    Test cube is half the size it should be on test print.
    273
    • ecnsuppliesundefined
      ecnsupplies
      When i did my first print i did a test cube. It was 10mm all sides and should have been 20mm all side.
      I used a test paper to jog and measure in increments of 20mm and its right on the spot so i know my steps are ok.
      Any ideas on what i should try?
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Nov 16 2023 14:37:40 GMT-0600 (Central Standard Time)
      M550 P"Ender 5 Pro"                                ; set printer name
      M918 P1 E4 F2000000                                ; configure direct-connect display
      M552 P192.168.1.87 S1                              ; enable network and acquire dynamic address via DHCP
      M586 P1 S1                                         ; disable FTP
      M586 P2 S1                                         ; disable Telnet
      M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
      M569 P0.2 S0                                       ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                       ; physical drive 0.3 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X225 Y225 Z300 S0                             ; set axis maxima
      M574 X2 S1 P"io0.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
      M574 Y2 S1 P"io1.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
      M574 Z2 S2                                         ; configure Z-probe endstop for high end on Z
      M950 S0 C"io7.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 T12000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X10 Y10 Z4.05                             ; set Z probe trigger value, offset and trigger height  G31 P500 X0 Y0 Z3.75
      M557 X50:220 Y20:220 S20                           ; define mesh grid  M557 X15:215 Y15:195 S20
      M308 S0 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 R0.532 K0.167:0.000 D13.56 E1.35 S1.00 B0  ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
      M308 S1 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
      M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out9" Q500                               ; create fan 2 on pin out9 and set its frequency
      M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Nozzle-0" D0 H1 F0                       ; define tool 0
      T0						                           ; ensures a tool is selected upon start up (allowing extrusion/retraction)
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Nov 16 2023 14:37:41 GMT-0600 (Central Standard Time)
      G91                   ; relative positioning
      G1 H2 Z5 F6000        ; lift Z relative to current position
      G1 H1 X225 Y225 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X-5 Y-5 F6000   ; go back a few mm
      G1 H1 X225 Y225 F240 ; move slowly to X and Y axis endstops once more (second pass)
      G90                   ; absolute positioning
      G1 X110 Y110 F6000    ; go to first bed probe point and home Z G1 X20 Y20 F6000
      G30                   ; home Z by probing the bed
      ;G91                  ; relative positioning
      ;G1 Z5 F200           ; lift Z relative to current position
      ;G90                  ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 X-5 Y15 F3000  ; go to first probe point
      ;G3 Z5 F200       ; lift Z relative to current position
      ; bed.g
      G29  ; probe the bed and enable compensation
      • fcwiltundefined
        fcwilt @ecnsupplies
        @ecnsupplies
        Perhaps you inadvertently told the slicer to scale the print?
        P.S. And I see you are still using bed.g instead of mesh.g
        ecnsuppliesundefined 1 Reply Last reply Reply Quote 0
          ecnsupplies @fcwilt
          @fcwilt no check and told it to print 20mm on all axis. Using cura.!20231119_204958.jpg
          • fcwiltundefined
            fcwilt @ecnsupplies
            @ecnsupplies said in Test cube is half the size it should be on test print.:
            What do you mean by "told it"?
            Normally the STL you slice determines the size.
            If the STL is not too big post it here.
            Thanks?
            ecnsuppliesundefined 3 Replies Last reply Reply Quote 0
              ecnsupplies @fcwilt
              @fcwilt
              I ment to say I double checked it. The stl says it's 20mm all sides.
              See picture. This is the stick test cubes size.
                ecnsupplies
                xyzCalibration_cube.stl
                • fcwiltundefined
                  fcwilt @ecnsupplies
                  @ecnsupplies
                  OK. I don't use CURA but I fired it up and saw what you were talking about.
                  So that would seem to leave your duet configuration wrong as the problem BUT you verified movement by measuring.
                  From the DWC console execute a M579 and see what it repots.
                    ecnsupplies @fcwilt
                    Made a test pattern to measure 25mm on each axis and jogged to each. They are exact.
                      ecnsupplies @fcwilt
                      @fcwilt
                      One forum said it might be z accep and jerk are to high. Any clue were this would be?
                        ecnsupplies @fcwilt
                        @fcwilt
                        M579. Axis scale factors x1.000, y:1.000 z:1.000
                        • fcwiltundefined
                          fcwilt @ecnsupplies
                          @ecnsupplies
                          So M587 is not the culprit either.
                          I don't think your acceleration or "jerk" settings are too high. They are higher than mine but I don't think it would drastically affect the size.
                            ecnsupplies @fcwilt
                            @fcwilt
                            Duet recommend cura so that's what I installed.
                            • fcwiltundefined
                              fcwilt @ecnsupplies
                              @ecnsupplies
                              CURA is fine based on the large numbers of users.
                              I just never could get good prints out of it using it's typical settings.
                              Since my "goto" slicer works for me I have never taken to the time to work with CURA to get good results.
                                ecnsupplies @fcwilt
                                @fcwilt
                                I downloaded a different slicer and will run it tonight just so I can say I did.
                                Let you know tomorrow
