Connecting fans to "OUT1" or "OUT2"
I've got a two "larger" 2pin blower 24v/12w (dual ballbearing variant) fans inbound i plan to use as AUX print cooling fans.
Issue is however i'm running short on fan outputs on the Duet 3 Mini, so i was wondering if i could use "OUT2" to run both these?
You mean in parallel?
The code should be:
M950 F{fan number} C"out2" Q25000 ; create fan {fan number} on pin out2 and set its frequency M106 P{fan number} S0 H-1 C"Heater controlled fans" ; set fan {fan number} value. Thermostatic control is turned off
where {fan number} is the number you prefer
@Mr-Yod Yeah in parallel, I know how to structure the code but I was curious if it might be any drawbacks to running fans on any of those outputs since they're "earmarked" for heaters
Should have worded myself better probably🙈
@Exerqtor
They are marked for heaters because they can output a much higher current than other output terminals.AFAIK there aren't drawbacks whatsoever and in your case it's also desireable since those fans draw a lot of current.
The other solution would be to use an external relais with a standard fan output (of which you are running short)
@Exerqtor there's no issues running fans on heater outputs
undefined Exerqtor marked this topic as a question
undefined Exerqtor has marked this topic as solved
