    Configuring Type 4 = sensor with microswitch
    Filament Monitor
    • demonio669undefined
      demonio669
      Re: Configuring Type 4 = sensor with microswitch
      Today I connect a microswitch to filament monitor and configured to use it ( type 4)
      I think there is a bug in the M591 D0 output it shows:
      19/10/2023, 22:53:39 M591 D0
      Duet3D rotating magnet filament monitor v4 with switch on pin io6.in, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 4, filament present, mag 132 agc 38, measured sensitivity 25.75mm/rev, min 97% max 103% ove
      19/10/2023, 22:53:03 M591 D0
      It finishes in "ove" instead in "over xxxx.xx mm"
      dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        What firmware version and Duet board are you running?
        demonio669undefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @demonio669
          @demonio669 if you are running 3.5.0-rc.1 then this has already been reported, logged and fixed. https://github.com/Duet3D/RepRapFirmware/issues/908
          T3P3 created this issue in Duet3D/RepRapFirmware
          closed M591 output truncated #908
            demonio669 @Phaedrux
            @Phaedrux
            RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.01 (SBC mode)
              @demonio669 thanks, looks like this issue affects RRF 3.4.x too.
              Edit: I've amended the source code so that this should be fixed in the next 3.4 release,
              • T3P3Tonyundefined
                T3P3Tony administrators @demonio669
                @demonio669 have you tested this in RC2?
                www.duet3d.com
                  demonio669 @T3P3Tony
                  @T3P3Tony no, i'm waiting to try it on 3.4.7 or 3.5.0 (not RC)
