RRF config tool and motor current
i just found out that the config bundle is not correct
in the tool when i look at motor currents it says
; NOTE: This is later generated in the Axes and/or Extruders section
M906 X1400 Y1400 Z1400 E1200 ; set motor driver currentsbut that is nowhere to be found in the generated config.g hence nothing will move
@boelle one for @chrishamm
@boelle are you sure? I’ve just done the same thing, and get M906 in for the axes and extruders in the expected place:
; Axes M584 X0.0 Y0.1 Z0.2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X1400 Y1400 Z1400 ; set axis driver currents M92 X80 Y80 Z400 ; configure steps per mm M208 X0:200 Y0:200 Z0:200 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders M584 E0.3 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E420 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2)
Make sure you’re using an up to date version of the config tool, rather than a cached one, by refreshing the page in your browser.
i started using it yesterday so it was not in the cache before that
EDIT: i did a ctrl+f to open a search window... no M906
but yeah i can copy it from config tool and insert as cutom command in the config tool and it gets written
odd i know
@boelle actually, you are right. I think it is not putting in M906 when the board is Duet 2 WiFi. It also allows you to choose stealthchop, when Duet 2 WiFi/Ethernet doesn’t support it. For @chrishamm to fix!
@droftarts ahh....
BIG box with this text:
This version of the Config Tool is still under development. If you encounter problems, please consider using the previous Config Tool instead.
so partly error 40
@boelle Thanks for reporting it, it's now fixed in v3.5.0-rc2+5.
@chrishamm The new config tool is still letting me choose stealthchop when Duet 2 WiFi/Ethernet/SBC is selected as board type. Maestro does support stealthchop and spreadcycle.
