    All fans failed near end of print
    319
    • jrwaters2undefined
      jrwaters2
      In January of last year I moved over to higher end parts-cooling fans (based on recommendations here https://forum.duet3d.com/category/5/duet-hardware-and-wiring).
      Once I had my new fans, I purchased a new Duet2 WiFi in April and I haven't had any issues since then.
      Last night during perhaps the last hour of a print, apparently all of my fans went out. I say apparently because
      1. The filament was melted at the bottom of my bowden tube.
      2. None of the fans work today - hotend fan and both parts fans.
      I saw a thread where someone had been doing maintenance and shorted something (https://forum.duet3d.com/topic/4018/my-fans-have-stopped-working) but nothing like that happened. Everything has been working fine for the last 8 months.
      Is there anything that might have triggered this? Is there any chance this would be covered under Warranty?
      Thanks
      Jack
      • oliofundefined
        oliof
        This post is deleted!
        • oliofundefined
          oliof
          Hi, there is precious little info here to make any call. Let's start by a couple base questions -which particular fans did you buy for hotend and part cooling?
          -how are they wired up?
          -what's the voltage you fed them? -how were they configured in config.g? -what kind of machine design is this? open frame, enclosed, heated chamber? if you happen to have spare fans lying around, can these still be driven? Some illustrative pictures of your setup (board and hotend side wiring, machine setup and layout) might also help understand the situation better.
          Also, a usual failure of fan ports on a control board would be blown Mosfets, which would cause the fans to run at full power; or a blown fuse, which would likely affect other parts of your setup as well.
          jrwaters2undefined 1 Reply Last reply Reply Quote 0
            jrwaters2 @oliof
            Hi @oliof
            I purchased a Sunon Maglev 5015 which is 24V and a Mechatronics B5015E24B-BSR also 24V. All of my fines are wired up 2-pin to the FAN headers using the Duet-provided connectors. So the hotend fan is always-on, others are as-needed.
            It is an open frame design with a heated bed. Spare fans don't work either.
            Here is my config.g.
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 07:16:08 GMT-0700 (Pacific Daylight Time)
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 controlx X motor and goes backwards with new motor and wiring
            M569 P1 S0 ; physical drive 1 controls Y motor and goes backwards with new motor and wiring
            M569 P2 S0 ; physical drive 2 controls both Z motors and goes backwards
            M569 P3 S1 ; physical drive 3 goes forwards with new motor and wiring
            M569 P4 S1 ; physical drive 4 goes forwards because no longer using an interted Titan
            M584 X0 Y1 Z2 E3:4 ; set drive mapping, including second extruder
            M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation, including second extruder
            ;M92 X100.00 Y100.00 Z400.00 E418.59:418.59 ; set steps per mm including second extruder. E values calculated by JW
            ;M92 X100.00 Y100.05 Z405.41 E418.59:418.59 ; set steps per mm including second extruder. E values calculated by JW ; Z value was coming up short - calibrated to 405.41 ; Y was short calibrated to 100.05
            M92 X101.00 Y101.00 Z411.58 E418.59:415 ; BMG Extruder says use 415
            M566 X600.00 Y600.00 Z18.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min), including second extruder
            M203 X7200.00 Y7200.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) including second extruder. 7200=120 mm/sec. 180=3 mm/sec. 1200=20 mm/sec
            M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00 ; set accelerations (mm/s^2) including second extruder
            ;M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent, including 2nd extruder. Nema 17 rated 900mA. Configurator recently used X500 Y500 Z500
            ; M906 X1800 Y1800 Z800 E1800:800 I30 ; New motors are rated 2.0 Amps
            M906 X1200 Y1200 Z800 E1200:800 I30 ; New motors are rated 2.0 Amps but X getting hot - try 1200 for the new ones
            M84 S30 ; Set idle timeout
            M208 X-7 Y-19 Z0 S1 ; set axis minima for V6 hotend
            ;Maxima is same for V6 or Chimera+ hotend.
            M208 X220 Y220 Z240 S0 ; set axis maxima - tested this. I can go to z=245 and still issue home which moves carriage up to z=250
            M574 X1 S1 P"xstop" ; Rewired endstop and moved it back to X pins - also made it active-high (normally closed) at the same time.
            M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop - at some point in future will re-wire this to be active-high
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z. probe position (Z=1) is activated at the low end of the bed (like microswitch being at bottom) but S2 defines Z sensor as a probe
            ; My BlTouch has two pins wired to zprobe.in and ground which are on the "Z Probe" header.
            ; The first is green and that is connected to the white z_min on the BLTouch.
            ; The second is yellow and that is connected to the black ground on the BLTouch.
            ; The other wires are connected on the expansion header using pins 1 and 2 which are 5V and ground.
            ; Those power pins are Red (Pin 1 +5V) and Brown (Pin 2 GND) and connect to BLTouch wires of the same color.
            ; The last wire is Orange at Duet and is connected to the expansion header using pin 8 which is heater3.
            ; The Orange wire connects to the BLTouch orange wire with is software PLM or the control channel.
            M307 H3 A-1 C-1 D-1 ; unbind that heater 3 pin
            ;M558 P9 C"^zprobe.in" H5 F100 T6000 R0.2 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
            ; Decreasing the Z value is equivalent to saying the probe is that closer to the bed and
            ; this results in loosening the print.
            ; Hence, decrease the Z value to loosen things.
            G31 P25 X29.45 Y-10.4 Z1.417 ; ?
            ; define mesh grid
            M557 X30:210 Y15:210 S40 ; This probes points of 30, 70, 110, 150, 190
            ; Now using a silicon pad by a company called Polisi. The specifications state "With 1meter NTC 100K 3950 thermistor for temperature Control. Power consumption: 300W"
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp. My pad uses NTC3950 thermister which has Beta of 3950. Trying default C=0
            ; I think this is Marlin type 11 which is "100k beta 3950 1% thermistor (4.7k pull-up)"
            M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0. heater 0 uses the bed_heat pin, sensor 0
            M307 H0 B0 S.90 ; disable bang-bang mode for the bed heater and set PWM limit to 90% based on doing M303 H0 S110 P1
            M143 H0 S130 ; set temperature limit for heater 0 to 130C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp - Even though datasheet says B=4267, E3d recommends T100000 B4725 C7.06e-8
            M143 H1 S262 ; set temperature limit for heater 1 to 262 Celcius which is also the Duet default
            ;M143 H1 S288 ; set temperature limit for heater 1 to 285 Celcius for nozzle tightening only. Seems to force temp to be < this, not <=. Also needs buffer to overshoot.
            M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp - Even though datasheet says B=4267, E3d recommends T100000 B4725 C7.06e-8
            M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M143 H2 S262 ; set temperature limit for heater 1 to 262 Celcius which is also the Duet default
            ;M143 H2 S288 ; set temperature limit for heater 2 to 285 Celcius for nozzle tightening only. Seems to force temp to be < this, not <=. Also needs buffer to overshoot.
            ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
            M950 F0 C"fan0" Q3000 L128 ; create fan 0 on pin fan0 and set its frequency. Minimum 50% power as doesn't blow much below that.
            M950 F1 C"fan1" Q500 L128 ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
            M563 P0 D0 H1 F0:1 ; define tool 0 - assign two fans: Fan0 and Fan1
            ;Define bed screws - well close enough to bed screws that can be reached by my probe
            ; Bed adjustment screws are at (110,0), (0,220), (220,220). In general I want 20 mm margin to bed edge
            ; so I would ideally target (110, 20), (20, 200), (200,200).
            ; With MGN mod and new BLTouch placement, my new probe position is 29 mm to the right and
            ; 7 mm in front of printhead. So, I can reach Y=0 or Y=20. Can I reach X=20? Well, my X minima
            ; from above is -4 and my BLTouch is 29 mm to the right of that so the smallest X value
            ; that my sensor can reach is 25 mm
            M671 X110:25:200 Y20:200:200 ; With MGN mod and new BLTouch placement, (110,20), (25,200), and (200,200).
            T0 ; select first tool
            ; G29 S2 ; Not using any height maps right now
            G29 S1 ; Load height map
            jay_s_ukundefined jrwaters2undefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @jrwaters2
              @jrwaters2 have you checked the fan fuse? It's 1A IIRC
                jrwaters2 @jay_s_uk
                @jay_s_uk I did not! I read another post and that didn't come up.
                knowing there is a fuse a) makes me feel a bit dumb and b) makes me very excited. I'll check that today!
                  jrwaters2 @jrwaters2
                  @jay_s_uk it was the fuse - thank you so much! I never thought I would be so lucky that the thing that failed was because of a fuse. With my first duet I had experienced a failed mosfet leading to an always-on fan. But in another post I read that "If all the fans have stopped working then you have fused the via in the trace between the VIN pin of the fan jumper selection block and the +VIN power input terminal. You can add a wire on the back of the Duet to connect them together again.".
                  So I assumed the worst. Lesson learned.
                  I didn't have a spare fuse but I obtained supplies today and replaced the fuse with a 2 amp fuse because I read on the duet parts list web page that "PCB revisions 1.03 and later have a 1A mini auto blade fuse protecting the fan circuits when the fan voltage selection jumper is in the VIN position. You can increase the fuse rating to 2A or even 3A if your fans, air pumps etc. draw more than 1A in total."
                  I turned on the system and my hot-end fan came on - great!!! Then I enabled my cooling fans and within say 5 seconds, the fuse blew. This is actually also great - because now I get to find the real root of the problem.
                  I replaced the fuse again and removed the Mechatronics fan. I've left the system up with fans on for about 5 minutes. It seems like this is the culprit because removing the other fan but leaving the Mechatronics will also blow the fuse. I put a multi-meter on the connectors to the Mechatronics fan (the terminals that plug into the duet so that I'm checking the full fan and wiring) and checked the resistance and I see about 16 Ohms of resistance. What I read said that this is a typical expected range. I would really like to find the root cause of the root cause so that this doesn't happen again. Any suggestions are welcome.
                  Thank you all for the help @jay_s_uk and @oliof and have a wonderful weekend.
                  jrwaters2undefined 1 Reply Last reply Reply Quote 1
                    Final update (I edited above a few times). I've cut the connectors off the Mechatonics fan and I used a 9V battery to try to get the fan to operate with no luck.
                    I always test with a 9V battery before installing and this fan was working previously. Its has < 50 hours of usage. So, something internal to the fan but have gone wrong. But, I have no idea what triggered it. A little unsatisfying. I have a second of the same model which works fine with 9V battery. At some point I'll wire that up and put it in production.
                    Jack
                    droftartsundefined 1 Reply Last reply Reply Quote 1
                    • dc42undefined dc42 marked this topic as a question
                      droftarts administrators @jrwaters2
                      @jrwaters2 said in All fans failed near end of print:
                      Good idea! Thanks!
