    Inconsistent track width
    Hardware wishlist
    • Avamanderundefined
      Avamander
      Is this inconsistency intended on the old 0.8.5 board (screenshot of Duet0.85.brd)?
      • T3P3Tonyundefined
        T3P3Tony administrators
        Woops, that's an error in the old board design. Is it in the Gerbers as well?
        Have a go with fitting it all into 3 layers. TBH I never considered a 3 layer board as that's pretty non standard. You need a good ground plane though.
        May I ask what your plans are?
        www.duet3d.com
          Avamander
          Haven't checked.
          Just thought for a moment about rolling with my own board, because paying more than a 2 hundred $ just sounded too steep for me so I was looking at if I could save some cost. Adding it all up (including time I'd have to spend to learn how to redesign the board to 3(or even more extreme 2)-layers without errors) I realized it's not worth it.
          EDIT: Clarified my sentence
          • T3P3Tonyundefined
            Fair enough
            I would be pretty surprised if anyone managed to make it fit on 2 layers. Also that would remove the ground plane which would be a bad idea.
            www.duet3d.com
              Avamander
              @T3P3Tony:
              Fair enough
              Would most likely mean just quite a "few" 0ohm resistors and a larger sized board (which isn't bad in terms of heat dissipation though).
