    Filament monitoring attached to U axis on
    Filament Monitor
    479
    • Duet_loverundefined
      Duet_lover
      Can someone please help me to attach filament monitoring sensor specifically Bigtreetech on U axis or on E1 axis.
      Initially I trying to map the driving system like
      M584 X0 Y1 Z2 E3:4
      Where E3 is used for E0 extruder and E4 drive for E1 extruder.
      I want to control both extruder separately (independent to each other)
      For that i send G code G1 E100 then extruder extruder E0 start extruding filament but i am not able to find G code which can second extruder attached to E1.
      Can some one help me to do so,....
      After failure to control second extruder Seperately i assign the E1 drive to U axis where I can control it as per my requirement by using G code such as G1 U 100.
      But the problem is that i am not able attach filament sensor BTT on U axis.
      Can some one please help me.
      Here is the my drive maping code
      M584 X0 Y1 Z2 E3 U4
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Duet_lover
        @India you can only use filament monitors with extruders. i.e. they can't be assigned to other axis such as U
          droftarts administrators @Duet_lover
          @India Define a tool that uses both extruders, then use something like G1 E100:0 to extrude from one, and G1 E0:100 to extrude from the other. Alternatively, set it up as a mixing extruder with M567, and adjust the mixing ratio before extrusion.
          From G1 notes:
          Where a tool has more than one extruder drive then Ennn:nnn:nnn etc is supported to allow for the individual movement of each to be controlled directly. This overrides the extruder mix ratio set with M567
          Duet_loverundefined 1 Reply Last reply Reply Quote 0
            Duet_lover @droftarts
            @droftarts thanks for your quick response
            Can you please tell me, how to define a tool that uses both extruder
              @India See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m563-define-or-remove-a-tool, particularly the description of the D, H and F parameters.
              Example:
              M563 P2 D0:1 H1:2 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2,  and fan mapped to fans 0 and 2
                @droftarts thanks for your help.
                As per your suggestion, I am able to configure two extruder E0 and E1 .1.PNG .
                M563 P0 D0:1
                G10 P0 R0 S0
                T0:1 ; tool
                After this I tried to monitor the filament runout using sensor BIGTREETECH by inserting the code in config.g as
                M591 D1 P7 C"e1stop" L7 R50:200 E5 S1 ;configure BTT smart filament sensor
                M591 D1 ; display filament sensor parameters for extruder drive
                where i have attached it to "e1stop" and run a two line g-code from SD card as
                G1 E0:50 F180
                G1 E0:-50 F180
                i found error shown in figure.
                M591 D0 shows that there is no sensor (here I don't want to monitor the filament as it used for extruding liquid)
                M591 D1- shows the sensor attached to it and where I want to monitor the filament.
                so based on above can some one guide me
                  @India What firmware version are you running? Send M115 in the console, and post the response.
                    please find the response of M115
                      @India Please update to 3.4.6 and test again.
                        @droftarts Thanks, I have updated the firmware to 3.4.6. Now it is not showing the problem as I was facing in old version.
                        Now filament sensor showing no calibrated data only as shown below
                        I have tried printing two line code from SD card (G1 E0:200; G1E0:-200) but it is not able to calibrate.
                        The code I have used to configure the sensor is
                        M591 D1 P7 C"e1stop" L7 R50:200 E22 S1
                        I am little confused about the R and E value , can u please suggest me how to get these value
                          Duet_lover @Duet_lover
                          @India said in Filament monitoring attached to U axis on:
                          @droftarts please help me out.
                            @India I don't have a BigTreeTech filament monitor to test, it isn't manufactured by us, and I don't know if the way you have set it up is correct. Please refer to the BigTreeTech documentation, or at very least provide a link to it so I know which version you have: BTT have produced two, V1 and V2, which do you have?
                            According to the documentation here, the configuration should be:
                            V1 (which appears to be what you have, and have set)
                            M591 D1 P7 C"e1stop" L7 R75:125 E22 S1
                            V2
                            M591 D1 P7 C"e1stop" L2.88 R75:125 E9 S1
                            If your configuration is correct, I don't know how many points counts as calibrated, but I doubt just extruding and retracting 200mm is enough to calibrate it. It really needs to start a print, so enough data can be collected, particularly if you are using a V1, which has larger distance between points sampled. Use the E parameter suggested; the R parameter is just for how sensitive you want the monitor to be.
                              @droftarts thank you sir.
                                @India Did you get it working? If so, please let us know, and what steps you took, so the information is here for other people, and so I can mark the thread as solved.
