    PID Tuning Procedure
    2.8k
      This is a good place to start.
      https://docs.duet3d.com/en/How_to_guides/Commissioning
      CarlBossonundefined 2 Replies Last reply Reply Quote 0
      • CarlBossonundefined
        CarlBosson @Phaedrux
        @Phaedrux
        After all your help I wanted to give you an update. I have been using the commissioning document to fine tune the board. As I now have this "Work" printer at my home I have been doing this in the evenings. I am very close with the basic setup and may start a test print tonight or tomorrow, definitely by this weekend.
        There is no box!
          @Phaedrux
          I ran in to a issue maybe you can help with?
          When I home the axis individually or by home all, they work correctly. Once homed X, and Y work properly. But Z goes in the wrong direction. If I select +25mm it will go back towards the end stop. I have changed from S1 to S0 in the homing and config.g a few times trying different combinations but no luck. See below the config.g, homeall.g and homeZ.g
          Thank you in advance.
          3/20/24
          Config.g
          ; Configuration file for RepRapFirmware on Duet 2 WiFi
          ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Sun Mar 10 2024 17:12:57 GMT-0400 (Eastern Daylight Time)
          ; General
          M550 P"My Printer" ; set hostname
          M552 S1 ; configure WiFi adapter
          M586 P0 S1 ; configure HTTP
          ; Smart Drivers
          M569 P0 S1 D2 ; driver 0 goes forwards (X axis)
          M569 P1 S1 D2 ; driver 1 goes forwards (Y axis)
          M569 P2 S1 D2 ; driver 2 goes forwards (Z axis)
          M569 P3 S1 D2 ; driver 3 goes forwards (extruder 0)
          ; Motor Idle Current Reduction
          M906 I30 ; set motor current idle factor
          M84 S30 ; set motor current idle timeout
          ; Axes
          M584 X0 Y1 Z2 ; set axis mapping
          M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
          M906 X1450 Y1450 Z1450 ; set axis driver currents
          M92 X80.58 Y80.58 Z400 ; configure steps per mm
          M208 X0:300 Y0:300 Z0:400 ; set minimum and maximum axis limits
          M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
          M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
          ; Extruders
          M584 E3 ; set extruder mapping
          M350 E16 I1 ; configure microstepping with interpolation
          M906 E1000 ; set extruder driver currents
          M92 E799.53 ; configure steps per mm
          M566 E120 ; set maximum instantaneous speed changes (mm/min)
          M203 E3600 ; set maximum speeds (mm/min)
          M201 E250 ; set accelerations (mm/s^2)
          ; Kinematics
          M669 K0 ; configure Cartesian kinematics
          ; Probes
          ;M558 K0 P0 H5 F120 T6000 ; configure manual probe via slot #0
          ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
          M574 X1 P"!xstop" S1 ; configure X axis endstop
          M574 Y1 P"!ystop" S1 ; configure Y axis endstop
          M574 Z1 P"!zstop" S1 ; configure Z axis endstop
          ; Sensors
          M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
          M308 S1 P"spi.cs1" Y"rtdmax31865" ; configure sensor #1
          M950 H1 C"e0heat" T1
          M950 H0 C"bedheat" T0 ; create heater #0
          M143 H0 P0 T0 C0 S200 A0 ; configure heater monitor #0 for heater #0
          M307 H0 R0.457 K0.287:0.000 D28.14 E1.35 S1.00 B0 V24.6 ; configure model of heater #0
          M950 H1 C"e0heat" T1 ; create heater #1
          M143 H1 P0 T1 C0 S475 A0 ; configure heater monitor #0 for heater #1
          M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
          ; Heated beds
          M140 P0 H0 ; configure heated bed #0
          M950 F0 C"fan0" ; create fan #0
          M106 P0 S0 L0 X1 B0.1 ; configure fan #0
          M950 F1 C"fan1" ; create fan #1
          M106 P1 S0 B0.1 H1 T45 ; configure fan #1
          M563 P0 D0 H1 F0 ; create tool #0
          M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
          HomeZ.g
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Sun Mar 10 2024 17:13:00 GMT-0400 (Eastern Daylight Time)
          ; lift Z
          G91 ; relative positioning
          G1 H2 Z-5 ; move Z relative to current position to avoid dragging nozzle over the bed
          ;G90 ; absolute positioning
          ; home Z
          ;var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
          ;var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
          ;G1 X{var.xCenter} Y{var.yCenter} F6000 ; go to bed centre
          ;G30 ; probe the bed
          ;Home Z with out probe
          G1 H1 Z20 F1800 ; move z up until the endstop is triggered
          G1 H2 Z-5 F900 ;go back a few mm
          G1 H1 Z20 F900 ; move slowly to z axis endstop once more (second pass)
          Homeall.g
          ; homeall.g
          ; called to home all axes
          ; lift Z
          G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed
          ; home XY
          var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
          var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
          G1 H1 X{-var.xTravel} Y{-var.yTravel} F600 ; coarse home in the -X and -Y directions
          G1 H2 X5 Y5 F6000 ; move back 5mm
          G1 H1 X{-var.xTravel} Y{-var.yTravel} F300 ; fine home in the -X and -Y directions
          ; home Z
          G91 ;relative positioning
          G1 H2 Z5 F900 ; Go back a few mm
          G1 H1 Z20 F900 ; move back slowly to z axis endstop once more (second pass)
          There is no box!
            Phaedrux Moderator @CarlBosson
            @CarlBosson said in PID Tuning Procedure:
            Keep in mind that Z0 is when the nozzle and bed are touching, and a Z+ move will make them move apart and a Z- move will make them move together. The position of the endstop does not have any bearing on the movement. If the endstop is at the Z0 end, it's a Z1, for low end, and the G1 Z homing move must be negative. If the endstop is at the Z max position farthest away from the bed, it's a Z2, for high end, and the G1 Z homing move must be positive.
            If all that is as it should be and a Z move is going the wrong direction, you may need to change the direction of rotation of the motor set by M569 S1 or S0.
            CarlBossonundefined 1 Reply Last reply Reply Quote 0
              @Phaedrux
              Hot end is at 200c heated bed is at 60c all axes are homed but the extrude and retract buttons are grayed out. I can not select them?
              Carl
              There is no box!
                droftarts administrators @CarlBosson
                @CarlBosson If the Retract and Extrude buttons are greyed out, check that the tool is selected and active. If it is still greyed out, check in config.g that your tool definition (M563) includes the extruder drive (D parameter), eg M563 P0 D0 H1 F0.
                  CarlBosson @droftarts
                  @droftarts That was it. Thank you
                  There is no box!
                    You may want to add T0 to the end of your config.g to select the first tool at startup.
                      @Phaedrux
                      Thank you for your input and all your help. All the heaters have been tuned. All the steppers have been calibrated. I printed this Benchy over the weekend. This looks pretty good to me! Have a great day.
                      Carl
                      There is no box!
                      droftartsundefined 1 Reply Last reply Reply Quote 2
                        @CarlBosson Well done, that does look like a pretty nice Benchy!
