    Connecting Accelerator - erratic behavior
    • phoenixundefined
      phoenix
      I am trying to connect an accelerator to establish input shaping profiles.
      I have a simple LIS3DH, connected to the Duex board (I am running a Toolchanger). Firmware is RepRapFirmware for Duet 2 WiFi/Ethernet 3.5.0-rc.3 (2024-01-24). Duet WiFi Server Version: 2.1beta6
      When putting the command M955 P0 C"spi.cs6+spi.cs5"
      the first time, it most often fails, and a repeat of the command does usually not work. when I however enter M955 P0 C"spi.cs5+spi.cs6", followed by the correct M955 P0 C"spi.cs6+spi.cs5", it most always records "connected".
      The InputShaper plugin seems to recognize it (most of the time - there are times that it simply takes a few more tries for it to be recognized). I have connected it through a flat ribbon, surrounded it with copper tape, and connected the shield to GND.
      My issue (perhaps not surprisingly) is that when trying to record a profile, it makes the first move, but then stalls. When I cancel and try again, it usually reboots itself after the first move.
      Would appreciate pointers where to start looking? Is my accelerator junk and I should try with another one?
      modlundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • modlundefined
        modl @phoenix
        This post is deleted!
        • T3P3Tonyundefined
          T3P3Tony administrators @phoenix
          @phoenix what LIS3DH module is it and how long is your wiring.
          www.duet3d.com
          phoenixundefined 1 Reply Last reply Reply Quote 0
          • phoenixundefined
            phoenix @T3P3Tony
            @T3P3Tony said in Connecting Accelerator - erratic behavior:
            Thanks for following up: the cable is about 50cm long.
            The module itself is an unbranded one from Amazon - the chip reads 96AED - HED - UTE8
            • T3P3Tonyundefined
              @phoenix ,50cm should be ok
              You could try a test with a shorter wire just to confirm it's not that.
              www.duet3d.com
              • phoenixundefined
                phoenix @T3P3Tony
                @T3P3Tony I should have mentioned: I get the same behavior using a 10cm lead. pretty sure it's not the wire length.
