    Stops dead randomly
    • bubblevisorundefined
      bubblevisor
      My duet 2 mini 5+ controlled printer has recently developed a problem whereby it stops dead randomly. I have yet to catch it when the failure occurs but it appears as though someone just cut the power momentarily. Could it literally be a fault with the power supply? I have attached a shot of the console that may indicate something. Any ideas?screen.jpg
        jay_s_uk @bubblevisor
        @bubblevisor post an output of M122 after the issue occurs. It doesn't have to be right away
        bubblevisorundefined 1 Reply Last reply Reply Quote 0
          bubblevisor @jay_s_uk
          @jay_s_uk Here is the M122. It has done a few successful prints but just now it stopped just before it started laying the first layer:
          m122
          RepRapFirmware for big-dipper version 3.4.0beta5+1 (2021-10-23 18:16:14) running on Duet 3 big-dipper WiFi (standalone mode)
          Board ID: RZAN1-D2401-8D3J0-40188-K3T0Z-7YR20
          Used output buffers: 3 of 40 (12 max)
          Static ram: 102180
          Dynamic ram: 101368 of which 0 recycled
          Never used RAM 38164, free system stack 198 words
          Tasks: NETWORK(ready,15.8%,249) HEAT(notifyWait,0.0%,343) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,338) TMC(notifyWait,1.2%,114) MAIN(running,82.0%,425) IDLE(ready,0.1%,30) AIN(delaying,0.8%,264), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:04:14 ago, cause: software
          Last software reset at 2023-10-21 16:25, reason: HardFault imprec, Display spinning, available RAM 37884, slot 2
          Software reset code 0x406f HFSR 0x40000000 CFSR 0x00000400 ICSR 0x0047d803 BFAR 0xe000ed38 SP 0x20003f18 Task MAIN Freestk 1066 ok
          Stack: 00000000 200290a8 00000571 00000570 00000348 00076857 00076872 61030000 00000000 00000000 369dc3a0 3edb75d2 3331bb4c 41880000 3e178897 3e1cd04f be09b238 3e3a3fd4 3e639b49 00000000 00000000 412ccccd 3f800000 00000000 60000010 a5a5a5a5 0000000f
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 0, ADC conversions started 254285, completed 254285, timed out 0, errs 0
          Step timer max interval 752
          MCU temperature: min 44.6, current 44.8, max 45.4
          Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: pos 0, standstill, SG min/max 10/10, read errors 0, write errors 1, ifcnt 22, reads 23088, writes 9, timeouts 0, DMA errors 0
          Driver 1: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 23088, writes 9, timeouts 0, DMA errors 0
          Driver 2: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 23088, writes 9, timeouts 0, DMA errors 0
          Driver 3: pos 0, standstill, SG min/max 14/14, read errors 0, write errors 1, ifcnt 21, reads 23087, writes 9, timeouts 0, DMA errors 0
          Driver 4: pos 0, standstill, SG min/max 14/14, read errors 0, write errors 1, ifcnt 22, reads 23088, writes 9, timeouts 0, DMA errors 0
          Driver 5: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 23088, writes 9, timeouts 0, DMA errors 0
          Driver 6: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 23087, writes 9, timeouts 0, DMA errors 0
          Date/time: 2023-10-21 16:29:37
          Cache data hit count 436204769
          Slowest loop: 2.92ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 0.5ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0 sensor: ok
          === CAN ===
          Messages queued 2288, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 1272/0/0
          Tx timeouts 0,0,1271,0,0,1015 last cancelled message type 30 dest 127
          === Network ===
          Slowest loop: 15.37ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address bc:ff:4dxxxxxxxx
            WiFi Vcc 3.38, reset reason Power up
            WiFi flash size 2097152, free heap 25600
            WiFi IP address 192.168.1.xxx
            WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            @bubblevisor you're running old firmware on 3rd party hardware. Not much we can do to help there.
            I suggest you upgrade the firmware and see how you get on
              @jay_s_uk I've just been trying to update the firmware. But no matter which .zip firmware I upload the installed version remains at 3.4.0beta.
                @bubblevisor maybe bossa the board. Who knows what changes fysetc have made to that beta version
