    Feedrate reformatting post script
    3D Printing General Chat
    • justinkgundefined
      justinkg
      I am looking for help with writing a post process script to adjust the formatting of the feedrate call outs from PrusaSlicer.
      Right now the format is like this:
      1 G1 E.1 F2400
      2 ;TYPE:Skirt/Brim
      3 ;WIDTH:1.7
      4 G1 F4799.988
      5 G1 X487.836 Y463.711 E.82895
      But this causes issues where my machine doesn't recognize the G1 F4799.988 command and maintains the feed rate of F2400 from line 1.
      I need it to look something like this (which comes from Simplify3D, but I want to use organic tree supports).
      6 G1 Z0.900 F1800
      7 G1 X483.600 Y469.844 F21000
      8 G1 X490.044 Y463.400 E4.6282 F3600
      9 G1 X549.956 Y463.400 E35.0570
      Any help would be appreciated.
      jay_s_ukundefined OwenDundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @justinkg
        @justinkg it would be better to tell us what firmware you are running so the "bug" can be addressed rather than trying to fix the output.
        Lots of people use prusaslicer.
        A sample gcode file would also b e helpful
        • justinkgundefined
          justinkg
          The machine uses a yaskawa controller and apparently how it interprets the gcode is part of the firmware. No way for me to change anything in there. The slicer firmware is RepRap/Sprinter.
            jay_s_uk @justinkg
            @justinkg oh, so nothing to do with RRF. You're just after general help. gotcha
            • Phaedruxundefined Phaedrux moved this topic from Gcode meta commands
            • justinkgundefined
              justinkg
              Yeah. From what I can gather. I need to write a script to go through the entire gcode and automate moving the feedrate to the end of the following line. I am going to try to write it in python, but its been a while.
              • OwenDundefined
                OwenD @justinkg
                @justinkg
                Just a guess as I have no experience with Yaskawa controllers.
                However some CNC controllers accept a feed rate command on its own
                So try changing
                G1 F3600
                to
                F3600
                • justinkgundefined
                  justinkg
                  I was able to write a script in python that does what I want. Posting it here for others to reference if needed.
                  import sys
                  import re
                  flag = False
                  out = open('YOUR FILE NAME HERE'+'_adjusted'+'.gcode', 'w')
                  with open('YOUR FILE NAME HERE.gcode') as f:
                  for r in f:
                  if re.search('G1 F', r):
                  feedrate = r[3:]
                  flag = True
                  print(r[:-1] + ' ' + feedrate) # get rid of new line
                  elif flag:
                  r = r[:-1] + ' ' + feedrate
                  out.write(r)
                  flag = False # Reset flag
                  else:
                  out.write(r)
