    UVWABCDabcdefghijkl - axis is not showing up
    490
    • Aurimasundefined
      Aurimas
      so it is me again.
      I am trying to setup multiple axis - just standard cartesian setup
      Firmware 3.4 6XD board + 1XD
      trying to use pretty much all axis from UVWABCDabcdefghijkl - axis is not showing up
      all I get is is up to D, XYZABXCDUV that are working and the rest are not showing up
      what am I doing wrong?
      I have all enstops configured - they are not showing up
      Matrix is shoeing only those axis and not the rest
      any advice would be much appreciated
      M122 and the config files are below:
      M122
      RepRapFirmware for Duet 3 MB6XD version 3.4.6 (2023-07-21 14:11:58) running on Duet 3 MB6XD v1.01 or later (standalone mode)
      Board ID: 0JD2M-999AL-D2PS0-6J9D2-3SJ6Q-15M33
      Used output buffers: 3 of 40 (24 max)
      Static ram: 151692
      Dynamic ram: 95132 of which 0 recycled
      Never used RAM 100920, free system stack 200 words
      Tasks: NETWORK(ready,77.7%,173) ETHERNET(notifyWait,0.1%,324) HEAT(notifyWait,0.0%,373) Move(notifyWait,0.0%,214) CanReceiv(notifyWait,0.1%,773) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,352) MAIN(running,22.0%,1152) IDLE(ready,0.1%,29), total 100.0%
      Owned mutexes: LwipCore(NETWORK)
      Last reset 00:23:52 ago, cause: software
      Last software reset at 2023-12-16 16:07, reason: User, GCodes spinning, available RAM 101524, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 5013
      MCU temperature: min 39.6, current 40.1, max 40.6
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.3, current 12.3, max 12.4, under voltage events: 0
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/152/152, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: ok
      Driver 1: ok
      Driver 2: ok
      Driver 3: ok
      Driver 4: ok
      Driver 5: ok
      Date/time: 2023-12-16 16:31:40
      Slowest loop: 34.35ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 3.2ms, write time 55.3ms, max retries 0
      DMs created 125, segments created 3, maxWait 225383ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 72, completed 72, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 72], CDDA state -1
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 7912, received 183849, lost 0, boc 0
      Longest wait 8ms for reply type 6036, peak Tx sync delay 272, free buffers 50 (min 49), ts 7161/7160/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 68.58ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      State: active
      Error counts: 0 0 0 1 1 0
      Socket states: 5 3 2 2 2 0 0 0
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      ; Default config.g template for DuetPi
      ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
      ; Enable network
      if {network.interfaces[0].type = "ethernet"}
          M552 P169.254.112.5 S1
      else
          M552 S3
      ;Enable PanelDue
      M575 P1 S1 B57600
      G4 S2
      M584 R0 X20.0 Y21.0 Z30.0 U31.0 V40.0 A41.0 B50.0 C51.0 D60.0 a61.0 c31.0 d41.0 e51.0 f71.0 i81.0 h91.0
      M569 P21.0 S1                                        ; physical drive 0.0 goes forwards
      M569 P20.0 S0                                        ; physical drive 0.1 goes forwards
      M569 P31.0 S1
      M569 P30.0 S0
      M569 P41.0 S1
      M569 P40.0 S0
      M569 P51.0 S1
      M569 P50.0 S0
      M569 P61.0 S1                                        ; physical drive 0.0 goes forwards
      M569 P60.0 S1
      M569 P71.0 S1                                        ; physical drive 0.0 goes forwards
      M569 P70.0 S1
      M569 P81.0 S1                                        ; physical drive 0.0 goes forwards
      M569 P80.0 S1
      M569 P91.0 S1                                        ; physical drive 0.0 goes forwards
      M569 P90.0 S1
      M92 X26.67 Z26.67 V26.67 B26.67 Y80.00 U80 A80 C80 D26.67
      M92 a26.67 ;F26.67 G80.0 H80.0 I80.0 J80.0 K80.0 L80.0 								;steps per mm
      M566 X2000.00 Y4000.00 U2000 V2000 A2000 B4000 C2000 D4000
      M566 a2000 Z4000 ;I4000 D2000 J4000 E2000 K4000 F2000 L4000
      M203 X10000.00 Z10000 Y10000.00 U10000.0 V10000.0 A10000 B10000 C10000 D10000
      M203 a10000 ;I10000 D10000 J10000 E10000 K10000 F10000 L10000
      M201 X2000.00 Y4000.00 U2000 Z2000 V2000 A2000 B4000 C2000 D4000
      M201 a2000 ;I4000 D2000 J4000 E2000 K4000 F2000 L4000
      M574 X2 S1 P"!20.io1.in"
      M574 Y1 S1 P"!21.io1.in"
      M574 Z2 S1 P"!30.io1.in"
      M574 V2 S1 P"!40.io1.in"
      M574 B2 S1 P"!50.io1.in"
      M574 U1 S1 P"!31.io1.in"
      M574 A1 S1 P"!41.io1.in"
      M574 C1 S1 P"!51.io1.in"
      ;M574 C2 S1 P"!50.io1.in"
      ;M574 D1 S1 P"!70.io1.in"
      ;M574 a1 S1 P"!80.io1.in"
      ;M574 F1 S1 P"!90.io1.in"
      ;M574 G1 S1 P"!31.io1.in"
      ;M574 H1 S1 P"!41.io1.in"
      ;M574 I1 S1 P"!51.io1.in"
      ;M574 J1 S1 P"!71.io1.in"
      ;M574 K1 S1 P"!81.io1.in"
      ;M574 L1 S1 P"!91.io1.in"
      M208 S1 X-90 U-90 V0 Y0 A-90 B-90 C-90 D-90 a-90 ;F-90 G0 H0 I0 J0 K0 L0 S1                                     ; set axis minima
      M208 S0 X90 U90 V150 Y150 A90 B90 C90 D90 a90 ;F90 G150 H150 I150 J150 K150 L150 S0
        dc42 administrators @Aurimas
        @Aurimas GCode is case insensitive, so you need to represent lower case letters by prefixing them with a single quote character, for example:
        M584 'a2.0
        Aurimasundefined 1 Reply Last reply Reply Quote 0
        • Aurimasundefined
          Aurimas @dc42
          @dc42 great - thank you. I will give it a go.
          while I got you - am I correct that 3.4 version supports mroe axis than the 3.5?
          what the reason to reduce the support?
            @Aurimas maximum axes on the 6XD is 15 in 3.4.x and 30 in 3.5.x.
            • Aurimasundefined
              Aurimas @dc42
              @dc42 I am confused.
              in the docs it has less axis in 3.5 than it is in 3.4
              U, V, W, A, B, Cnnn Driver number(s) for additional axes U, V, W, A, B and C (UVW available in RepRapFirmware 1.16 and later; UVWABC available in RepRapFirmware 1.19 and later; UVWABCD available in RepRapFirmware 3.0 and later; UVWABCDabcdefghijkl available in RepRapFirmware 3.3 and 3.4, Duet 3 MB6HC and MB6XD only; UVWABCDabcdef available in RepRapFirmware 3.5 and later, Duet 3 MB6HC and MB6XD only).
              also in the docs says 15 movement axis + 8 extruders I believe. So I assume this part is outdated.
                @Aurimas I have corrected the M584 documentation.
                Where do the docs specify a limit of 15 axes + 5 extruders?
                droftartsundefined Aurimasundefined 2 Replies Last reply Reply Quote 0
                  droftarts administrators @dc42
                  @dc42 Here: https://docs.duet3d.com/User_manual/RepRapFirmware/RepRapFirmware_overview#firmware-configuration-limits
                  Is it that there are more axis names available than axes that can be set, ie not all can be used at once?
                  UVWABCDabcdefghijkl available in RepRapFirmware 3.3 and later
                  In 3.3 and 3.4, there are 22 axis labels, XYZUVWABCDabcdefghijkl, but a maximum of 15 axes.
                  additionally mnopqrstuvwxyz are available in RepRapFirmware 3.5 and later on Duet 3 MB6HC and MB6XD only
                  In 3.5, there are 36 axis labels, XYZUVWABCDabcdefghijklmnopqrstuvwxyz, but a maximum of 30 axes.
                  • Aurimasundefined
                    Aurimas @dc42
                    @dc42 also your correction states 15
                    The maximum number of axes supported on Duet 3 MB6HC is increased to 15 in RRF 3.3 and later. Axis letters abcdefghijkl may be used in addition to XYZUVWABCD. Because GCode is normally case insensitive, these must be prefixed with a single quote character in GCode commands. For example, M584 'A1.2 would assign axis 'a' to driver 1.2, and G1 'A10 would move the 'a' axis to the 10mm or 10 degree position (or by 10mm or 10 degrees if in relative mode).
                      @Aurimas thanks. I hadn't noticed that the notes about M584 mentioned the maximum number of axes supported. I have removed that mention and updated the table that @droftarts linked to in his post.
                      • Aurimasundefined
                        Aurimas @dc42
                        @dc42 thanks.
                        you probably should update this as well
                        MaxAxesPlusExtruders 25
                          @Aurimas said in UVWABCDabcdefghijkl - axis is not showing up:
                          @dc42 thanks.
                          Where is that?
                            @dc42 said in UVWABCDabcdefghijkl - axis is not showing up:
                            @dc42 thanks.
                            Where is that?
                            Aurimasundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • Aurimasundefined
                              Aurimas @droftarts
                              This post is deleted!
                                dc42 administrators @droftarts
                                Thanks, now corrected.
                                • Aurimasundefined
                                  Aurimas @dc42
                                  @dc42 thank you
