New experimental DuetPi Bookworm builds available
With Duet 3.5.0 being released, I decided I would run
apt update && apt upgrade
on my RPI5. I am getting the following errors.
rr:1 https://pkg.duet3d.com stable/armv7 arm64 duetpimanagementplugin arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:2 https://pkg.duet3d.com stable/armv7 arm64 duetpluginservice arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:3 https://pkg.duet3d.com stable/armv7 arm64 duetsoftwareframework arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:4 https://pkg.duet3d.com stable/armv7 arm64 duettools arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:5 https://pkg.duet3d.com stable/armv7 arm64 duetcontrolserver arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:6 https://pkg.duet3d.com stable/armv7 arm64 duetruntime arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Err:7 https://pkg.duet3d.com stable/armv7 arm64 duetwebserver arm64 3.5.0~rc.4+2 404 Not Found [IP: 134.209.94.168 443] Ign:8 https://pkg.duet3d.com stable/armv7 arm64 reprapfirmware all 3.5.0~rc.4+2-1 Err:8 https://pkg.duet3d.com stable/armv7 arm64 reprapfirmware all 3.5.0~rc.4+2-1 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetpimanagementplugin_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetpluginservice_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetsoftwareframework_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duettools_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetcontrolserver_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetruntime_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-arm64/duetwebserver_3.5.0%7erc.4%2b2_arm64.deb 404 Not Found [IP: 134.209.94.168 443] E: Failed to fetch https://pkg.duet3d.com/dists/stable/armv7/binary-armhf/reprapfirmware_3.5.0%7erc.4%2b2-1_all.deb 404 Not Found [IP: 134.209.94.168 443] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Is this something wrong on my end?
@kiendeleo It's WIP. I will announce 3.5.0 when everything is ready.
@chrishamm okay, I just wanted to submit the bug
This post is deleted! -
@oozeBot
hey. Can you just shortly explain how to change the gpiochip 0 to 4?
I couldn´t manage it with the docu.
Would be great, thanks -
@IndeX4D You can change it by editing
/opt/dsf/conf/config.json
on the Pi. Runningsudo set-dsf-chipdev
on the Pi via SSH should work as well. -
@chrishamm
I don´t understand why I could printing yesterday and now it´s freaking out.
I have the pi5 and the image flashed from above. qithout arm version..
Duet 6hc and expansions 1hcl 2x + 1lc -
@chrishamm said in New experimental DuetPi Bookworm builds available:
was alreasy on gpiochip4, strange...
@IndeX4D is ths forum still the right place for questions?
