    Connecting a capacitive sensor, but not as a probe
    • awitcundefined
      awitc
      Hi!
      I am trying to set up a capacitive sensor not as a probe, but as a switch, which triggers some macro, whenever its "pressed". I am working with a Duet3 6XD, sensor information and config lines can be found below. My idea was to connect it as I have my endstops:
      brown -> 24V
      blue -> io_in_iso_neg
      black -> io_in_iso_pos
      However, this connection causes the sensor to not respond. Therefore, I did this:
      brown -> 24V
      blue -> io_GND
      black -> io_in
      With this connection, the sensor operates correctly, lighting up an LED whenever something is close to it, but the Duet3 does not recognize any change to the GPIO state:
      21.11.2023, 16:05:50 	M409 K"sensors.gpIn[1]"
          "key": "sensors.gpIn[1]",
          "flags": "",
          "result": {
              "value": 0
      When I measure the voltage of the black wire, it is 8V or 9V depending on the state of the sensor. I figure, that changes between 0 and 3,3V would be needed, but do not know what to change to make it work.
      ; proximity sensor for pellet loading system
      M950 J2 C"io8.in"
      M581 P2 T2
      fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @awitc
        @awitc
        I could not find the specs on that sensor as to what the output voltage should be in the "on/off" states.
        Perhaps it needs a resistor from the output to ground - do you have a resistor you could try as a test? Perhaps something between 1K and 10K?
        • oliofundefined
          oliof @awitc
          @awitc try enabling the pullup resistor like so
          M950 J2 C"^io8.in"
          • awitcundefined
            awitc
            The addition of "^" helped to bring the voltages to 0.7V and 3.3V respectively. I thought the pullup on the input is enabled by default. Thanks a lot!
            I found also that testing the trigger with a M117 message makes the message show up only the first time the trigger is evoked. At least in my case.
