    Is this VFA?
    • Arminasundefined
      Arminas
      I have a question - is this a VFA or not? Belt is original Gates, so maybe it's not the belt issue? Looking from one side the wall looks pretty good, but from the front view there is a pattern.
      oliofundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @Arminas
        @Arminas what's the distance peak to peak? does the pattern change on longer/taller/slimmer prints?
        Arminasundefined 1 Reply Last reply Reply Quote 0
        • Arminasundefined
          Arminas @oliof
          @oliof pattern spacing is about 1.5 mm. I have not done a lot of print on this printer yet, but on curved part (this part is also taller and slimmer) the pattern spacing is about 1 mm.
            Phaedrux Moderator @Arminas
            @Arminas said in Is this VFA?:
            How bout the idlers? Do they have an actual GT2 profile, or something else?
            If you turn the motor shafts by hand can you feel any cogging?
            • Arminasundefined
              Arminas @Phaedrux
              @Phaedrux instead of toothed idlers I have placed a bearing stack like in the RatRig (I assume those bearings will last longer).
              Motors are not very smooth while turning by hand, motech motors nema23 on X axis and nema17 on Y.
