Set velocity is not reached
Hello everybody,
after finishing my VZBot I have done some Testprints.
The problem is that the set speeds are not reached during printing.
The speeds are reached in rapid moves.
I have set the acceleration and speeds high enough. 20kmm/s2 Acc.
It looks like when printing, it slowly moves to the speed that is set.
In rapid moves, it reaches the speed immediately.I don’t know what to do or set.
Is that a Problem with Input Shaper or PA?
Any ideas ?
Regards Lars
@gringo, have a look at the slicer settings and possibly the gcode. PrusaSlicer has a nice feature where you can visually see a lot of parameters on your model. I use speed and volumetric flow rate for almost every print before it is sent to the printer in order to verify that I have set things up right. I look at fan speed on occasion - that was really helpful yesterday when one particular layer called for 100% fan speed which caused heater faults.
There are other gcode visualizers out there but I am happy with PrusaSlicer so never looked at others. -
When I disable PA the speeds are achieved.
@gringo said in Set velocity is not reached:
The usual culprit in that situation is that extruder jerk is set too low. There is an interaction between extruder jerk and PA. You can set extruder jerk to a "silly high" number and it won't have any adverse effect.
Ok, I will try it. Thanks
It works. Thanks a lot
