    Duet 2/Duex driver errors
    621
    • FreddyB428undefined
      FreddyB428
      Hello fellow duet members. Brand new member here and a bit out of my depth.
      I'll keep this simple, I finished assembling my Modix 120X Gen 4 and was in the process of calibrating the machine. during hot end calibration the machine turned off and I received the following error codes:
      Event notification -
      Driver 1 error: over temperature shutdown, phase A short to ground, phase B short to ground
      • Event notification -
        Driver 3 error: over temperature shutdown, phase A short to ground, phase B short to ground
        Warning: VIN under-voltage event (7.7V)
      Currently, the Modix printer does not turn on, but when I remove the 7.5 amp fuse (that originally had a 15 amp fuse) that is for the hot end heaters and stepper motors the machine will start but have the same error codes. When the fuse is plugged back in the printer will not turn on.
      Back story, When I received the printer there was a 15 amp fuse in place of the 7.5 amp fuse, and the instructions showed a 7.5 amp fuse. Since there were many errors in the build instructions, I took it as an error and that it was in fact a 15 amp fuse for the hot end heaters and stepper motors(nowhere did it say to install fuses or check that the fuses were the correct amps). When I contacted customer support is when I found out the instructions were right and who ever put together the boards in the e box had it wrong.
      My question is do I have 2 bad duet boards? or bad stepper motors? or both? There was no popping noise, smell, smoke, or physical signs on the boards. Your help is greatly appreciated.
      Thank you,
      Will
      o_lampeundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @FreddyB428
        @FreddyB428
        Hi, you could check the stepper plugs from drive 1+3 if they are different from the others.
        Red, blue, green, black is a common wiring order, unless you have 6-wire NEMA23 steppers. Those can be wired in various ways.
        When you unplug the steppers, hotend, fans, etc. and still get the shortcut error, the board is faulty.
        FreddyB428undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @FreddyB428
          @FreddyB428 Had you already tested all motors to see if they were working? Please post your config.g, and send M115 in the console, and post the response, so we can see what firmware version you are using.
          Disconnect the DueX and test the motors on the Duet board on it's own. Incorrect driver error messages can be generated if:
          • the ribbon cable between the Duet and Duex is damaged
          • the grounding wire between them is not good (see https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#power)
          • high current wires (like heater wires) run close to the ribbon cable (which is not shielded)
          Disconnecting the Duex and testing the Duet will narrow down if the issue is one of the above, or if the Duet has actually failed.
          Regarding the fuses, there should be a 15A fuse for the heated bed, (between the VIN and bed terminals) 7.5A fuse for the heaters and stepper drivers, and a 1A fuse for the fans. Were the bed and heater/stepper drivers fuses swapped, or did you have 15A in both? If you could post a picture of the Duet, that might help.
          FreddyB428undefined 2 Replies Last reply Reply Quote 0
            FreddyB428 @o_lampe
            @o_lampe
            I Checked both plugs, driver 1 (brown yellow green white at the board) and followed it all the way to the X motor, no issues, did the same for driver 3 (primary extruder motor, white pink purple blue). Everything looks brand new. plugged and un-plugged still the same error codes without the 7.5 amp fuse. With the fuse installed I just get flashing lights.
              FreddyB428 @droftarts
              @droftarts
              I have the firmware 3.4.5. I did not test the motors prior to install, looking around the web I have found that a small number of stepper motors become faulty within a few hours of use, but this maybe had 5 minutes of calibration run time. I'll pull the config.g and the M115 code here shortly and then follow your steps of diagnosis.
              Regarding the fuses, there were 2 15 amp fuses and only 1 7.5 amp fuse. I'll also get a picture of the board once I get a chance. Thank you for the help.
                FreddyB428
                  FreddyB428
                  I found a wire swap that came pre-installed. the E1 and E0 wires on the duet were swapped. I'm not sure if this helps. I just swapped them into their original location.
                    @droftarts
                    I Disconnected the DueX and the error codes when away. There are no other error codes. I inspected the ribbon cable and it looks good. no physical signs of damage.
                    I inspected the grounding wire and cleaned both end on the Duet and DueX.
                      @FreddyB428 said in Duet 2/Duex driver errors:
                      Is that with the motor unplugged, or the ribbon cable to the Duex unplugged?
                      Which lights are flashing?
                      are all the DUEX board lights supposed to be red?
                      Those are the endstop lights. They can be on when the endstop is triggered, and of when it is not triggered, or vice versa, depending how the endstop is configured.
                      That's good, it sounds like the problem is the Duex end, at least.
                      In your picture, there is no fuse in the Duex? There should be a 7.5A fuse behind the VIN power connector. Without that, it's drawing power from the Duet, which may be dragging the voltage down and causing the errors.
                        @droftarts
                        @droftarts said in Duet 2/Duex driver errors:
                        It is with the motor unplugged.
                        all lights on the Duet 2 and DueX
                        Ack. I just wasn't sure what to make of all the lights.
                        Correct there was no fuse in the DueX, Which was the only way to turn the printer on.
                        Since I thought it was the Duex that was the issue I unplugged everything except the ribbon connector and started plugging in everything one by one and turning the machine on until it wouldn't start. It started on all wires plugged in except for the last cable that connects to the secondary hot end fan (HF1).
                        So can I assume that the DueX is not the issue, and it is the Hot end fan wire/fan itself?
                          Possibly. It sounds like it might have a dead short, so shorting out VIN power, possibly dragging the power down on the Duet. It might still be the Duex, though ie if the MOSFET on the fan connector has failed. Also check underneath the boards to check nothing is touching the pins on the back.
                          Does disconnecting that fan mean you can put the 7.5A fuse back in the Duex and it works now?
                            Yes.
                              FreddyB428 @FreddyB428
                              @o_lampe, @droftarts you both have been so helpful. Thank you so much.
                                FreddyB428
                                Since it was the heater fan, I pulled it off and found the problem.shorted wires.jpg
                                Wires made contact with the hot-end. Thank god that's the only issue.
                                  @FreddyB428 Phew, a lucky escape!
                                  Note that fans and heaters that are controlled by a MOSFET have the MOSFET on the GND side, ie voltage is flowing to them all the time, just waiting for a chance to short to ground. Unfortunately, this is just the way MOSFETs work; they need to be after the load, not before.
                                  Hopefully the rest of the build goes a bit smoother now!
                                    @droftarts
                                    Thank you, I'll remember that for next time. you both as well as this forum have been beyond helpful. Can't wait to get this printer running!
