    controlling (multiple) closed loop steppers
    • lazy_mosquitoundefined
      lazy_mosquito
      Is it possible to control closed loop steppers with the 6HC, 6XD or the 3HC expansion board, or is this only possible with the 1HCL expansion board?
      • fcwiltundefined
        fcwilt @lazy_mosquito
        @lazy_mosquito
        The 6XD is designed for that sort of use.
        lazy_mosquitoundefined 1 Reply Last reply Reply Quote 0
          lazy_mosquito @fcwilt
          @fcwilt Problem: I have a delta build which will use the 6XD and 3 servos for the arms and i need at least 1 normal stepper and 1 to 2 steppers with an encoder connected to my extruder, and as far as i can see in the documentation the 6XD doesn't support normal steppers and only the 1HCL supports the encoding signal. I would prefer to have one expansion card which supports multiple standard and encoded steppers instead of 1 tool board 1LC and 2 1HCL boards. thats why i was wondering if the 3HC board could deliver this
          • fcwiltundefined
            @lazy_mosquito
            You can easily have one 6HC and one 6XD in a system. More than two 6xx boards is a bit of work.
            You can add 3HC, 1HCL, etc to the pair of 6xx boards.
              @fcwilt Thanks, this solves my problem for the normal steppers and the servos, but not the use of encoders. At this moment i found only the 1HCL capable of using a stepper with encoder, or is there also a way to get this functionality with one of the other boards?
              • fcwiltundefined
                @lazy_mosquito
                You can get a controller with encoder equipped stepper and drive the controller with the 6XD.
                  @fcwilt Thanks, that answers all my questions. I will indeed go that route: the 6XD for all servos and closed loop steppers. and if i have a normal stepper i can always choose to use the 3HC addon or the tool card or an extra external driver. Solved.
