lost connection to sbc due to remote timeout error
  • undefined
    benecito
    We recently got an error message
    on a duet 3 mini 5+ running in SBC mode. Never saw this error before and found nothing - can anyone (@dc42) point me in the right direction?
    undefined 1 Reply Last reply 5 Nov 2023, 08:27 Reply Quote 0
    • undefined
      chrishamm administrators @benecito
      @benecito Send M122 after the timeout occurred and check what device caused the timeout (somewhere at the end of the diagnostics). If it is the SBC, probably slow IO caused the main service to hang and you'll see a timeout by the SBC. That particular error message cannot come from DSF, though.
      Duet software engineer
      undefined 1 Reply Last reply 5 Nov 2023, 15:52 Reply Quote 0
      • undefined
        benecito @chrishamm
        @chrishamm That's the M122. DWC shows disconnected so I ran it over USB. So I assume the error is also sent from the firmware and not DSF
        What are you thinking about if talking about "slow IO"?
        Recv:16:47:15.911: === Diagnostics ===
        Recv:16:47:15.911: RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1 (2023-08-31 16:16:56) running on Duet 3 Mini5plus WiFi (SBC mode)
        Recv:16:47:15.911: Board ID: 4YP38-PR6KL-K65J0-409ND-JSW1Z-RWVQQ
        Recv:16:47:15.911: Used output buffers: 1 of 40 (34 max)
        Recv:16:47:15.911: === RTOS ===
        Recv:16:47:15.911: Static ram: 102836
        Recv:16:47:15.912: Dynamic ram: 106008 of which 0 recycled
        Recv:16:47:15.912: Never used RAM 28348, free system stack 66 words
        Recv:16:47:15.912: Tasks: SBC(2,nWait,7.3%,434) HEAT(3,nWait,0.3%,323) Move(4,nWait,26.9%,255) CanReceiv(6,nWait,0.0%,939) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.1%,342) TMC(4,nWait,3.4%,74) MAIN(1,running,58.1%,822) IDLE(0,ready,0.0%,29) AIN(4,delaying,3.9%,264), total 100.0%
        Recv:16:47:15.912: Owned mutexes: USB(MAIN)
        Recv:16:47:15.912: === Platform ===
        Recv:16:47:15.912: Last reset 06:04:11 ago, cause: software
        Recv:16:47:15.912: Last software reset at 2023-11-05 10:43, reason: User, Platform spinning, available RAM 28460, slot 0
        Recv:16:47:15.912: Software reset code 0x2000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
        Recv:16:47:15.913: Error status: 0x00
        Recv:16:47:15.913: MCU revision 3, ADC conversions started 21852847, completed 21852845, timed out 0, errs 0
        Recv:16:47:15.913: MCU temperature: min 35.6, current 61.1, max 65.0
        Recv:16:47:15.913: Supply voltage: min 23.4, current 23.8, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Recv:16:47:15.913: Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/120/0, gc cycles 0
        Recv:16:47:15.913: Events: 0 queued, 0 completed
        Recv:16:47:15.913: Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 42, reads 33239, writes 19, timeouts 0, DMA errors 0, CC errors 0
        Recv:16:47:15.914: Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 42, reads 33237, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Recv:16:47:15.914: Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 42, reads 33236, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Recv:16:47:15.914: Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 42, reads 33236, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Recv:16:47:15.914: Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 36, reads 33239, writes 19, timeouts 0, DMA errors 0, CC errors 0
        Recv:16:47:15.914: Driver 5: not present
        Recv:16:47:15.914: Driver 6: not present
        Recv:16:47:15.915: Date/time: 2023-11-05 16:47:14
        Recv:16:47:15.915: Cache data hit count 4294967295
        Recv:16:47:15.915: Slowest loop: 67.66ms; fastest: 0.11ms
        Recv:16:47:15.915: === Storage ===
        Recv:16:47:15.915: Free file entries: 20
        Recv:16:47:15.915: SD card 0 not detected, interface speed: 0.0MBytes/sec
        Recv:16:47:15.915: SD card longest read time 0.0ms, write time 0.0ms, max retries 0
        Recv:16:47:15.915: === Move ===
        Recv:16:47:15.916: DMs created 83, segments created 57, maxWait 1480432ms, bed compensation in use: none, height map offset 0.000, ebfmin -1.00, ebfmax 1.00
        Recv:16:47:15.916: next step interrupt due in 1059 ticks, enabled
        Recv:16:47:15.916: Moves shaped first try 3252, on retry 15564, too short 426412, wrong shape 1142318, maybepossible 389406
        Recv:16:47:15.916: === DDARing 0 ===
        Recv:16:47:15.916: Scheduled moves 2936143, completed 2936103, hiccups 0, stepErrors 0, LaErrors 0, Underruns [340521, 0, 1], CDDA state 3
        Recv:16:47:15.916: === DDARing 1 ===
        Recv:16:47:15.916: Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        Recv:16:47:15.916: === Heat ===
        Recv:16:47:15.917: Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Recv:16:47:15.917: === GCodes ===
        Recv:16:47:15.917: Movement locks held by null, null
        Recv:16:47:15.917: HTTP* is idle in state(s) 0
        Recv:16:47:15.917: Telnet is idle in state(s) 0
        Recv:16:47:15.917: File is idle in state(s) 0
        Recv:16:47:15.917: USB is ready with "M122" in state(s) 0
        Recv:16:47:15.917: Aux is idle in state(s) 0
        Recv:16:47:15.917: Trigger* is idle in state(s) 0
        Recv:16:47:15.917: Queue* is idle in state(s) 0
        Recv:16:47:15.918: LCD is idle in state(s) 0
        Recv:16:47:15.918: SBC is idle in state(s) 0
        Recv:16:47:15.918: Daemon is idle in state(s) 0
        Recv:16:47:15.918: Aux2 is idle in state(s) 0
        Recv:16:47:15.918: Autopause is idle in state(s) 0
        Recv:16:47:15.918: File2 is idle in state(s) 0
        Recv:16:47:15.918: Queue2 is idle in state(s) 0
        Recv:16:47:15.918: Q0 segments left 1, axes/extruders owned 0x0000807
        Recv:16:47:15.918: Code queue 0 is empty
        Recv:16:47:15.919: Q1 segments left 0, axes/extruders owned 0x0000000
        Recv:16:47:15.919: Code queue 1 is empty
        Recv:16:47:15.919: === CAN ===
        Recv:16:47:15.919: Messages queued 196649, received 0, lost 0, boc 0
        Recv:16:47:15.919: Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 109257/0/0
        Recv:16:47:15.919: Tx timeouts 0,0,109256,0,0,87391 last cancelled message type 30 dest 127
        Recv:16:47:15.919: === SBC interface ===
        Recv:16:47:15.919: Transfer state: 0, failed transfers: 0, checksum errors: 0
        Recv:16:47:15.919: RX/TX seq numbers: 0/1
        Recv:16:47:15.920: SPI underruns 0, overruns 0
        Recv:16:47:15.920: State: 0, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x0dadc
        Recv:16:47:15.920: Buffer RX/TX: 0/0-0, open files: 0
        undefined 1 Reply Last reply 6 Nov 2023, 07:31 Reply Quote 0
        • undefined
          @benecito Thanks, that confirms my assumption:
          RRF lost connection to the Duet because the SBC didn't respond in time, which can happen when the SBC is temporarily overloaded. Consider exchanging the microSD card with an A1- or A2-rated card if you haven't done this already.
          undefined 1 Reply Last reply 23 Jan 2025, 07:33 Reply Quote 0
          • undefined
            Ant1 @chrishamm
            @chrishamm I have had the same issue, but with a different error code:
            State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x24d04
            Is it also related to the SBC being overloaded ?
            undefined 1 Reply Last reply 23 Jan 2025, 07:52 Reply Quote 0
            • undefined
              chrishamm administrators @Ant1
              @Ant1 Hard to say without further details. Can you please open a new thread with the full M122 output? The journal of duetcontrolserver might help, too, see https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#troubleshooting
              • undefined chrishamm locked this topic 23 Jan 2025, 07:52
