    oibject model "status" dcos.
    Documentation
    • Tinchusundefined
      Tinchus
      Hello. I have checked https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation#statestatus
      I see "printing" status is not there anymore. It has been replaced for what other value?
      his property may be one of the following:
      disconnected: Not connected to the Duet
      starting: Processing config.g
      updating: The firmware is being updated
      off: The machine is turned off (i.e. the input voltage is too low for operation)
      halted: The machine has encountered an emergency stop and is ready to reset
      pausing: The machine is about to pause a file job
      paused: The machine has paused a file job
      resuming: The machine is about to resume a paused file job
      cancelling: Job file is being cancelled
      processing: The machine is processing a file job
      simulating: The machine is simulating a file job to determine its processing time
      busy: The machine is busy doing something (e.g. moving)
      changingTool: The machine is changing the current tool
      idle: The machine is on but has nothing to do
      jay_s_ukundefined OwenDundefined 2 Replies Last reply Reply Quote 1
        jay_s_uk @Tinchus
        @Tinchus processing
        • OwenDundefined
          OwenD @Tinchus
          @Tinchus
          Political correctness has spread even to RRF.
          In the spirit of inclusiveness , you must now use "processing" in deference to those machines that do not identify as "printers" 😉
          Tinchusundefined 1 Reply Last reply Reply Quote 5
          • Tinchusundefined
            Tinchus @OwenD
            @OwenD In RRF too????? Noooooooooooooooooooooooooooooo jajajajaja
            Thanks all for the clarification
