    COREXY Homing issues
    • Pierrelitoundefined
      Pierrelito
      Hello everybody,
      I am currently setting RRF 3.4 up on my Voron 0.1.
      I run into some issues with the axis and homing X and Y:
      • When I home X (to max position 120mm), it does the first bump into the endstop, goes back 5mm then ram the endstop and causing a slight movement in -Y. I have to hit "emergency stop", never been able to home this axis.
      • When I home Y (to max position 120mm), the first bump into the endstop is good, then it goes to Y80 while the X axis is moving toward its Lowest position.. It then does bump correctly in the endstop and considering the Homing OK.
      Config.g:
      General
      M550 P"Voron 0.1" ; set hostname
      M552 S1 ; configure WiFi adapter
      M586 P0 S1 ; configure HTTP
      M586 P1 S1 ; configure FTP
      ; Smart Drivers
      ;M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
      ;M569 P0.1 S0 D2 ; driver 0.1 goes forwards (Y axis)
      ;M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis)
      ;M569 P0.3 S1 D2 ; driver 0.3 goes forwards (extruder 0)
      M569 P0.0 S1 D3 V20 ; physical drive 0.0 goes forwards
      M569 P0.1 S1 D3 V20 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 D3 V20 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 D3 V20
      ; Kinematics
      M669 K1 ; configure CoreXY kinematics
      M667 S1;
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 Z0.2 ; set axis mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M906 X800 Y800 Z800 ; set axis driver currents
      M92 X80 Y80 Z400 ; configure steps per mm
      M208 X0:120 Y0:120 Z0:120 ; set minimum and maximum axis limits
      M566 X900 Y900 Z25 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z30 ; set accelerations (mm/s^2)
      ; Extruders
      M584 E0.3 ; set extruder mapping
      M350 E16 I1 ; configure microstepping with interpolation
      M906 E1000 ; set extruder driver currents
      M92 E735 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E3600 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      ; Probes
      ;M558 K0 P0 H5 F120 T6000 ; configure manual probe via slot #0
      ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
      M574 X2 P"io0.in" S1 ; configure X axis endstop
      M574 Y2 P"io1.in" S1 ; configure Y axis endstop
      M574 Z1 P"io2.in" S1 ; configure Z axis endstop
      ; Mesh Bed Compensation
      M557 X25:95 Y25:95 S40:40 ; define grid for mesh bed compensation
      ; Sensors
      M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
      M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
      M950 H0 C"out0" T0 ; create heater #0
      M143 H0 P0 T0 C0 S115 A0 ; configure heater monitor #0 for heater #0
      M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0
      M950 H1 C"out1" T1 ; create heater #1
      M143 H1 P0 T1 C0 S290 A0 ; configure heater monitor #0 for heater #1
      M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
      ; Heated beds
      M140 P0 H0 ; configure heated bed #0
      M950 F0 C"out6" ; create fan #0
      M106 P0 S0 L0 X1 B0.1 ; configure fan #0
      M950 F1 C"out5" ; create fan #1
      M106 P1 S0 B0.1 H1 T20 ; configure fan #1
      ;M950 F2 C"out5" ; create fan #2
      ;M106 P2 S0 L0 X1 B0.1 ; configure fan #2
      M563 P0 D0 H1 F0 ; create tool #0
      M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
      Homex.g
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2+6 on Fri Feb 23 2024 20:05:47 GMT+0100 (heure normale d’Europe centrale)
      ; lift Z
      G91 ; relative positioning
      G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
      G90 ; absolute positioning
      ; home X
      var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
      G1 H1 X120 F600 ; coarse home in the -X direction
      G1 H2 X-5 F600 ; move back 5mm
      G1 H1 X120 F300 ; fine home in the -X direction
      G1 H2 Z-5 F6000 ; lower Z again
      Homey.g
      ; homey.g
      ; called to home the Y axis
      ; lift Z
      ; home Y
      var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 Y120 F600 ; coarse home in the -Y direction
      G1 H2 Y-5 F3000 ; move back 5mm
      G1 H1 Y120 F500 ; fine home in the -Y direction
      Thank you in advance for any help you can provide.
      • oliofundefined
        oliof
        your homex.gnand homey.g dontatch what you describe, they look like normal homing sequences to me. do you have homeall.g as well? if yes, please share.
        If a sudden stop of the X motion jumps your y motion, it's likely a mechanical issue (skewed X gantry or issues with (uneven) belt tension).
        Pierrelitoundefined 1 Reply Last reply Reply Quote 0
          Pierrelito @oliof
          @oliof
          Hi
          The homeall only bump the y Axis on its max position until I shutdown the printer.
          Here is the Homeall.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2+6 on Fri Feb 23 2024 14:10:44 GMT+0100 (heure normale d’Europe centrale)
          ; lift Z
          G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed
          ; home XY
          var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
          var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
          G1 H1 X{var.xTravel} Y{var.yTravel} F600 ; coarse home
          G1 H1 X{var.xTravel} F600 ; coarse home in the +X direction
          G1 H1 Y{var.yTravel} F600 ; coarse home in the +Y direction
          G1 H2 X-5 Y-5 F6000 ; move back 5mm
          G1 H1 X{var.xTravel} Y{var.yTravel} F300 ; fine home
          G1 H1 X{var.xTravel} F300 ; fine home in the +X direction
          G1 H1 Y{var.yTravel} F300 ; fine home in the +Y direction
          ; home Z
          var zTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
          G1 H1 Z{-var.zTravel} F600 ; coarse home in the -Z direction
          G1 H2 Z5 F6000 ; move back 5mm
          G1 H1 Z-10 F300 ; fine home in the -Z direction
          Belts Tensions are very similar,
          Skew is around '0.9%) EDIT 0.9° according to various skew tests done this week with marlin
            Pierrelito @Pierrelito
            I have solved my issue
            ; homex.g
            ; lift Z
            ; home X
            G91
            G1 H1 X{var.maxTravel} F600 ; coarse home in the +X direction
            G1 H1 X-5 F6000 ; move back 5mm
            G1 H1 X{var.maxTravel} F300 ; fine home in the +X direction
            G1 H2 Z-5 ; move Z relative to current position to avoid dragging nozzle over the bed
            G90 ; absolute positioning ; lower Z again
            ; homey.g
            ; lift Z
            ; home Y
            G1 H1 Y{var.maxTravel} F600 ; coarse home in the +Y direction
            G1 H1 Y-5 F3000 ; move back 5mm
            G1 H1 Y{var.maxTravel} F500 ; fine home in the +Y direction
            G1 H1 Z-5 ; move Z relative to current position to avoid dragging nozzle over the bed
            ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi
            ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2+6 on Fri Feb 23 2024 14:10:43 GMT+0100 (heure normale d’Europe centrale)
            ; General
            ; Smart Drivers
            M569 P0.0 S0 D3 V20 ; physical drive 0.0 goes forwards
            M569 P0.1 S0 D3 V20 ; physical drive 0.1 goes forwards
            M569 P0.3 S1 D3 V20
            ; Kinematics
            M667 S1;
            ; Axes
            M584 X0.1 Y0.0 Z0.2 ; set axis mapping
            ; Extruders
            ; Probes
            ; Sensors
            ; Heated beds
            Phaedruxundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @Pierrelito
              @Pierrelito said in COREXY Homing issues:
              Don't use H1 on your back off move. The H1 means to move until an endstop switch is triggered. Just leave the H off entirely, or use H0 if you want to be specific.
              • gloomyandyundefined
                gloomyandy @Pierrelito
                @Pierrelito I'd also avoid the use of
                as well at that point your axis is homed so you can just use a normal (H0) move to back away from the endstop. H2 means use an individual motor move, which I'm not sure you want with a corexy printer.
