Managed to mess up my config
I went to add a new trigger height to config.g but couldn't see it (It must have been there but I've had a busy day)
I used the config tool and messed up my config - totally my fault. I used the config.bak to get config.g back but a number of files have been changed. The ones causing me issues just now are the home files. Trying to home x,y or z gives
My printer is a home made corexy with dual z axis and bltouch. It's a Duet2 wifi. Firmware is Duet Web Control 3.5.0-rc.1
Any help getting me back running would be most appreciated.
G28 Y Error: in file macro line 6: G1: insufficient axes homed My homimg files are;
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.4.0 on Fri Dec 22 2023 15:58:50 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning G1 S2 Z5 F6000 ; lift Z relative to current position G1 S1 X-205 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 S1 X-205 F360 ; move slowly to X axis endstop once more (second pass) G1 S2 Z-5 F6000 ; lower Z again G90 ; absolute positioning ; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.4.0 on Fri Dec 22 2023 15:58:50 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning G1 S2 Z5 F6000 ; lift Z relative to current position G1 S1 Y-205 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 S1 Y-205 F360 ; move slowly to Y axis endstop once more (second pass) G1 S2 Z-5 F6000 ; lower Z again G90 ; absolute positioning ; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.4.0 on Fri Dec 22 2023 15:58:50 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning G1 S2 Z5 F6000 ; lift Z relative to current position G1 S1 Z136 F1800 ; move Z up until the endstop is triggered G92 Z131 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning ; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.4.0 on Fri Dec 22 2023 15:58:50 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning G1 S2 Z5 F6000 ; lift Z relative to current position G1 S1 X-205 Y-205 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 S1 X-205 ; home X axis G1 S1 Y-205 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 S1 X-205 F360 ; move slowly to X axis endstop once more (second pass) G1 S1 Y-205 ; then move slowly to Y axis endstop G1 S1 Z136 F360 ; move Z up stopping at the endstop G90 ; absolute positioning G92 Z131 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning ; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 23 2019 16:28:56 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hypercube Elite" ; set printer name M669 K1 ; select CoreXY mode M575 P1 S1 B57600 ; Setup PanelDue ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Orbiter filament sensor M950 J1 C"^connlcd.encb"; define logical input for filament auto load M581 P1 T2 S0 R0 ;define trigger for filament auto load triggers trigger2.g M950 J2 C"^connlcd.enca"; define logical input for filament unload M581 P2 T3 S0 R0 ; define trigger for filament auto load triggers trigger3.g ; Accelerometer M955 P0 C"spi.cs2+spi.cs1" I16 ; all wires connected to temp DB connector, no temperature daughterboard ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes backwards M569 P4 S0 ; physical drive 4 goes backwards M584 X0 Y1 Z2:4 E3 ; set drive mapping M671 X0:200 Y0:0 S1 ; leadscrews at left (connected to Z) and right (connected to M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X80 Y80 Z3200:3200 E690 ; set steps per mm M566 X900.00 Y900.00 Z12.00:12.00 E300 ; set maximum instantaneous speed changes (mm/min) e was 40 M203 X9000.00 Y9000.00 Z180.00 E7200.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z20.00:20.00 E3000 ; set accelerations (mm/s^2) e was 250 M906 X1000 Y1000 Z800:800 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent ;M572 D0 S0.02 ;pressure advance – to be calibrated M207 S1.5 F7200 Z0.2 ;firmware retraction M84 S30 ; Set idle timeout ;M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation ;M92 X80 Y80 Z3200:3200 E685 ; set steps per mm ;M566 X900.00 Y900.00 Z12.00:12.00 E300 ; set maximum instantaneous speed changes (mm/min) e was 40 ;M203 X9000.00 Y9000.00 Z180.00 E3600.00 ; set maximum speeds (mm/min) ;M201 X4000.00 Y4000.00 Z20.00:20.00 E600 ; set accelerations (mm/s^2) e was 250 ;M906 X1000 Y1000 Z800:800 E450 I30 ; set motor currents (mA) and motor idle factor in per cent ;M84 S30 ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X200 Y190 Z150 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop ; Filament Runout Sensor ;M591 D0 P2 C"e0_stop" S1 ; filament monitor connected to E0_stop ;M591 D0 P7 C"e0_stop" S0 E1216.9 L0.152 R3:65 A1 ; Z-Probe M950 S3 C"exp.heater3" ; create servo pin 3 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-25.6 Y18.8 Z3.7 ; set Z probe trigger value, offset and trigger height M557 X30:170 Y30:170 P6:6 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S285 ; set temperature limit for heater 1 to 285C M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.1 ; Custom settings are not defined M501 ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Paddy said in Managed to mess up my config:
> M584 X0 Y1 Z2:4 E3 ; set drive mapping > M671 X0:200 Y0:0 S1 ; leadscrews at left (connected to Z) and right (connected to > M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation > M92 X80 Y80 Z3200:3200 E690 ; set steps per mm > M566 X900.00 Y900.00 Z12.00:12.00 E300 ; set maximum instantaneous speed changes (mm/min) e was 40 > M203 X9000.00 Y9000.00 Z180.00 E7200.00 ; set maximum speeds (mm/min) > M201 X2000.00 Y2000.00 Z20.00:20.00 E3000 ; set accelerations (mm/s^2) e was 250 > M906 X1000 Y1000 Z800:800 E1200 I10 Most likely cause at a quick glance is that you've used the colon separator with multiple values for the Z axis. You've assigned two motors but M350, M92, M566, M203, M201 and M906 are per axis commands, not per motor. So remove the colons and second values.
your homing files are also using G1 S1/S2 moves which is no longer supported and hasn't been for quite some time, they're used for laser moves now. You should use G1 H1/H2 moves instead.
@Phaedrux Many thanks. Changing the S to H in the homing files sorted it.
So, I'm up and running (sort of) but I have a lot of files in my system folder. The is a corexy with an bltouch and a duet3d accelerator.
Apart from config.g, bed.g, and my x, y, z, all homing files, what else do I need?
I'm wanting to get it to a 'clean' state. So I am trying to get it to 3.5.0 Release Candidate 2. However I am getting the following
Incompatible software versions The installed software versions do not match. Please operate your setup only at equal versions to avoid potential incompatibilities and unexpected errors. In general it says Duet Web Control 3.5.0-rc.2
M122 returns
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.1 (2023-08-31 16:16:15) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J1F8-3SN6L-1VNZG Used output buffers: 1 of 26 (18 max) === RTOS === Static ram: 23076 Dynamic ram: 76636 of which 12 recycled Never used RAM 13420, free system stack 184 words Tasks: NETWORK(2,nWait,15.5%,218) ACCEL(6,nWait,0.0%,348) HEAT(3,nWait,0.0%,329) Move(4,nWait,0.0%,364) MAIN(1,running,84.0%,743) IDLE(0,ready,0.5%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:03:19 ago, cause: reset button or watchdog Last software reset at 2023-12-23 11:04, reason: User, Gcodes spinning, available RAM 13420, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 22.9, current 23.4, max 24.0 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-12-23 11:13:39 Cache data hit count 4294967295 Slowest loop: 6.59ms; fastest: 0.20ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Network === Slowest loop: 15.09ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 1.27 MAC address cc:50:e3:4a:b8:38 Module reset reason: Turned on by main processor, Vcc 3.38, flash size 4194304, free heap 25760 WiFi IP address 192.168.2.124 Signal strength -60dBm, channel 0, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 Grateful for any assistance.
Try uploading the bin file for 3.5 RC2
https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.0-rc.2/Duet2CombinedFirmware.bin
@Phaedrux I had tried that, but tried again anyway, unfortunately, it still gives the massage after it reconnects.
@Paddy
Update the wifi server
I seem to remember seeing that error during the upgrade (between uploading the three files - duet, DWC, Wifi)
The WiFi module firmware included here is version 2.1beta6. -
@OwenD said in Managed to mess up my config:
@Paddy
The WiFi module firmware included here is version 2.1beta6.Thanks. That sorted it. I had to erase my duet2 wifi as any wifi firmware newer than 1.27 wouldn't work. erasing everything and using bosso to get started got it sorted.
