    macro debugging?
    • wayneosdiasundefined
      wayneosdias
      Is it possible to single step through a macro or an extension that will import a macro and allow you to execute commands line by line?
      jay_s_ukundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @wayneosdias
        @wayneosdias I don't believe so, other than manually issuing each line
        wayneosdiasundefined 1 Reply Last reply Reply Quote 0
          wayneosdias @jay_s_uk
          @jay_s_uk
          Thanks. It probably wouldn't help much of the community if there was. I need to manually motion plan 4 axis machines for gasketing /sealing processes. In searching the forum for edge finding routines, posters doing similar would benefit from a 'step-through' macro mechanism.
          I can easily write a winform/excel file importer/serial sender, but thought a baked in DWC extension capable of the same would be nice. Currently I just copy/paste to the DWC dashboard sender. It works, but is clumsy and requies I keep a redundant text file copy that needs to be reconciled with the actual macro stored on the machine.
            @wayneosdias looks like step through is on the feature request list but it doesn't have a milestone added yet.
            https://github.com/Duet3D/RepRapFirmware/issues/705
            T3P3 created this issue in Duet3D/RepRapFirmware
            open Single stepping through macros and job files #705
            • zaptaundefined
              zapta @wayneosdias
              You can write a macro that will wait for some user action and then call it from the places where you want to stop halt your tested macro.
              https://forum.duet3d.com/topic/12897/wait-for-input
              https://docs.duet3d.com/User_manual/Reference/Gcodes
