    PanelDue cable extension
    • MihaiDesignsundefined
      MihaiDesigns
      I need about 2 meters of cable between the display and the board. I read that I can extend the 4p cable to 2m. Ideally, I'd be able to use the SD card; for that, I need the 10p cable (or so I understand). Would it work to extend that cable as well to 2 meters? I suppose I could give up the SD card support if it's too much trouble, but wanted to check here first.
        jay_s_uk @MihaiDesigns
        @MihaiDesigns no, you won't be able to manage 2m for the 10p cable.
        For the 4p I would suggest using screened cable
