WiFi Module Not Recognized - Duet 3 6HC Mainboard
Hi all,
I recently purchased a Duet 3 6HC Mainboard with a WiFi module. During setup, I noticed that the WiFi module didn't light up when I plugged the mainboard's USB cable.
Also, whenever I used the
M552
command, it would respond withEthernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
.I updated the mainboard's firmware to 3.4.6 and was able to successfully perform a firmware upload to the WiFi module with
M997 S1
but checking the board's network status usingM552
always mentions ethernet instead of WiFi and attempting to connect to a network results in the following error:Error: M587: Failed to add SSID to remembered list: WiFi module is disabled
I've tried the above with another WiFi module which results in identical results and the voltage drop between PWR and GND on the pins for the ESP are the correct ~3.3v.
@big_plotter_man Are you using
I1
in the M552 commands?- Send
M552 I1 S0
to take the WiFi module out of its disabled state and into idle. - Use M587 to add the SSID and password of your wifi network. Note, it does not need to be the same network that the ethernet is connected to. The WiFi interface will get its own IP address via DHCP, or you can specify what IP address to use in the M587 command.
- Send
M552 I1 S1
to enable the WiFi interface in client mode and connect to an access point that you specified using M587. SendM552 I1
orM122
to see the configured IP address. - You can add this to config.g if you want WiFi to be enabled on boot.
- Send
Need a lot more information here. For starters, the full M552 and M587 commands you're using and a photo of how you have it installed would be helpful.
I1
M552 I1 S0
- Send
M552 I1 S1
orM122
- Send
Thanks! That appears to have fixed my issue and now my MB6HC can now consistently connect to the internet.
