 Reply Last reply 23 Sept 2023, 12:10 Reply Quote 0
          • undefined
            Serhii @droftarts
            @droftarts
            Some information about the board and FW
            Board: Duet 2 WiFi (2WiFi)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0 (2022-03-15)
            Duet WiFi Server Version: 1.26
            config.txt
            M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y0 Z14.82 ; set Z probe trigger value, offset and trigger height
            M557 R85 S20 ; define mesh grid
            I removed the H option from the bed.g file
            The result looks the same
            undefined 1 Reply Last reply 23 Sept 2023, 23:47 Reply Quote 0
            • undefined
              @Serhii The diagram of the bed you are looking at is a mesh probe of the bed using G29, not the result of delta calibration (G32/bed.g). Running a delta calibration with the G30 H parameter set to -14.82 will affect the 'homed height' result of the delta calibration, I think, so when you then run G29, the bed looks too far away. So make sure all G30 H commands are set to H0 in bed.g, then run G32 again (to set the correct homed height) then G28 to home, then G29 for the bed mesh.
              G29 runs sys/mesh.g if it exists, so you could create that with a G28 then G29 in it.
              In case you haven't seen it, also see https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
              undefined 1 Reply Last reply 26 Sept 2023, 18:25 Reply Quote 0
              • undefined
                Serhii @droftarts
                @droftarts thank you for your help.
                I finally got the following result:
                1 out of 7
