    y slope with 3.5.0-rc1, not seen with 3.4.6
    Beta Firmware
    10
    92
    5.2k
      dc42 administrators @Adrian52
      @Adrian52 thanks. My delta also has 200 steps/mm so I'll try it on that.
        @Adrian52 I increased the max speeds and acceleration on my delta to the values in your config.g and set the input shaping to be the same. The print came out OK.
        If you send me the GCode file for the other print that had a lean, I'll try that one.
        PS - I've just noticed an anomaly in the 'min interval' value in your M122 report after the print that leaned. That may be relevant to this issue. I will investigate it.
        Adrian52undefined 2 Replies Last reply Reply Quote 0
        • Adrian52undefined
          Adrian52 @dc42
          @dc42 I only used that gcode file - for me, it leans with IS on, but is vertical with IS off. The effect is not that obvious - just less than 1mm over the 20mm height.
            @Adrian52 i meant the one in this post https://forum.duet3d.com/post/325473.
            Adrian52undefined 1 Reply Last reply Reply Quote 0
            • Adrian52undefined
              Adrian52 @dc42
              @dc42 here is a picture of the effect:
              the left cuboid is sloped in the y+ direction (IS on), the right cuboid is vertical. The short sides (x-facing) of the centre cuboid are vertical . The print quality seems fine to me, apart from the lean.
              • Adrian52undefined
                Adrian52 @dc42
                @dc42 Here it is
                jig1_225.gcode
                I couldn't find the original gcode, so I resliced with the same conditions as the cube. I checked print, and amazingly it came out looking exactly like the blue ones in the early post, going vertical from the U cutout on the y+ face
                • Adrian52undefined
                  Adrian52
                  Just checked printing the same jig1 gcode file with IS disabled, and there is still some slope on the lower part - around 1mm offset at the base, compared with about 2mm with IS on zvd.
                    @Adrian52 please re-run some of those prints that give you a slope, but before the print run this command:
                    M112 B4096
                    This will likely result in debug output on the DWC console during the print. Please post that output here. If you don't see any debug output, please take a M122 report when the print finishes, or when you are sure it is leaning if you don't want t complete the print.
                    gloomyandyundefined Adrian52undefined 2 Replies Last reply Reply Quote 0
                    • gloomyandyundefined
                      gloomyandy @dc42
                      @dc42 Did you mean M111 B4096 rather than M112 B4096?
                      • Adrian52undefined
                        Adrian52 @dc42
                        @dc42 This is the debug output printing jig1.gcode with zvd enabled
                        23/03/2024, 12:19:29 	Seg length diff 9.52e-7 at 5
                        S d=9.0218e-4 t=17.3 b=9.6610e+3 c=-3.7000e+8 a=-5.4053e-9
                        23/03/2024, 12:19:28 	Seg length diff -9.28e-7 at 5
                        S d=8.8501e-4 t=16.9 b=9.6607e+3 c=-3.7000e+8 a=-5.4055e-9
                        23/03/2024, 12:16:34 	M32 "0:/gcodes/jig1_225.gcode"
                        File 0:/gcodes/jig1_225.gcode selected for printing
                        23/03/2024, 12:14:07 	M111 B4096
                        23/03/2024, 12:12:19 	M593
                        Input shaping 'zvd' at 27.0Hz damping factor 0.00, min. reduction 0.1, impulses 0.250 0.750 with durations (ms) 18.52 18.52
                        and the M122
                        23/03/2024, 12:42:28 	M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.3+ (2024-03-18 09:34:21) running on Duet WiFi 1.0 or 1.01
                        Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W
                        Used output buffers: 3 of 26 (17 max)
                        Static ram: 23256
                        Dynamic ram: 76852 of which 12 recycled
                        Never used RAM 7536, free system stack 110 words
                        Tasks: NETWORK(2,nWait 6,14.3%,193) HEAT(3,nWait 5,0.1%,307) Move(4,nWait 5,1.7%,242) MAIN(1,running,83.9%,850) IDLE(0,ready,0.1%,29), total 100.0%
                        Owned mutexes:
                        Last reset 00:33:33 ago, cause: power up
                        Last software reset at 2024-03-05 21:23, reason: User, Gcodes spinning, available RAM 11272, slot 1
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU temperature: min 17.1, current 27.7, max 33.9
                        Supply voltage: min 24.1, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, SG min 0
                        Driver 1: standstill, SG min 0
                        Driver 2: standstill, SG min 0
                        Driver 3: standstill, SG min 0
                        Driver 4: standstill, SG min 0
                        Driver 5:
                        Driver 6:
                        Driver 7:
                        Driver 8:
                        Driver 9:
                        Driver 10:
                        Driver 11:
                        Date/time: 2024-03-23 12:42:26
                        Slowest loop: 210.94ms; fastest: 0.14ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                        DMs created 105, segments created 29, maxWait 427239ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                        no step interrupt scheduled
                        Moves shaped first try 1888, on retry 165, too short 2675, wrong shape 6534, maybepossible 136
                        === DDARing 0 ===
                        Scheduled moves 14391, completed 14391, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                        Movement locks held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Q0 segments left 0
                        Code queue 0 is empty
                        === Filament sensors ===
                        check 4870041 clear 2112480
                        Extruder 0: pos 0.83, brightness 25, shutter 133, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                        === Network ===
                        Slowest loop: 205.68ms; fastest: 0.00ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        === WiFi ===
                        Interface state: active
                        Firmware version 2.1beta6
                        MAC address 5c:cf:7f:2c:24:6b
                        Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 43036
                        WiFi IP address 192.168.1.16
                        Signal strength -53dBm, channel 13, mode 802.11n, reconnections 0
                        Clock register 00002002
                        23/03/2024, 12:41:24 	Finished printing file 0:/gcodes/jig1_225.gcode, print time was 0h 24m
                        23/03/2024, 12:36:11 	Duet3D laser filament monitor v2 on pin (connlcd.encb,connlcd.3), enabled when SD printing, allow 1% to 300%, check all extruding moves every 10.0mm, cal. factor 0.450, quality 219, measured min 81% avg 99% max 120% over 1188.1mm
                          @Adrian52 thanks. Please do the same test with the filled cube print.
                          • Adrian52undefined
                            Adrian52 @dc42
                            @dc42 Here is the dbug output
                            24/03/2024, 10:22:00 	Duet3D laser filament monitor v2 on pin (connlcd.encb,connlcd.3), enabled when SD printing, allow 1% to 300%, check all extruding moves every 10.0mm, cal. factor 0.450, quality 221, measured min 87% avg 102% max 123% over 1958.4mm
                            24/03/2024, 10:03:08 	Seg length diff -8.66e-7 at 5
                            S d=8.2207e-4 t=15.8 b=9.4952e+3 c=-3.6525e+8 a=-5.4756e-9
                            24/03/2024, 10:02:26 	Seg length diff 9.13e-7 at 5
                            S d=8.5831e-4 t=16.5 b=9.5068e+3 c=-3.6552e+8 a=-5.4717e-9
                            24/03/2024, 10:02:22 	Seg length diff 9.13e-7 at 5
                            24/03/2024, 10:02:16 	Seg length diff 8.82e-7 at 5
                            S d=8.5831e-4 t=16.5 b=9.5068e+3 c=-3.6553e+8 a=-5.4715e-9
                            24/03/2024, 10:02:06 	Bad interval -676 dr=2, ns=119
                            DMZ: dir=B steps=119 next=119 rev=52 interval=11626 ssl=120 A=1.3211e+11 B=4.6209e+5 C=-2.3672e+7 dsf=2.7601e+1 tsf=424234.8 hmz0s=6.3767e+4 minusAaPlusBbTimesS=2.7592e+3 dSquaredMinusAsquaredMinusBsquared=4.0683e+9 drev=1.2807e+1
                            dda:  3 ts=673539940 DDA: start=[13.796242 -8.836784 0.485564] end=[-13.805079 -8.836784 0.400000] s=2.7601e+1 vec=[-0.999995 0.000000 -0.003100] ext=[0.032510 0.032510]
                            a=1.2672e-9 d=1.2673e-9 reqv=7.4666e-5 startv=1.6000e-5 topv=7.4666e-5 endv=1.5992e-5 cks=424233 fp=26876 fl=155f
                            S d=3.4144e-1 t=17361.1 b=-3.7880e+4 c=4.7350e+9 a=4.2239e-10
                            S d=5.9606e-1 t=17361.1 b=-1.8414e+4 c=1.5783e+9 a=1.2672e-9
                            S d=9.7800e-1 t=17361.1 b=-3.5775e+4 c=1.5783e+9 a=1.2672e-9
                            S d=1.2326e+0 t=17361.1 b=-1.5941e+5 c=4.7350e+9 a=4.2239e-10
                            S d=2.1306e+1 t=285345.9 c=1.3393e+4
                            S d=1.2326e+0 t=17361.1 b=1.7674e+5 c=-4.7343e+9 a=-4.2245e-10
                            S d=9.7795e-1 t=17361.1 b=5.3128e+4 c=-1.5781e+9 a=-1.2673e-9
                            S d=5.9596e-1 t=17361.1 b=3.5767e+4 c=-1.5781e+9 a=-1.2673e-9
                            S d=3.4131e-1 t=17361.1 b=5.5217e+4 c=-4.7343e+9 a=-4.2245e-10
                            24/03/2024, 09:58:40 	M32 "0:/gcodes/30x20x20cube_filled.gcode"
                            File 0:/gcodes/30x20x20cube_filled.gcode selected for printing
                            and the M122:
                            24/03/2024, 10:27:23 	M122
                            Used output buffers: 16 of 26 (18 max)
                            Static ram: 23256
                            Never used RAM 7656, free system stack 68 words
                            Tasks: NETWORK(2,nWait 6,14.3%,193) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,1.6%,242) MAIN(1,running,84.0%,841) IDLE(0,ready,0.1%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:37:14 ago, cause: power up
                            Error status: 0x08
                            Aux0 errors 0,0,0
                            MCU temperature: min 17.8, current 27.1, max 35.1
                            Supply voltage: min 24.1, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/32/32, gc cycles 0
                            Driver 5:
                            Driver 6:
                            Driver 7:
                            Driver 8:
                            Driver 9:
                            Driver 10:
                            Driver 11:
                            Date/time: 2024-03-24 10:27:19
                            Slowest loop: 211.98ms; fastest: 0.14ms
                            === Storage ===
                            SD card longest read time 1.0ms, write time 9.5ms, max retries 0
                            DMs created 105, segments created 24, maxWait 487694ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval -676, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                            Moves shaped first try 2635, on retry 98, too short 2405, wrong shape 2294, maybepossible 2
                            === DDARing 0 ===
                            Scheduled moves 9392, completed 9392, hiccups 1, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                            Q0 segments left 0
                            check 5550781 clear 2098127
                            Extruder 0: pos -3.49, brightness 12, shutter 102, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                            === Network ===
                            Slowest loop: 206.54ms; fastest: 0.00ms
                            Responder states: HTTP(0) HTTP(1) HTTP(1) FTP(0) Telnet(0)
                            === WiFi ===
                            Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 39524
                            Signal strength -49dBm, channel 13, mode 802.11n, reconnections 0
                            Socket states: 0 5 3 3 0 0 0 0
                            24/03/2024, 10:27:15 	Finished printing file 0:/gcodes/30x20x20cube_filled.gcode, print time was 0h 28m
                            • Adrian52undefined
                              Adrian52 @dc42
                              @dc42 I also checked a 20x20x20 plain filled cube, as this has a more pronounced y slope than the 30x20x20 cube.
                              debug:
                              24/03/2024, 10:58:02 	Finished printing file 0:/gcodes/20x20x20cube_filled.gcode, print time was 0h 24m
                              24/03/2024, 10:52:49 	Duet3D laser filament monitor v2 on pin (connlcd.encb,connlcd.3), enabled when SD printing, allow 1% to 300%, check all extruding moves every 10.0mm, cal. factor 0.450, quality 219, measured min 86% avg 98% max 116% over 1430.4mm
                              24/03/2024, 10:52:11 	Seg length diff -8.60e-7 at 5
                              S d=8.5258e-4 t=16.4 b=9.4745e+3 c=-3.6557e+8 a=-5.4710e-9
                              24/03/2024, 10:51:46 	Seg length diff 8.93e-7 at 5
                              S d=8.5449e-4 t=16.5 b=9.4796e+3 c=-3.6584e+8 a=-5.4669e-9
                              24/03/2024, 10:51:43 	Seg length diff 9.40e-7 at 5
                              S d=8.5258e-4 t=16.5 b=9.4796e+3 c=-3.6586e+8 a=-5.4666e-9
                              24/03/2024, 10:51:18 	Seg length diff 8.71e-7 at 5
                              S d=8.0872e-4 t=16.9 b=1.6875e+4 c=-7.0312e+8 a=-2.8444e-9
                              24/03/2024, 10:36:17 	Seg length diff 9.52e-7 at 5
                              24/03/2024, 10:36:16 	Seg length diff -9.28e-7 at 5
                              24/03/2024, 10:33:21 	M32 "0:/gcodes/20x20x20cube_filled.gcode"
                              File 0:/gcodes/20x20x20cube_filled.gcode selected for printing
                              M122:
                              24/03/2024, 11:02:48 	M122
                              Used output buffers: 3 of 26 (26 max)
                              Static ram: 23256
                              Tasks: NETWORK(2,nWait 6,14.2%,193) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,1.5%,242) MAIN(1,running,84.2%,841) IDLE(0,ready,0.0%,29), total 100.0%
                              Last reset 01:12:41 ago, cause: power up
                              Error status: 0x08
                              Aux0 errors 0,0,0
                              MCU temperature: min 26.5, current 28.1, max 35.3
                              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/64/64, gc cycles 0
                              Driver 5:
                              Driver 6:
                              Driver 7:
                              Driver 8:
                              Driver 9:
                              Driver 10:
                              Driver 11:
                              Date/time: 2024-03-24 11:02:46
                              Slowest loop: 211.56ms; fastest: 0.14ms
                              === Storage ===
                              SD card longest read time 8.2ms, write time 0.0ms, max retries 0
                              DMs created 105, segments created 24, maxWait 645579ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                              Moves shaped first try 2392, on retry 6, too short 1623, wrong shape 2362, maybepossible 3
                              === DDARing 0 ===
                              Scheduled moves 8376, completed 8376, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                              Q0 segments left 0
                              check 10345540 clear 4725652
                              Extruder 0: pos 7.10, brightness 15, shutter 91, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                              === Network ===
                              Slowest loop: 203.61ms; fastest: 0.07ms
                              === WiFi ===
                              Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 42348
                              Signal strength -52dBm, channel 13, mode 802.11n, reconnections 0
                              • balajiramaniundefined
                                balajiramani @dc42
                                @dc42 Here is the output of M122 before the print. This print had IS turned on. I will submit another result after turning off IS.
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.3+mms (2024-03-13 13:10:20) running on Duet WiFi 1.0 or 1.01
                                Board ID: 08DAM-999TL-MQ4SD-6JTDL-3SS6N-968BX
                                Used output buffers: 2 of 26 (26 max)
                                Static ram: 23256
                                Dynamic ram: 77488 of which 0 recycled
                                Never used RAM 8320, free system stack 114 words
                                Tasks: NETWORK(1,ready,30.6%,193) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,258) MAIN(1,running,60.1%,714) IDLE(0,ready,9.2%,29), total 100.0%
                                Owned mutexes:
                                Last reset 00:13:31 ago, cause: software
                                Last software reset at 2024-03-20 18:21, reason: StuckInSpinLoop, Gcodes spinning, available RAM 8552, slot 0
                                Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200025b4 Task MAIN Freestk 929 ok
                                Stack: 0042c6eb 0045747c 61030000 3ef8490a 40a00400 4232877a 80000000 c33a2cf8 00000000 20000c98 00000001 00000001 00000028 20004c64 40090000 0042c96d 00000000 00000001 000c8f49 0042d0fb 00000000 447b221d 00000001 03ba77ff 004575b5 00000000 00000000
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU temperature: min 41.1, current 41.5, max 43.1
                                Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1212/1176, gc cycles 1
                                Driver 0: standstill, SG min n/a
                                Driver 1: standstill, SG min n/a
                                Driver 2: standstill, SG min n/a
                                Driver 3: standstill, SG min n/a
                                Driver 4: standstill, SG min n/a
                                Driver 5:
                                Driver 6:
                                Driver 7:
                                Driver 8:
                                Driver 9:
                                Driver 10:
                                Driver 11:
                                Date/time: 2024-03-26 18:50:33
                                Slowest loop: 51.48ms; fastest: 0.18ms
                                === Storage ===
                                Free file entries: 8
                                SD card longest read time 51.1ms, write time 2.7ms, max retries 0
                                DMs created 83, segments created 51, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                === DDARing 0 ===
                                Scheduled moves 13465, completed 13465, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                Heater 0 is on, I-accum = 0.1
                                Heater 1 is on, I-accum = 0.2
                                Daemon is idle in state(s) 0 0, running macro
                                Q0 segments left 0
                                === Network ===
                                Slowest loop: 21.11ms; fastest: 0.07ms
                                === WiFi ===
                                MAC address 5c:cf:7f:2c:25:00
                                Module reset reason: Turned on by main processor, Vcc 3.40, flash size 2097152, free heap 43088
                                WiFi IP address 192.168.1.61
                                Signal strength -36dBm, channel 6, mode 802.11n, reconnections 0
                                Here is the output after I cancelled the print.
                                M122
                                Used output buffers: 7 of 26 (26 max)
                                Static ram: 23256
                                Never used RAM 8232, free system stack 114 words
                                Tasks: NETWORK(2,nWait 6,29.8%,193) HEAT(3,nWait 5,0.1%,319) Move(4,nWait 5,1.4%,258) MAIN(1,running,60.9%,714) IDLE(0,ready,7.8%,29), total 100.0%
                                Owned mutexes:
                                Last reset 00:23:40 ago, cause: software
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU temperature: min 39.2, current 42.7, max 43.4
                                Supply voltage: min 23.4, current 24.3, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/620/584, gc cycles 3
                                Driver 5:
                                Driver 6:
                                Driver 7:
                                Driver 8:
                                Driver 9:
                                Driver 10:
                                Driver 11:
                                Date/time: 2024-03-26 19:00:42
                                Slowest loop: 311.49ms; fastest: 0.09ms
                                === Storage ===
                                SD card longest read time 50.1ms, write time 10.5ms, max retries 0
                                DMs created 84, segments created 51, maxWait 534671ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                                Moves shaped first try 244, on retry 11, too short 236, wrong shape 11146, maybepossible 64
                                === DDARing 0 ===
                                Scheduled moves 13421, completed 13421, hiccups 0, stepErrors 0, LaErrors 0, Underruns [16, 0, 20], CDDA state -1
                                Q0 segments left 0
                                === Network ===
                                Slowest loop: 210.54ms; fastest: 0.07ms
                                === WiFi ===
                                Module reset reason: Turned on by main processor, Vcc 3.40, flash size 2097152, free heap 42812
                                Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
                                  balajiramani
                                  BTW, I had run M111 B4096 before starting the print, but I did not get any debugging output.
                                  • Adrian52undefined
                                    Adrian52 @balajiramani
                                    @balajiramani when I tried the 20x20x20 filled cube with IS disabled there was no debug output (although the y slope is still there).
                                    balajiramaniundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      balajiramani
                                      Here is the output of M122 with IS off.
                                      M122
                                      Static ram: 23256
                                      Dynamic ram: 77488 of which 208 recycled
                                      Never used RAM 8024, free system stack 114 words
                                      Tasks: NETWORK(1,ready,30.2%,193) HEAT(3,nWait 5,0.1%,319) Move(4,nWait 5,1.0%,258) MAIN(1,running,60.4%,714) IDLE(0,ready,8.3%,29), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:37:42 ago, cause: software
                                      Error status: 0x04
                                      Aux0 errors 0,0,0
                                      MCU temperature: min 39.7, current 42.9, max 43.7
                                      Supply voltage: min 23.4, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1796/1760, gc cycles 4
                                      Driver 5:
                                      Driver 6:
                                      Driver 7:
                                      Driver 8:
                                      Driver 9:
                                      Driver 10:
                                      Driver 11:
                                      Date/time: 2024-03-26 19:14:44
                                      Slowest loop: 238.35ms; fastest: 0.09ms
                                      === Storage ===
                                      SD card longest read time 53.1ms, write time 5.6ms, max retries 1
                                      DMs created 84, segments created 51, maxWait 639154ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                                      === DDARing 0 ===
                                      Scheduled moves 13388, completed 13388, hiccups 0, stepErrors 0, LaErrors 0, Underruns [21, 0, 46], CDDA state -1
                                      Q0 segments left 0
                                      === Network ===
                                      Slowest loop: 211.70ms; fastest: 0.07ms
                                      === WiFi ===
                                      Signal strength -45dBm, channel 6, mode 802.11n, reconnections 0
                                        balajiramani @Adrian52
                                        @Adrian52 I too have the same experience, where IS does not seem to matter.
                                          @Adrian52 is your config.g file still the same as the one you posted on 23 Oct 2023 here https://forum.duet3d.com/post/325846 ?
                                          • Adrian52undefined
                                            Adrian52 @dc42
                                            @dc42 Probably not exactly - this is my current config.g
                                            ; Communication and general
                                            M111 S0                             	; Debug off
                                            M550 PKosselXL							; Machine name and Netbios name (can be anything you like)
                                            M551 Preprap                        	; Machine password (used for FTP)
                                            ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                                            ;M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED 	; MAC Address
                                            ;*** Wifi Networking
                                            M552 S1									; Enable WiFi. Disabled for setup and testing. Enable once set up on your network.
                                            M555 P0                           		; Set output to look like Reprap
                                            M575 P1 B57600 S1						; Comms parameters for PanelDue
                                            G21                                 	; Work in millimetres
                                            G90                                		; Send absolute coordinates...
                                            M83                                 	; ...but relative extruder moves
                                            ; Axis and motor configuration
                                            M584 X0 Y1 Z2 E3:4						;explicitly assign drives
                                            M569 P0 S0								; Drive 0 goes backwards - changed to backwards for robodigg clamps
                                            M569 P1 S0								; Drive 1 goes backwards - "
                                            M569 P2 S0								; Drive 2 goes backwards - "
                                            M569 P3 S0								; Drive 3 goes backwards - changed for orbiter 1.5
                                            M569 P4 S0								; Drive 4 goes backwards - orbiter 2.0
                                            M84 S120								;set idle timeout to 120sec
                                            ;M574 X2 Y2 Z2 S1						; set endstop configuration (all endstops at high end, active high)
                                            M574 X2 S1 P"xstop"
                                            M574 Y2 S1 P"ystop"
                                            M574 Z2 S1 P"zstop"
                                            ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                                            M665 L360.25 R173.990 H297.084 B120.0 X0.538 Y0.525 Z0.000
                                            M666 X1.493 Y-1.213 Z-0.280 A-1.03 B-0.66		; put your endstop adjustments here, or let auto calibration find them
                                            M579 X1.005 Y1.012 Z1.00		        	;correct x y z scaling
                                            M350 X16 Y16 Z16 I1	    				; Set 16x microstepping with interpolation
                                            M350 E16:16 I1								; Set exruder to 16x with interpolation
                                            M92 X200 Y200 Z200						; Set axis steps/mm
                                            M906 X1400 Y1400 Z1400 I0.6		; Set motor currents (mA) and increase idle current to 60%
                                            M906 E850:850 I10							;current for orbiter
                                            M201 X5000 Y5000 Z5000 E5000:5000			; Accelerations (mm/s^2)
                                            M203 X20000 Y20000 Z20000 E7200:7200			; Maximum speeds (mm/min)
                                            M566 X900 Y900 Z900 E300 P1			; Maximum instant speed changes mm/minute, switch on 2.03 jerk policy
                                            ; Thermistors and heaters
                                            M308 S0 P"bedtemp" A"Bed temp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin bedtemp
                                            M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
                                            M307 H0 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
                                            M140 H0									;bed heater is heater 0
                                            M143 H0 S125
                                            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 A"Extruder temp"  ; configure sensor 1 as thermister via e0temp
                                            M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.060000e-8 A"Cold end temp"  ; configure sensor 2 as thermister via e1temp
                                            ;M308 S1 P"spi.cs1" Y"rtdmax31865" A"Extruder temp"  ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                            ;M308 S2 P"spi.cs2" Y"rtdmax31865" A"Test temp"		; configure sensor 2
                                            M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
                                            M950 P2 C"e1heat"									; create output to switch lights
                                            M307 H1 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
                                            M143 H1 S300                                        ; set temperature limit for heater 1 to 295C
                                            M570 H1 S60											;cancel print 60min after extruder temp fault
                                            ; ****Fans
                                            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                                            M106 P0 S0 H-1                                      ; set fan 0 value. Thermostatic control is turned off
                                            M950 F1 C"fan1" Q2500                                ; create fan 1 on pin fan1 and set its frequency
                                            M106 P1 S1 H1 T45                                   ; set fan 1 value. Thermostatic control is turned on
                                            M950 F2 C"!Fan2+^exp.pb6" Q25000
                                            M106 P2 S0 H-1 C"Extra cool"
                                            M563 P0 D0:1 H1 F0                                   ; define tool 0
                                            G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
                                            G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
                                            ; Tool definitions
                                            ;M563 P0 D0 H1 F0:2                     			; Define tool 0 with fan 0, fan 2 linked
                                            ;M563 P0 D0 H1 F0 									; tool 0 with fan 0 only
                                            G10 P0 S0 R0                        				; Set tool 0 operating and standby temperatures
                                            M567 P0 E1.00:1.00									; set mix ratio
                                            M309 p0 S0.006										; set heater feed forward for tool 0
                                            ;*** If you have a single-nozzle build, comment the next 2 lines
                                            ;M563 P1 D1 H2                      					; Define tool 1
                                            ;G10 P1 S0 R0                       				; Set tool 1 operating and standby temperatures
                                            ;M92 E458                        					; Set extruder steps per mm
                                            M92 E667:667                        					; Set extruder steps per mm orbiter
                                            M572 D0:1 S0.032											;pressure advance extruder 0 and 1
                                            ;M572 D1 S0.02										; pressure advance extruder 1
                                            M207 S2.1 R0.0 F7200 Z0.05             		; firmware retraction setting
                                            ; Z probe and compensation definition
                                            M558 P8 C"zprobe.in+zprobe.mod" R0.4 F1000 H5 A2 S-1		;Z probe smart effector
                                            M672 S105:20:235									;set z probe sensitivity
                                            ;G31 P100 X0 Y0 Z-0.10								;probe offset for old smart effector
                                            G31 P100 X0 Y0 Z-0.08								;probe offset for new smart effector 0.27 for petg 0.18 for pla try 0.1 for direct drive
                                            													;laser filament monitor settings
                                            M591 D0 P5 C"connlcd.encb" R01:300 E10 L0.45 S1 A1		;version for reprap3
                                            ;M955 P0 C"spi.cs3+spi.cs4" I64 S5000 R10							;accelerometer configuration
                                            ;*** If you are using axis compensation, put the figures in the following command
                                            M556 S100 X0.05 Y0 Z0                  				; Axis compensation here
                                            M593 P"zvd" F27 L0.10 S0							; Damp ringing at 27Hz
                                            M376 H0											;taper mesh over 10mm
                                            M501												;use override-config.g parameters
                                            M208 S1 Z-0.2										; set minimum Z
                                            M912 P0 S-2											;calibration mcu temperature reading
                                            G28													;Home axes
                                            M42 P2 S1											;lights on
                                            ;G29 S1												;load height map and activate mesh compensation
                                            ;M290 S-0.1											;current baby steps
                                            T0													; select first hot end
