Solved Ajax communication error: connection terminated
Check the settings > general tab on the left bar.
https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#settings-general
@Phaedrux Finally getting back around to this. I actually had some prints to do and other house projects to wrap up.
Looks like I'm running duet web control 3.3.0 and RR firmware at version 3.1.1
Aren't those 2 versions supposed to match?
Should I try and install version 3.3 again?
@Mklein23 If looks like DWC got updated, but RRF didn't, because of this error:
Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found
You need the Duet2CombinedIAP.bin file in your /sys folder. Download "Duet2CombinedIAP.bin" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1 and upload it to your sys folder, then send
M997 S0
to update the firmware to 3.3.Then download the RRF 3.4.6 zip and update to that:
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.6.zipIan
Duet web control is at version 3.4.6
RR firmware is at version 3.4.6Thank you so much for your patience and assistance throughout this adventure.
I added the combined IAP file, then re-installed the 3.3.0 combined.zip file for 3.3.
That installed perfectly, then I installed the 3.4.6 combined zip and it just worked.
@Mklein23 great, hopefully this resolves the initial problem of not being able to connect to DWC!
