Losing connection while trying to record motion profile
  • undefined
    tomasf
    I just installed the Duet3D accelerometer board, connected it to my Mini 5 and set it up with
    M955 P0 I64 C"spi.cs2+spi.cs1". So far so good, but when I try to Record Motion Profile, it moves to the correct Z height, stops, and after a couple of seconds, the board resets and I get Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin) followed by Connection to Duet established and Warning: SPI connection has been reset.
    The very first time I tried it, I did get results back (but with The selected motion profile contains overflows. It may not be accurate.), but every time since then, I get the reset.
    SBC mode. RRF 3.5.0-rc.1.
    Any ideas?
    • undefined
      tomasf
      I tried downgrading to RRF 3.4.6 to see if a stable version improved things, but it didn't help.
      • undefined
        tomasf
        Here's M122 after a reset if that could help:
        RepRapFirmware for Duet 3 Mini 5+ version 3.4.6 (2023-07-21 14:09:13) running on Duet 3 Mini5plus WiFi (SBC mode)
        Board ID: MPKT6-F396U-D65J0-40KM8-3A03Z-R0UUN
        Used output buffers: 1 of 40 (12 max)
        Static ram: 103712
        Dynamic ram: 99580 of which 24 recycled
        Never used RAM 38396, free system stack 206 words
        Tasks: ACCEL(notifyWait,0.0%,346) SBC(ready,1.3%,434) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,342) TMC(notifyWait,0.0%,124) MAIN(running,97.4%,557) IDLE(ready,0.5%,30) AIN(delaying,0.8%,273), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 00:00:54 ago, cause: software
        Last software reset at 2023-10-12 17:23, reason: HeatTaskStuck, GCodes spinning, available RAM 38252, slot 1
        Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x200134b0 Task ACCE Freestk 4294936825 ok
        Stack: 2001948c 20012e5c 200014e8 e000e000 000000a5 00091d55 000905a6 6100f000 00000001 e000e000 00091d55 20019074 000000c8 20019088 0008ac65 bd0ae633 00000005 3e638e37 20019074 00000005 00000006 200135a0 0008ae6d 20019074 20023ad8 20023a50 00027ac6
        Error status: 0x00
        MCU revision 3, ADC conversions started 54608, completed 54608, timed out 0, errs 0
        Step timer max interval 1489
        MCU temperature: min 28.8, current 29.1, max 29.8
        Supply voltage: min 1.3, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
        Events: 0 queued, 0 completed
        Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2023-10-12 17:24:35
        Cache data hit count 129047879
        Slowest loop: 3.63ms; fastest: 0.08ms
        === Storage ===
        Free file entries: 10
        SD card 0 not detected, interface speed: 0.0MBytes/sec
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 489, received 0, lost 0, boc 0
        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 273/0/0
        Tx timeouts 0,0,272,0,0,215 last cancelled message type 4514 dest 127
        === SBC interface ===
        Transfer state: 5, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 11189/2147
        SPI underruns 0, overruns 0
        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f178
        Buffer RX/TX: 0/0-0, open files: 0
        === Duet Control Server ===
        Duet Control Server v3.4.6
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
        Full transfers per second: 33.05, max time between full transfers: 95.2ms, max pin wait times: 34.0ms/2.5ms
        Codes per second: 0.49
        Maximum length of RX/TX data transfers: 3716/960
        • undefined Phaedrux marked this topic as a question 13 Oct 2023, 20:53
        • undefined
          What are you using for wiring?
          undefined 1 Reply Last reply 15 Oct 2023, 11:51 Reply Quote 0
          • undefined
            tomasf @Phaedrux
            @Phaedrux It's the cable that came with the accelerometer.
            • undefined
              Perhaps @chrishamm has some ideas?
              1 out of 6
