    while command not work properly while printing
    Gcode meta commands
    • FBGundefined
      FBG
      Re: How to make a loop of a Output_Pin ON and OFF?
      Sorry for late response...
      If i try the code (inside daemon.g):
      while state.status  != "printing"
          M42 P1 S1
          G4 S2
          M42 P1 S0
          G4 S10
      Works properly as the code said.
      But i want that works while i am printing so... i use:
      while state.status  != "idle"
          M42 P1 S1
          G4 S2
          M42 P1 S0
          G4 S10
      If I start printing a file, it seems that the Duet3 6HC can't do two things at the same time... The duet can't make any movement and while it does it it loops.
      Activates or deactivates the port sometimes during line changes.
      It's like not having multitasking... one task to make the loop and another task to make movements...
      Surely it can be done, but I don't know how...
      Thank you!
      gloomyandyundefined timschneiderundefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @FBG
        @FBG said in while command not work properly while printing:
        Can you explain a little more about what exactly you mean by this?
        • timschneiderundefined
          timschneider @FBG
          @FBG
          M42 is queued in the movement queue, so you can try to bypass the queue:
              M42 P1 S{1}
              G4 S2
              M42 P1 S{0}
              G4 S10
          maybe this helps.
          FBGundefined 1 Reply Last reply Reply Quote 0
          • FBGundefined
            FBG @timschneider
            @gloomyandy I mean turn on/off the output relay
            @timschneider thank you!!! now work properly!!
            • timschneiderundefined timschneider referenced this topic
