Common +3.3V and GND for multiple Duet MFMs
Hi there,
my search in the forum was not really successful so I'd just ask my simple question:
Recently I've added three more extruder drives to my printer and now I'd like to add three more MFMs to the existing one MFM I used up until now.
The existing MFM is wired to E0_STOP on a Duet2Wifi. It has +3.3V and GND supplied through the corresponding pins on E0_STOP connector.
To keep wiring simple I would like to use +3.3V and GND from E0_STOP for the other three MFMs as well, and only wire the signal line from the MFMs to the respective connectors on the Duet board. Would this be possible? Or does every MFM need separate +3.3V and GND lines?Thanks in advance,
Andreas -
@themelle that should be fine
@themelle that should be fine as long as the ground wire isn't especially thin.
@themelle 22awg should be OK.
@dc42 Thanks again, so I should be safe as it is - great
@themelle thanks for confirming.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
