    MQTT protocol not supported by this firmware error
    • e4dundefined
      e4d
      Hello, I try to send MQTT message to a broker but I keep getting :
      Error: M586.4: MQTT protocol not supported by this firmware
      My configuration is Duet 2 Wifi running :
      Duet 2 WiFi 2WiFi 3.5.0-rc.1
      Duet WiFi Server n/a 2.1beta4
      Duet Web Control DWC 3.5.0-rc.1
      If I understand correctly I meet the requirements of M586 :
      Supported from firmware version 3.5, on Duet WiFi boards in standalone mode. Requires the WiFi interface to be running WiFi server version 2.1 or later.
      How can I solve this problem ? THanks
        dc42 administrators @e4d
        @e4d I've asked the developer of the MQTT support to look at your post.
        • gloomyandyundefined
          gloomyandy @dc42
          @dc42 @e4d SUPPORT_MQTT does not seem to be defined for the Duet 2 builds I'm not sure if that is deliberate (due to lack of memory/resources) or an error.
            dc42 administrators @gloomyandy
            @gloomyandy thanks. The reason is almost certainly insufficient RAM and flash memory on Duet 2. The MQTT support requires significant amounts of both.
            I have updated the M586.4 documentation.
