Duet 2 Ethernet Drive Phase B Short to ground
on my duet 2 ethernet I replaced wires and have started getting this error. I have since went back to my old wires, still got the problem. i have tried checking continuity between Black and Blue. as well as Red and Green which resulted nothing, i have checked for anything obviously bridging connections and came up empty, any ideas?
@DisabledGooru See this section for how to determine the wiring for the stepper motor: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting#using-the-internal-drivers
The wire colours to the stepper motor are not always the same, and should not be trusted. Check for continuity in the wire pairs. Reduce the current if you're not sure, using M906, to 600mA, which should avoid burning out the driver. If you have a working motor on another axis, swap it to the driver giving the error (you don't say which driver) and test.
With a short to ground error, it could be the motor has failed, and internally the motor is shorted out. Again, testing with a known-working motor would check if the Duet is okay.
undefined DisabledGooru marked this topic as a question
undefined DisabledGooru marked this topic as a regular topic
Tried it on 4 different motors, occasionally it gives a different error. but if i try again it does the same thing, i am really stumped, i am afraid it is from me redoing my wires
Do you see any damage on the drivers themselves?
This is the Driver i believe, i dont see anything wrong with it, no bridging or anything. (the bag it is on is the antistatic bag it shipped with)
@DisabledGooru said in Duet 2 Ethernet Drive Phase B Short to ground:
What is the other error?
Can you share your config.g and the results of sending M122 and M98 P"config.g" please?
Do you have an unused driver available to use instead of this one?
When and where did you purchase the Duet?
Other error is saying both phases are disconnected
i got the Duet 2 Ethernet from Filastruder June 27, 2023 i have tried it on all drivers in the house, both active and sparesm122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet Ethernet 1.02 or later
Board ID: 0JD2M-9F8TA-GJ4TD-6JKDA-3SD6L-K7PU6
Used output buffers: 1 of 26 (19 max)
Static ram: 23836
Dynamic ram: 70244 of which 0 recycled
Never used RAM 18000, free system stack 188 words
Tasks: NETWORK(ready,21.7%,242) HEAT(notifyWait,0.0%,339) Move(notifyWait,0.0%,363) MAIN(running,73.7%,458) IDLE(ready,4.5%,30), total 100.0%
Owned mutexes:
Last reset 00:00:19 ago, cause: power up
Last software reset at 2023-10-07 17:48, reason: User, GCodes spinning, available RAM 18000, slot 1
Error status: 0x00
Step timer max interval 0
MCU temperature: min 15.9, current 18.1, max 18.4
Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-10-24 18:05:43
Cache data hit count 732135033
Slowest loop: 3.48ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.4ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 11.45ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplexm98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23 -
it appears to be giving me the problem on all drives, including the extruder with both new and old wires
@Phaedrux anything else i forgot?
@droftarts
Is it normal for the area circled in yellow to all have continuity -
testing continuity with no motors plugged in on the back. with the two motors in series 2A on one port, and 2b on another port are shorted together, as well as 1a and l2, l1 and l1
