No accelerometer found!
Hey there,
i bought the Duet3D Accelerometer and installed it today on my Duet 6HC Version 1.01a. Running Firmware 3.5.0 rc1.
I installed it at the TEMP Doughterboard connector, but the Accelerometer is not found.
I tried two different cables.
The green LED at the Accelerometer lights up.What did I do wrong?
@gringo do you send M955 P0 C"spi.cs1+spi.cs0" command ?
Will check it at the weekend. Thanks
It works. My fault. Thanks @demonio669
@gringo glad to help you
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
